Underworld blu-ray
johnnyb
Underworld blu-ray
Post by johnnyb »
I've typically had pretty good luck with [gradually] converting my blu-ray collection into MKV's for sharing on my home network. For Halloween I grabbed Underworld, tried the same process...but got an error, though I've tried a few different times with different [main] title combinations (audio, etc)...
This title doesn't seem to have any issues on here -- at least that seem to be reported, and was curious if anyone had any ideas as to what the issue might be. I will, of course, send in an error report as usual, but wanted to check here as well. :)
Error 'Scsi error - HARDWARE ERROR:TRACK FOLLOWING ERROR' occurred while reading '/BDMV/STREAM/00011.m2ts' at offset '13765767168'
Error 'Scsi error - HARDWARE ERROR:TRACK FOLLOWING ERROR' occurred while reading '/BDMV/STREAM/00011.m2ts' at offset '13765773312'
DEBUG: Code 0 at >upK5X|e6k><)8ZFvZ&=:29394298
DEBUG: Code 0 at 'P}QIvFRZXb'-%\}uKT*:121261681
DEBUG: Code 0 at >upK5X|e6k><)8ZFvZ&=:29394183
DEBUG: Code 6721569 at >upK5X|e6k><)8ZFvZ&=:29393309
DEBUG: Code 0 at O;cBK@w8JNA"H}}wId#<U:121266534
Failed to save title 0 to file /Users/Server/Desktop/blu temp/LOGICAL_VOLUME_ID/title00.mkv
0 titles saved, 1 failed
And then I get a failed dialogue box.
Any suggestions?
Thank you!
setarip_old
Re: Underworld blu-ray
Post by setarip_old »
Failing drive or dirty lens...
johnnyb
Post by johnnyb »
even if it just worked when I tested it out with another disc...?
(and then retried Underworld, with no success)?
drvenom14
Post by drvenom14 »
Bump.. I am having the same hardware issue with only Green Hornet. I have tried other discs with success.
setarip_old
To cover all possibilities, try cleaning the disc...
goaliebob99
Post by goaliebob99 »
Bump! Same issue with Back to the Future disk 1, brand new disk out of the box, plays fine in other players, rips fine in other programs, and drive is brand new.
oscillator
Post by oscillator »
I get this error when trying to rip Underworld as well. I have tried this with 2 separate discs.
Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/BDMV/STREAM/00011.m2ts' at offset '303759360'
Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/BDMV/STREAM/00011.m2ts' at offset '303820800'
Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/BDMV/STREAM/00011.m2ts' at offset '303826944'
DEBUG: Code 0 at a@.8T')HOvTQ SNc}u*O:121262739
DEBUG: Code 0 at lj^jzws<Rp!qx54Y.!:S:121261888
DEBUG: Code 0 at a@.8T')HOvTQ SNc}u*O:213130743
DEBUG: Code 148353 at a@.8T')HOvTQ SNc}u*O:29393332
DEBUG: Code 0 at e+!PDn"":im09l/RAaww*:213134584
Failed to save title 0 to file D:/MKV/MKV-UNSORTED/Underworld (Unrated Extended Cut) (2003)/Underworld_(Unrated_Extended_Cut)_(2003)_t00.mkv
Uncorrectable errors like that are an indication of a hardware read failure. That means either the drive or the disk has a problem.
If the offset is the same for the errors on both disks you tried, the disks may be mastered poorly. If they're in different places, it is possible the disks are both scratched.
But MakeMKV is simply reporting the error it got back from the hardware in these cases.
