deadchip12
@RESET_9999
I looked for Alien Romulus web rpu in your google drive folder and only saw Alien.Romulus.2024.UHD.BluRay.2160p.TrueHD.Atmos.7.1.DV.HEVC.REMUX-FraMeSToR Retail P7 FEL (cmv4.0 added).bin. Is this file the equivalent of CMV4.0_L3L8L9_transfered.bin? Do we just inject this directly to the bluray mkv file?
darrrkmanxxx
can you please share the link with all of the RPUs?deadchip12 wrote: ↑Mon Jan 06, 2025 4:56 am@RESET_9999
The link is private...
Instructions on how to access it are in the Resolve Metadata Generation tutorial comments.
yes, I did all the possible movies on my GD.deadchip12 wrote: ↑Mon Jan 06, 2025 4:56 amI looked for Alien Romulus web rpu in your google drive folder and only saw Alien.Romulus.2024.UHD.BluRay.2160p.TrueHD.Atmos.7.1.DV.HEVC.REMUX-FraMeSToR Retail P7 FEL (cmv4.0 added).bin. Is this file the equivalent of CMV4.0_L3L8L9_transfered.bin? Do we just inject this directly to the bluray mkv file?
darrrkmanxxx
@RESET_9999
For devices who can't play P7, what would be the workflow to get the best out of dynamic metadata?
exmaple:
I have one profile 7 remux and a web-dl profile 8, which are compatible in brighntess.
- Extract rpu from web-dl p8
- convert P7 to P8 with dovi_tool
- inject into converted remux
Is that correct?
exmaple:
Is that correct?
just convert the P7 rip to P8 with workflow 4-1
darrrkmanxxx
thanks, is this the same as with dovi_tool mode 2 from quietvoid?
yes, all the workflows rely on dovi_tool.exe ... there's no other way.
Would it be possible to extract the HDR10plus of lower quality mkv and inject it into its higher quality variant?
Format : Matroska
Format version : Version 4
File size : 23.3 GiB
Duration : 1 h 59 min
Overall bit rate : 28.0 Mb/s
Frame rate : 23.976 FPS
Movie name : Alien Romulus (2024)
Encoded date : 2024-12-05 16:14:58 UTC
Writing application : mkvmerge v88.0 ('All I Know') 64-bit
Writing library : libebml v1.4.5 + libmatroska v1.7.1 / Lavf60.3.100
Cover : Yes
Attachments : cover.jpg
Time code of first frame : 01:00:00:00
Time code source : Matroska tags
Video
Format : HEVC
HDR format : Dolby Vision, Version 1.0, Profile 8.1, dvhe.08.06, BL+RPU, no metadata compression, HDR10 compatible / SMPTE ST 2094 App 4, [B]Version HDR10+ Profile A, HDR10+ Profile A[/B] compatible
Codec ID : V_MPEGH/ISO/HEVC
Bit rate : 25.7 Mb/s
Width : 3 840 pixels
Height : 1 608 pixels
Display aspect ratio : 2.39:1
Frame rate mode : Constant
Frame rate : 23.976 (24000/1001) FPS
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 10 bits
Bits/(Pixel*Frame) : 0.173
Stream size : 21.4 GiB (92%)
Title : HSaber <-|-> Z@X
Default : Yes
Forced : No
Color range : Limited
Color primaries : BT.2020
Transfer characteristics : PQ
Mastering display color primaries : BT.2020
Mastering display luminance : min: 0.0001 cd/m2, max: 1000 cd/m2
Maximum Content Light Level : 1000 cd/m2
Maximum Frame-Average Light Level : 400 cd/m2
Format : Matroska
File size : 53.6 GiB
Overall bit rate mode : Variable
Overall bit rate : 64.5 Mb/s
Movie name : Alien: Romulus - Ultra HD™
Encoded date : 2024-11-26 14:39:36 UTC
Cover : Yes
Video
ID in the original source medium : 4113 (0x1011)
Format : HEVC
HDR format : Dolby Vision, Version 1.0, Profile 7.6, dvhe.07.06, BL+EL+RPU, no metadata compression, Blu-ray compatible / SMPTE ST 2086, Version HDR10, HDR10 compatible
Bit rate : 54.9 Mb/s
Height : 2 160 pixels
Display aspect ratio : 16:9
Color space : YUV
Bit depth : 10 bits
Bits/(Pixel*Frame) : 0.276
Stream size : 45.6 GiB (85%)
Title : English
Language : English
Default : Yes
Forced : No
Original source medium : Blu-ray
Yes, measure both videos if they are the same grade.
RESET_9999 wrote: ↑Fri Dec 27, 2024 2:59 pmNo, madvr generated metadata (3-2) is the worst and not really suited for DV playback. Also, Madvr scene cut detection is not very good. It's quite sensitive to flashes/explosions/fast movement and can sometimes miss obvious scene cuts. The best dv metadata generation is one of the analysis tunings using Davinci Resolve. I prefer the ''balanced tuning'' which is the dovi_scripts default in workflow 3-1Thanks for explaining. How to interpret those? Is the madvr plot the best, because it has the most dynamics?
If I do the madvr measuremnt, I adjust cmv4.0 when I generate from madvr file with dovi_tool ,e.g.
Hello
in your video you said that we should choose most highlights details in resolve but now i see that you prefer balanced. So what is the best ?
Yeah, when I did the video, I was using tuning 1.
After more tests/comparisons, I now prefer tuning 3 because it's a bit brighter without clipping. Both tunings are good though and tuning 3(balanced) is Resolve default.
ok thank you
Does Chroma Weight makes a big difference if it is used only in 100 nits trim?
yes and it doesn't matter if it's only a 100nits trim because whatever they did in the SDR trim gets extrapolated to any brightness.
thankfully CW is not used very often.
darrrkmanxxx
so if there are no CW trims (flat line) at 1000nits and my device has 1000nits peak brightness, will it still be tone mapped because of the 100nit trim?RESET_9999 wrote: ↑Fri Jan 10, 2025 3:22 pmyes and it doesn't matter if it's only a 100nits trim because whatever they did in the SDR trim gets extrapolated to any brightness.
