deadchip12
#10561 Post by deadchip12 » Mon Jan 06, 2025 4:56 am
@RESET_9999
I looked for Alien Romulus web rpu in your google drive folder and only saw Alien.Romulus.2024.UHD.BluRay.2160p.TrueHD.Atmos.7.1.DV.HEVC.REMUX-FraMeSToR Retail P7 FEL (cmv4.0 added).bin. Is this file the equivalent of CMV4.0_L3L8L9_transfered.bin? Do we just inject this directly to the bluray mkv file?
darrrkmanxxx
#10562 Post by darrrkmanxxx » Mon Jan 06, 2025 9:34 am
@RESET_9999
can you please share the link with all of the RPUs?
#10563 Post by RESET_9999 » Mon Jan 06, 2025 12:08 pm
The link is private...
Instructions on how to access it are in the Resolve Metadata Generation tutorial comments.
yes, I did all the possible movies on my GD.
darrrkmanxxx
#10564 Post by darrrkmanxxx » Tue Jan 07, 2025 1:20 pm
@RESET_9999
For devices who can't play P7, what would be the workflow to get the best out of dynamic metadata?
exmaple:
I have one profile 7 remux and a web-dl profile 8, which are compatible in brighntess.
- Extract rpu from web-dl p8
- convert P7 to P8 with dovi_tool
- inject into converted remux
Is that correct?
#10565 Post by RESET_9999 » Tue Jan 07, 2025 3:25 pm
just convert the P7 rip to P8 with workflow 4-1
darrrkmanxxx
#10566 Post by darrrkmanxxx » Tue Jan 07, 2025 3:40 pm
thanks, is this the same as with dovi_tool mode 2 from quietvoid?
#10567 Post by RESET_9999 » Tue Jan 07, 2025 3:49 pm
yes, all the workflows rely on dovi_tool.exe ... there's no other way.
fazambuja
#10568 Post by fazambuja » Wed Jan 08, 2025 2:18 am
Would it be possible to extract the HDR10plus of lower quality mkv and inject it into its higher quality variant?
File size                                : 23.3 GiB
Duration                                 : 1 h 59 min
Overall bit rate                         : 28.0 Mb/s
Frame rate                               : 23.976 FPS
Movie name                               : Alien Romulus (2024)
Encoded date                             : 2024-12-05 16:14:58 UTC
Writing application                      : mkvmerge v88.0 ('All I Know') 64-bit
Writing library                          : libebml v1.4.5 + libmatroska v1.7.1 / Lavf60.3.100
Cover                                    : Yes
Attachments                              : cover.jpg
Time code of first frame                 : 01:00:00:00
Time code source                         : Matroska tags
Video
HDR format                               : Dolby Vision, Version 1.0, Profile 8.1, dvhe.08.06, BL+RPU, no metadata compression, HDR10 compatible / SMPTE ST 2094 App 4, [B]Version HDR10+ Profile A, HDR10+ Profile A[/B] compatible
Bit rate                                 : 25.7 Mb/s
Height                                   : 1 608 pixels
Display aspect ratio                     : 2.39:1
Chroma subsampling                       : 4:2:0
Bits/(Pixel*Frame)                       : 0.173
Stream size                              : 21.4 GiB (92%)
Title                                    : HSaber <-|-> Z@X
Mastering display color primaries        : BT.2020
Maximum Frame-Average Light Level        : 400 cd/m2
File size                                : 53.6 GiB
Overall bit rate                         : 64.5 Mb/s
Movie name                               : Alien: Romulus - Ultra HD™
Encoded date                             : 2024-11-26 14:39:36 UTC
Cover                                    : Yes
Video
ID in the original source medium         : 4113 (0x1011)
HDR format                               : Dolby Vision, Version 1.0, Profile 7.6, dvhe.07.06, BL+EL+RPU, no metadata compression, Blu-ray compatible / SMPTE ST 2086, Version HDR10, HDR10 compatible
Bit rate                                 : 54.9 Mb/s
Bits/(Pixel*Frame)                       : 0.276
Stream size                              : 45.6 GiB (85%)
Title                                    : English
#10569 Post by RESET_9999 » Wed Jan 08, 2025 11:59 am
Yes, measure both videos if they are the same grade.
dkangel
#10570 Post by dkangel » Wed Jan 08, 2025 4:55 pm
RESET_9999 wrote:
Fri Dec 27, 2024 2:59 pm
Thanks for explaining. How to interpret those? Is the madvr plot the best, because it has the most dynamics?
If I do the madvr measuremnt, I adjust cmv4.0 when I generate from madvr file with dovi_tool ,e.g.
No, madvr generated metadata (3-2) is the worst and not really suited for DV playback. Also, Madvr scene cut detection is not very good. It's quite sensitive to flashes/explosions/fast movement and can sometimes miss obvious scene cuts. The best dv metadata generation is one of the analysis tunings using Davinci Resolve. I prefer the ''balanced tuning'' which is the dovi_scripts default in workflow 3-1
Hello
in your video you said that we should choose most highlights details in resolve but now i see that you prefer balanced. So what is the best ? :D
#10571 Post by RESET_9999 » Wed Jan 08, 2025 5:38 pm
Yeah, when I did the video, I was using tuning 1.
After more tests/comparisons, I now prefer tuning 3 because it's a bit brighter without clipping. Both tunings are good though and tuning 3(balanced) is Resolve default.
dkangel
#10572 Post by dkangel » Wed Jan 08, 2025 8:03 pm
ok thank you :)
powdeau
#10573 Post by powdeau » Fri Jan 10, 2025 12:22 pm
Does Chroma Weight makes a big difference if it is used only in 100 nits trim?
#10574 Post by RESET_9999 » Fri Jan 10, 2025 3:22 pm
yes and it doesn't matter if it's only a 100nits trim because whatever they did in the SDR trim gets extrapolated to any brightness.
thankfully CW is not used very often.
darrrkmanxxx
#10575 Post by darrrkmanxxx » Fri Jan 10, 2025 10:48 pm
so if there are no CW trims (flat line) at 1000nits and my device has 1000nits peak brightness, will it still be tone mapped because of the 100nit trim?
