Numb3rs DVDs Not Reading
Vrykodin
Post by Vrykodin »
I'm trying to record my DVD's like I've done with many other DVD's and BR's, but this series is giving me an error. I've tried manually setting to CellWalk, CellTrim, and CellFull and still doesn't work. I have CCExtractor installed but I don't know if I need to do any further configuration to it as I haven't used it before.
Thanks in advance for any insight.
Debug log started at Tue Jan 07 02:11:54 2025 , written by MakeMKV v1.17.8 win(x64-release)
001005:0000 MakeMKV v1.17.8 win(x64-release) started
001004:0000 Debug logging enabled, log will be saved as file://C:\Users\[Redacted]/MakeMKV_log.txt
No  SDF v098: ASUS_BW-16D1X-U_A105_212012021114_KL1N3A93248
DEBUG: Code 0 at H.L>:vj.[<bHehWh[:29396253
DEBUG: Code 0 at e`1A[8IgfdJS=V\(:213136746
DEBUG: Code 3 at E}P)4^&Zt'eI2]i`NTMR>^^t:29395310
SDF id v098: ASUS_BW-16D1X-U_A105_212012021114_KL1N3A93248
DEBUG: Code 2 at 2J!u9qU,kE=@%*e[N:121263199
DEBUG: Code 3 at 2J!u9qU,kE=@%*e[N:121263199
Launching C:\Program Files (x86)\MakeMKV\mmgplsrv64.exe
003038:0000 Cells 12-12 were removed from title end
003028:0000 Title #1 was added (11 cell(s), 0:43:22)
003038:0000 Cells 11-11 were removed from title end
003028:0000 Title #2 was added (10 cell(s), 0:42:51)
003028:0000 Title #3 was added (10 cell(s), 0:42:28)
003028:0000 Title #4 was added (10 cell(s), 0:43:39)
003038:0000 Cells 22-22 were removed from title end
003028:0000 Title #5 was added (21 cell(s), 1:26:13)
003028:0000 Title #6 was added (20 cell(s), 1:26:07)
003038:0000 Cells 3-3 were removed from title end
003028:0000 Title #7 was added (2 cell(s), 0:04:29)
003025:0000 Title #8 has length of 13 seconds which is less than minimum title length of 30 seconds and was therefore skipped
005014:0000 Saving 4 titles into directory file://[Redacted]/Numb3rs/Season 1
CCX001: Launching C:/Program Files (x86)/CCExtractor/ccxgui.exe
001003:0020 DEBUG: Code 16777216 at Qzy1>KY`*\mM#`{2I'q?Q:29395678
CCX001: flutter: onCreate -- UpdaterBloc
DEBUG: Code 0 at ,}KA*b/JMeLAxi%":213136332
001003:0020 DEBUG: Code 1 at ,}KA*b/JMeLAxi%":121264418
001003:0020 DEBUG: Code 0 at MUklj]%J8Q@ \s=`g8hm:121261773
001003:0020 DEBUG: Code 0 at r*4xP~>k4SvZ3d8pxZ:2I:121268972
---- Failed [Redacted]/Numb3rs/Season 1/Numbers.mkv
ch_0                    0 0
ch_1                    0 0
ch_2                    0 0
ch_3                    0 0
ch_4                    0 0
ch_5                    0 0
ch_6                    0 0
ch_7            540540000 2
mt=0000018396A06E40 n=4
s=0 n=11 o=4683776
    0   7992 000015              0       36036000 0FFA4DE6 000001B32D01E03417ED23821010101210121616161616161A181A1A1A1A1A1A1A1A1A1A1A1C1C1C2222221C1C1C1A1A1C1C2020222224262422222222262628282830302E2E38383A444453080808090909090909090A0A0A0A0A0A0A0A0A0A0A0B0B0B0B0B0B0B0B0B0B0B0B0B0B0B0C0C0C0C0C0C0C0C0D0D0D0D0C0D0D0D
    0    388 000010       36036000       54054000 40EBACFA 000001000057FFFB80000000000001B5844FFB8B80000000000001010A6DA5ACFC3E01018D800000000001020A6C04051B000000000001030A6C04051B000000000001040A6C04051B000000000001050A6C04051B000000000001060A6C04051B000000000001070A6C04051B000000000001080A6C04051B00000000000109
    0    388 000010      126126000       54054000 9E24762D 0000010000D7FFFB80000000000001B5855FFB0B80000000000001010A6DA5CC771D0080C6C00000000001020A6C04051B000000000001030A6C04051B000000000001040A6C04051B000000000001050A6C04051B000000000001060A6C04051B000000000001070A6C04051B000000000001080A6C04051B00000000000109
    0    388 000018       90090000       36036000 93CA4E60 00000100009FFFFBB8000000000001B584444B0980000000000001010A56CE6B98EE3A01018AC000000001020A5602028AC00000000001030A5602028AC00000000001040A5602028AC00000000001050A5602028AC00000000001060A5602028AC00000000001070A5602028AC00000000001080A5602028AC0000000000109
    0    384 000010      216216000       54054000 EDF6DD94 000001000157FFFB80000000000001B5855FFB8B80000000000001010A6C04051B000000000001020A6C04051B000000000001030A6C04051B000000000001040A6C04051B000000000001050A6C04051B000000000001060A6C04051B000000000001070A6C04051B000000000001080A6C04051B000000000001090A6C0405
    0    388 000018      180180000       36036000 E87F1AC6 00000100011FFFFBB8000000000001B584444B8980000000000001010A56CE6BDD5F0F67804062B0000001020A5602028AC00000000001030A5602028AC00000000001040A5602028AC00000000001050A5602028AC00000000001060A5602028AC00000000001070A5602028AC00000000001080A5602028AC0000000000109
    0    388 000010      270270000       36036000 CB09B4D8 000001000197FFFB80000000000001B5844FFB0980000000000001010A6DA5EEAF87B3C02031B000000001020A6C04051B000000000001030A6C04051B000000000001040A6C04051B000000000001050A6C04051B000000000001060A6C04051B000000000001070A6C04051B000000000001080A6C04051B00000000000109
    0    384 000010      396396000       54054000 3F5EAAB8 000001000257FFFB80000000000001B5865FFB8B80000000000001010A6C04051B000000000001020A6C04051B000000000001030A6C04051B000000000001040A6C04051B000000000001050A6C04051B000000000001060A6C04051B000000000001070A6C04051B000000000001080A6C04051B000000000001090A6C0405
    0    388 000018      306306000       54054000 E4E9F497 0000010001DFFFFBB8000000000001B584455B0B80000000000001010A56CE6B8DDC740203158000000001020A5602028AC00000000001030A5602028AC00000000001040A5602028AC00000000001050A5602028AC00000000001060A5602028AC00000000001070A5602028AC00000000001080A5602028AC0000000000109
    0    388 000018      360360000       36036000 259C90B7 00000100021FFFFBB8000000000001B585544B8980000000000001010A56CE6B8DDC740203158000000001020A5602028AC00000000001030A5602028AC00000000001040A5602028AC00000000001050A5602028AC00000000001060A5602028AC00000000001070A5602028AC00000000001080A5602028AC0000000000109
    0   7992 000013      540540000       36036000 EC79FCFA 000001B32D01E03417ED23821010101210121616161616161A181A1A1A1A1A1A1A1A1A1A1A1C1C1C2222221C1C1C1A1A1C1C2020222224262422222222262628282830302E2E38383A444453080808090909090909090A0A0A0A0A0A0A0A0A0A0A0B0B0B0B0B0B0B0B0B0B0B0B0B0B0B0C0C0C0C0C0C0C0C0D0D0D0D0C0D0D0D
s=1 n=1 o=296960
    1   1792 000001              0       34560000 77C83621 0B77174B1E40E1DC41CB807E41FEB2E101042020840410808210102AAF1F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CFBFE757CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CFBFF9D5F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3
s=2 n=1 o=317440
    2    768 000001              0       34560000 D6A96979 0B77540714405371072E0E41E6C5B8404040410808080820AE3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F7FCEAF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F7FF3ABE7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7DE53E2891224000
s=3 n=0 o=0
mt=0000018394E9B7D0 n=4
s=0 n=49 o=4683776
    0    388 000018      450450000       36036000 B1B95438 00000100001FFFFBB8000000000001B584455B0980000000000001010A56CE6B8DDC740203158000000001020A5602028AC00000000001030A5602028AC00000000001040A5602028AC00000000001050A5602028AC00000000001060A5602028AC00000000001070A5602028AC00000000001080A5602028AC0000000000109
    0    384 000018      486486000       54054000 0E4E3F73 00000100005FFFFBB8000000000001B585544B0B80000000000001010A5602028AC00000000001020A5602028AC00000000001030A5602028AC00000000001040A5602028AC00000000001050A5602028AC00000000001060A5602028AC00000000001070A5602028AC00000000001080A5602028AC00000000001090A560202
    0    388 000010      576576000       54054000 FC56F287 0000010000D7FFFB80000000000001B5844FFB8B80000000000001010A6DA5ACFC3E01018D800000000001020A6C04051B000000000001030A6C04051B000000000001040A6C04051B000000000001050A6C04051B000000000001060A6C04051B000000000001070A6C04051B000000000001080A6C04051B00000000000109
    0    388 000010      666666000       54054000 5AE295AA 000001000157FFFB80000000000001B5855FFB0B80000000000001010A6DA5CC771D0080C6C00000000001020A6C04051B000000000001030A6C04051B000000000001040A6C04051B000000000001050A6C04051B000000000001060A6C04051B000000000001070A6C04051B000000000001080A6C04051B00000000000109
    0    384 000018      630630000       36036000 8D34E002 00000100011FFFFBB8000000000001B584444B0980000000000001010A5602028AC00000000001020A5602028AC00000000001030A5602028AC00000000001040A5602028AC00000000001050A5602028AC00000000001060A5602028AC00000000001070A5602028AC00000000001080A5602028AC00000000001090A560202
    0    384 000010      756756000       54054000 320FCD29 0000010001D7FFFB80000000000001B5855FFB8B80000000000001010A6C04051B000000000001020A6C04051B000000000001030A6C04051B000000000001040A6C04051B000000000001050A6C04051B000000000001060A6C04051B000000000001070A6C04051B000000000001080A6C04051B000000000001090A6C0405
    0    388 000018      720720000       36036000 54C244BB 00000100019FFFFBB8000000000001B584444B8980000000000001010A56CE6BDD5F0F67804062B0000001020A5602028AC00000000001030A5602028AC00000000001040A5602028AC00000000001050A5602028AC00000000001060A5602028AC00000000001070A5602028AC00000000001080A5602028AC0000000000109
    0    388 000010      810810000       36036000 4824ECAE 000001000217FFFB80000000000001B5844FFB0980000000000001010A6DA5EEAF87B3C02031B000000001020A6C04051B000000000001030A6C04051B000000000001040A6C04051B000000000001050A6C04051B000000000001060A6C04051B000000000001070A6C04051B000000000001080A6C04051B00000000000109
    0    384 000010      936936000       54054000 E0A7BA05 0000010002D7FFFB80000000000001B5865FFB8B80000000000001010A6C04051B000000000001020A6C04051B000000000001030A6C04051B000000000001040A6C04051B000000000001050A6C04051B000000000001060A6C04051B000000000001070A6C04051B000000000001080A6C04051B000000000001090A6C0405
    0    384 000018      846846000       54054000 FF3ED636 00000100025FFFFBB8000000000001B584455B0B80000000000001010A5602028AC00000000001020A5602028AC00000000001030A5602028AC00000000001040A5602028AC00000000001050A5602028AC00000000001060A5602028AC00000000001070A5602028AC00000000001080A5602028AC00000000001090A560202
    0    388 000018      900900000       36036000 9921CECA 00000100029FFFFBB8000000000001B585544B8980000000000001010A56CE6B8DDC740203158000000001020A5602028AC00000000001030A5602028AC00000000001040A5602028AC00000000001050A5602028AC00000000001060A5602028AC00000000001070A5602028AC00000000001080A5602028AC0000000000109
    0   7992 000011     1081080000       36036000 7E99817F 000001B32D01E03417ED23821010101210121616161616161A181A1A1A1A1A1A1A1A1A1A1A1C1C1C2222221C1C1C1A1A1C1C2020222224262422222222262628282830302E2E38383A444453080808090909090909090A0A0A0A0A0A0A0A0A0A0A0B0B0B0B0B0B0B0B0B0B0B0B0B0B0B0C0C0C0C0C0C0C0C0D0D0D0D0C0D0D0D
    0    388 000018      990990000       36036000 B1B95438 00000100001FFFFBB8000000000001B584455B0980000000000001010A56CE6B8DDC740203158000000001020A5602028AC00000000001030A5602028AC00000000001040A5602028AC00000000001050A5602028AC00000000001060A5602028AC00000000001070A5602028AC00000000001080A5602028AC0000000000109
    0    384 000018     1027026000       54054000 0E4E3F73 00000100005FFFFBB8000000000001B585544B0B80000000000001010A5602028AC00000000001020A5602028AC00000000001030A5602028AC00000000001040A5602028AC00000000001050A5602028AC00000000001060A5602028AC00000000001070A5602028AC00000000001080A5602028AC00000000001090A560202
    0    388 000010     1117116000       54054000 82A0F4DD 0000010000D7FFFB80000000000001B5844FFB8B80000000000001010A6DA5A8D1D0080C6C000000000001020A6C04051B000000000001030A6C04051B000000000001040A6C04051B000000000001050A6C04051B000000000001060A6C04051B000000000001070A6C04051B000000000001080A6C04051B00000000000109
    0    956 000010     1207206000       54054000 65E6870B 000001000157FFFB80000000000001B5855FFB0B80000000000001010A6DA58593E01018D8000000000001020A6C04051B000000000001030A6C04051B000000000001040A6C04051B000000000001050A6C04051B000000000001060A6C04051B000000000001070A6C2C6FE1FB758103F28103F181000A810011801011400C
    0    388 000018     1171170000       36036000 6ACFBBC7 00000100011FFFFBB8000000000001B584444B0980000000000001010A56CE6B0B27C02031580000000001020A5602028AC00000000001030A5602028AC00000000001040A5602028AC00000000001050A5602028AC00000000001060A5602028AC00000000001070A5602028AC00000000001080A5602028AC0000000000109
    0   1980 000010     1297296000       54054000 23C7A784 0000010001D7FFFB80000000000001B5855FFB8B80000000000001010A6DA58593E01018D8000000000001020A6C04051B000000000001030A6C04051B000000000001040A6C04051B000000000001050A6C04051B000000000001060A6C04051B000000000001070A6C2D440190027004E00D800C001C006A00BC015803F018
    0    976 000018     1261260000       36036000 36A17BB4 00000100019FFFFBB8000000000001B584444B8980000000000001010A56CE6B0B27C02031580000000001020A5602028AC00000000001030A5602028AC00000000001040A5602028AC00000000001050A5602028AC00000000001060A5602028AC00000000001070A5616E7128B2D08474A7B232BA9606C2C81200A7E801086
    0   2232 000010     1351350000       36036000 94849053 000001000217FFFB80000000000001B5844FFB0980000000000001010A6DA58593E01018D8000000000001020A6C04051B000000000001030A6C04051B000000000001040A6C04051B000000000001050A6C04051B000000000001060A6C04051B000000000001070A6C2D4434984C486F18847EDBFFB19B1E9E73652D2E072C
    0   4276 000010     1477476000       54054000 5E47F7DA 0000010002D7FFFB80000000000001B5865FFB8B80000000000001010A6DA58593E01018D8000000000001020A6C04051B000000000001030A6C04051B000000000001040A6C04051B000000000001050A6C04051B000000000001060A6C04051B000000000001070A6C2F2C22019003B0072019003801000C401F803D013930
    0   2008 000018     1387386000       54054000 81630DB4 00000100025FFFFBB8000000000001B584455B0B80000000000001010A56CE6B0B27C02031580000000001020A5602028AC00000000001030A5602028AC00000000001040A5602028AC00000000001050A5602028AC00000000001060A5602028AC00000000001070A5617CF892CBC8C353F6CFD6E249E01EC536E4340D464E2
    0   2504 000018     1441440000       36036000 414FB9B0 00000100029FFFFBB8000000000001B585544B8980000000000001010A56CE6B0B27C02031580000000001020A5602028AC00000000001030A5602028AC00000000001040A5602028AC00000000001050A5602028AC00000000001060A5602028AC00000000001070A5617CF897B252ED9DB7FFB9827914507D90DC0C20310AC
    0  14504 000011     1621620000       36036000 AA5885BC 000001B32D01E03417ED23821010101210121616161616161A181A1A1A1A1A1A1A1A1A1A1A1C1C1C2222221C1C1C1A1A1C1C2020222224262422222222262628282830302E2E38383A444453080808090909090909090A0A0A0A0A0A0A0A0A0A0A0B0B0B0B0B0B0B0B0B0B0B0B0B0B0B0C0C0C0C0C0C0C0C0D0D0D0D0C0D0D0D
    0   3816 000018     1531530000       36036000 F4C30614 00000100001FFFFBB8000000000001B584455B0980000000000001010A56CE6B0B27C02031580000000001020A5602028AC00000000001030A5602028AC00000000001040A5602028AC00000000001050A5602028AC00000000001060A5602028AC00000000001070A5617CF88D2D056C37ECBDB7F8FFD5B0BE01ED646E43292
    0   3568 000018     1567566000       54054000 1D3304B8 00000100005FFFFBB8000000000001B585544B0B80000000000001010A56CE6B0B27C02031580000000001020A5602028AC00000000001030A5602028AC00000000001040A5602028AC00000000001050A5602028AC00000000001060A5602028AC00000000001070A5617CF886A1094FC8467EBEB22800E60D0DEC03AC8415F
    0   4540 000010     1657656000       54054000 CF4D6CE0 0000010000D7FFFB80000000000001B5844FFB8B80000000000001010A6C04051B000000000001020A6C04051B000000000001030A6C04051B000000000001040A6C04051B000000000001050A6C04051B000000000001060A6C04051B000000000001070A6C2D45391D3F21197CE51A0708C299E0C010968C020C4219F96019
    0   4864 000010     1747746000       54054000 E9B555F0 000001000157FFFB80000000000001B5855FFB0B80000000000001010A6C04051B000000000001020A6C04051B000000000001030A6C04051B000000000001040A6C04051B000000000001050A6C04051B000000000001060A6C04051B000000000001070A6C2D449A4C210690CB4060623965FFDB6C78F7739B2D293B2F98FA
    0   2768 000018     1711710000       36036000 18DF2D20 00000100011FFFFBB8000000000001B584444B0980000000000001010A5602028AC00000000001020A5602028AC00000000001030A5602028AC00000000001040A5602028AC00000000001050A5602028AC00000000001060A5602028AC00000000001070A5617CF8A5BA7B6DFFFDB6680764C4A119291BF719F33114C14FCE5
    0   4660 000010     1837836000       54054000 C3FB9427 0000010001D7FFFB80000000000001B5855FFB8B80000000000001010A6C04051B000000000001020A6C04051B000000000001030A6C04051B000000000001040A6C04051B000000000001050A6C04051B000000000001060A6C04051B000000000001070A6C2D443484420D02A1A826130AE5965FF8A4610E3C918F59C83FED
    0   2984 000018     1801800000       36036000 BD6BE70D 00000100019FFFFBB8000000000001B584444B8980000000000001010A5602028AC00000000001020A5602028AC00000000001030A5602028AC00000000001040A5602028AC00000000001050A5602028AC00000000001060A5602028AC00000000001070A5617DF8A5BE19FEFB7F91D3B00F1C0398B6ED93B3EFFE020C1E034
    0   3424 000010     1891890000       36036000 1502AAAC 000001000217FFFB80000000000001B5844FFB0980000000000001010A6C04051B000000000001020A6C04051B000000000001030A6C04051B000000000001040A6C04051B000000000001050A6C04051B000000000001060A6C04051B000000000001070A6C2D452521294A10847E9EDB6C7859CA58DFD918F8349A4D490803
    0   4744 000010     2018016000       54054000 79D0C80D 0000010002D7FFFB80000000000001B5865FFB8B80000000000001010A6C04051B000000000001020A6C04051B000000000001030A6C04051B000000000001040A6C04051B000000000001050A6C04051B000000000001060A6C04051B000000000001070A6C2F2C2242013808404C0202113406202702A4C01D00E884189269
    0   2264 000018     1927926000       54054000 97FF85BD 00000100025FFFFBB8000000000001B584455B0B80000000000001010A5602028AC00000000001020A5602028AC00000000001030A5602028AC00000000001040A5602028AC00000000001050A5602028AC00000000001060A5602028AC00000000001070A5617CF8A57B0FCBE7C33805218CCC4CC926F16621C7E73D180DDE7
    0   2396 000018     1981980000       36036000 313FFDD6 00000100029FFFFBB8000000000001B585544B8980000000000001010A5602028AC00000000001020A5602028AC00000000001030A5602028AC00000000001040A5602028AC00000000001050A5602028AC00000000001060A5602028AC00000000001070A5617CF89684253F2108E9FDFED8563C0393E49346E01D24945F0C2
    0  16780 000011     2162160000       36036000 5D098FA0 000001B32D01E03417ED23821010101210121616161616161A181A1A1A1A1A1A1A1A1A1A1A1C1C1C2222221C1C1C1A1A1C1C2020222224262422222222262628282830302E2E38383A444453080808090909090909090A0A0A0A0A0A0A0A0A0A0A0B0B0B0B0B0B0B0B0B0B0B0B0B0B0B0C0C0C0C0C0C0C0C0D0D0D0D0C0D0D0D
    0   3016 000018     2072070000       36036000 B56FDF1E 00000100001FFFFBB8000000000001B584455B0980000000000001010A5602028AC00000000001020A5602028AC00000000001030A5602028AC00000000001040A5602028AC00000000001050A5602028AC00000000001060A5602028AC00000000001070A5617CF8A7FC8CE9EDB2FFEAB40614586A306E74210586FCE039252
    0   2956 000018     2108106000       54054000 5ACDEFD4 00000100005FFFFBB8000000000001B585544B0B80000000000001010A5602028AC00000000001020A5602028AC00000000001030A5602028AC00000000001040A5602028AC00000000001050A5602028AC00000000001060A5602028AC00000000001070A5617CF8978FD87C064620989FD2DD2593099BE3C24938739E03FBC
    0   3580 000010     2198196000       54054000 2A69F0ED 0000010000D7FFFB80000000000001B5844FFB8B80000000000001010A6C04051B000000000001020A6C04051B000000000001030A6C04051B000000000001040A6C04051B000000000001050A6C04051B000000000001060A6C04051B000000000001070A6C2D44BC84A5284237FFF66DB9BC700B57B586F494026269684EC5
    0   4416 000010     2288286000       54054000 48A461FA 000001000157FFFB80000000000001B5855FFB0B80000000000001010A6C04051B000000000001020A6C04051B000000000001030A6C04051B000000000001040A6C04051B000000000001050A6C04051B000000000001060A6C04051B000000000001070A6C2D45251492D284211D25A7EC846C7800F2C042586814006000EC
    0   2712 000018     2252250000       36036000 379F3CBF 00000100011FFFFBB8000000000001B584444B0980000000000001010A5602028AC00000000001020A5602028AC00000000001030A5602028AC00000000001040A5602028AC00000000001050A5602028AC00000000001060A5602028AC00000000001070A5617DF8A568CFDBBFDB2C781C0357F2761ADD4A0160B0B1579FD23
    0   4280 000010     2378376000       54054000 BFC2A0D5 0000010001D7FFFB80000000000001B5855FFB8B80000000000001010A6C04051B000000000001020A6C04051B000000000001030A6C04051B000000000001040A6C04051B000000000001050A6C04051B000000000001060A6C04051B000000000001070A6C2D44B0C28B26A5051484A529EC84233969FD4C801A44301D8680
    0   2884 000018     2342340000       36036000 DD9658F1 00000100019FFFFBB8000000000001B584444B8980000000000001010A5602028AC00000000001020A5602028AC00000000001030A5602028AC00000000001040A5602028AC00000000001050A5602028AC00000000001060A5602028AC00000000001070A5617CF8A764A52331E766DC500CAD2F9BE776DB7C38D34007D79FF
    0   3068 000010     2432430000       36036000 D1DB95A8 000001000217FFFB80000000000001B5844FFB0980000000000001010A6C04051B000000000001020A6C04051B000000000001030A6C04051B000000000001040A6C04051B000000000001050A6C04051B000000000001060A6C04051B000000000001070A6C2D452828B2CB40614874A7E291B603E3980E0B8B496593004C02
    0  10972 000010     2558556000       54054000 0937A3E9 0000010002D7FFFB80000000000001B5865FFB8B80000000000001010A6C04051B000000000001020A6C04051B000000000001030A6C04051B000000000001040A6C04051B000000000001050A6C125A16F0D605BC0B1B00000001060A6C1D59E607CD688AAEEFB297EAB6734F15559EA1C6D56E2AA6B0BADDDC57FAB32D87F7
    0   2596 000018     2468466000       54054000 42BB8838 00000100025FFFFBB8000000000001B584455B0B80000000000001010A5602028AC00000000001020A5602028AC00000000001030A5602028AC00000000001040A5602028AC00000000001050A5602028AC00000000001060A5602028AC00000000001070A5617CF8FDC279E691405C7C03101D1482686945273A13FF2C11C01
    0   2776 000018     2522520000       36036000 17EB7741 00000100029FFFFBB8000000000001B585544B8980000000000001010A5602028AC00000000001020A5602028AC00000000001030A5602028AC00000000001040A5602028AC00000000001050A5602028AC00000000001060A5602028AC00000000001070A5617CF8A72129FF211D3CCDB030FFFC43C5A4A292940D74F413374
    0  23448 000011     2702700000       36036000 46EB5DDF 000001B32D01E03417ED23821010101210121616161616161A181A1A1A1A1A1A1A1A1A1A1A1C1C1C2222221C1C1C1A1A1C1C2020222224262422222222262628282830302E2E38383A444453080808090909090909090A0A0A0A0A0A0A0A0A0A0A0B0B0B0B0B0B0B0B0B0B0B0B0B0B0B0C0C0C0C0C0C0C0C0D0D0D0D0C0D0D0D
    0   6140 000018     2612610000       36036000 F64037FC 00000100001FFFFBB8000000000001B584455B0980000000000001010A5602028AC00000000001020A5602028AC00000000001030A5602028AC00000000001040A5602028AC00000000001050A561CE7A3CF50E88E78CA16260739E05BC0B158000001060A560E73B828F91CEFCDFAD5A473B7154E6730B97FF6E6657A73A224
s=1 n=0 o=296960
s=2 n=0 o=317440
s=3 n=0 o=0
mt=0000018396A022C0 n=4
s=0 n=1 o=4683776
    0   6944 000018     2648646000       54054000 687FE462 00000100005FFFFBB8000000000001B585544B0B80000000000001010A5602028AC00000000001020A5602028AC00000000001030A5602028AC00000000001040A5602028AC00000000001050A561CE7A3CF50E88E78C2FBC1273C83FCCE7816F02C5600000001060A560E738C147D6EE67C27539F79A40D15C2A9C5739E9CE7
s=1 n=49 o=296960
    1   1792 002001       34560000       34560000 BF8F3395 0B77174B1E40E1DC41CB807E41FEB2E101042020840410808210102AAF1F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CFBFE757CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CFBFF9D5F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3
    1   1792 002001       69120000       34560000 9B5AB3E0 0B77174B1E40E1DC41CB807E41FEB2E101042020840410808210102AAF1F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CFBFE757CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CFBFF9D5F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3
    1   1792 002001      103680000       34560000 A5A1BE7E 0B77174B1E40E1DC41CB807E41FEB2E101042020840410808210102AAF1F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CFBFE757CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CFBFF9D5F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3
    1   1792 002001      138240000       34560000 BB343FBD 0B77174B1E40E1DC41CB807E41FEB2E101042020840410808210102AAF1F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CFBFE757CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CFBFF9D5F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3
    1   1792 002001      172800000       34560000 2C9CE6A3 0B77174B1E40E1DC41CB807E41FEB2E101042020840410808210102AAF1F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CFBFE757CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CFBFF9D5F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3
    1   1792 002001      207360000       34560000 D6BA41F7 0B77174B1E40E1DC41CB807E41FEB2E101042020840410808210102AAF1F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CFBFE757CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CFBFF9D5F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3
    1   1792 002001      241920000       34560000 C0B860A0 0B77174B1E40E1DC41CB807E41FEB2E101042020840410808210102AAF1F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CFBFE757CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CFBFF9D5F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3
    1   1792 002001      276480000       34560000 DEA02449 0B77174B1E40E1DC41CB807E41FEB2E101042020840410808210102AAF1F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CFBFE757CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CFBFF9D5F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3
    1   1792 002001      311040000       34560000 C98711E2 0B77174B1E40E1DC41CB807E41FEB2E101042020840410808210102AAF1F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CFBFE757CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CFBFF9D5F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3
    1   1792 002001      345600000       34560000 571C3F6C 0B77174B1E40E1DC41CB807E41FEB2E101042020840410808210102AAF1F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CFBFE757CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CFBFF9D5F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3
    1   1792 002001      380160000       34560000 7F916FA2 0B77174B1E40E1DC41CB807E41FEB2E101042020840410808210102AAF1F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CFBFE757CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CFBFF9D5F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3
    1   1792 002001      414720000       34560000 D249CCB2 0B77174B1E40E1DC41CB807E41FEB2E101042020840410808210102AAF1F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CFBFE757CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CFBFF9D5F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3
    1   1792 002001      449280000       34560000 2808DD7E 0B77174B1E40E1DC41CB807E41FEB2E101042020840410808210102AAF1F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CFBFE757CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CFBFF9D5F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3
    1   1792 002001      483840000       34560000 7131CF76 0B77174B1E40E1DC41CB807E41FEB2E101042020840410808210102AAF1F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CFBFE757CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CFBFF9D5F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3
    1   1792 002001      518400000       34560000 74C91F77 0B77174B1E40E1DC41CB807E41FEB2E101042020840410808210102AAF1F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CFBFE757CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CFBFF9D5F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3
    1   1792 002001      552960000       34560000 4F3EF47C 0B77174B1E40E1DC41CB807E41FEB2E101042020840410808210102AAF1F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CFBFE757CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CFBFF9D5F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3
    1   1792 002001      587520000       34560000 EA32CBC5 0B77174B1E40E1DC41CB807E41FEB2E101042020840410808210102AAF1F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CFBFE757CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CFBFF9D5F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3
    1   1792 002001      622080000       34560000 3DBB9372 0B77174B1E40E1DC41CB807E41FEB2E101042020840410808210102AAF1F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CFBFE757CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CFBFF9D5F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3
    1   1792 002001      656640000       34560000 49B9C517 0B77174B1E40E1DC41CB807E41FEB2E101042020840410808210102AAF1F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CFBFE757CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CFBFF9D5F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3
    1   1792 002001      691200000       34560000 F3A0D1EA 0B77174B1E40E1DC41CB807E41FEB2E101042020840410808210102AAF1F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CFBFE757CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CFBFF9D5F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3
    1   1792 002001      725760000       34560000 CF31257C 0B77174B1E40E1DC41CB807E41FEB2E101042020840410808210102AAF1F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CFBFE757CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CFBFF9D5F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3
    1   1792 002001      760320000       34560000 41EB21C4 0B77174B1E40E1DC41CB807E41FEB2E101042020840410808210102AAF1F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CFBFE757CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CFBFF9D5F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3
    1   1792 002001      794880000       34560000 DA8527D4 0B77174B1E40E1DC41CB807E41FEB2E101042020840410808210102AAF1F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CFBFE757CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CFBFF9D5F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3
    1   1792 002001      829440000       34560000 2F55040B 0B77174B1E40E1DC41CB807E41FEB2E101042020840410808210102AAF1F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CFBFE757CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CFBFF9D5F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3
    1   1792 002001      864000000       34560000 EAD9C63A 0B77174B1E40E1DC41CB807E41FEB2E101042020840410808210102AAF1F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CFBFE757CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CFBFF9D5F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3
    1   1792 002001      898560000       34560000 D3C96635 0B77174B1E40E1DC41CB807E41FEB2E101042020840410808210102AAF1F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CFBFE757CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CFBFF9D5F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3
    1   1792 002001      933120000       34560000 7093DDBD 0B77174B1E40E1DC41CB807E41FEB2E101042020840410808210102AAF1F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CFBFE757CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CFBFF9D5F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3
    1   1792 002001      967680000       34560000 24147D5C 0B77174B1E40E1DC41CB807E41FEB2E101042020840410808210102AAF1F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CFBFE757CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CFBFF9D5F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3
    1   1792 002001     1002240000       34560000 EF2753F4 0B77174B1E40E1DC41CB807E41FEB2E101042020840410808210102AAF1F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CFBFE757CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CFBFF9D5F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3
    1   1792 002001     1036800000       34560000 7C4FFA1A 0B77CD551E40E1DC41CB807E41FEB2E101042020840410808210102AAF1F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CFBFE757CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CFBFF9D5F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3
    1   1792 002001     1071360000       34560000 6B9D1B67 0B7796DE1E40E1DC41CB807E41FEB2E8C015121FA243D45446840B352ED4BA2CE46EBD54A956A4BD2C354E5FDD7CFBFE75535ABBA7CE6BBE7CF9F3E7CF953A7B5DD3E4CF94D7FFE757CF9F3DAEF9D3A7CF5F577CF9F3E7CF6BBE74F9312FFE757CF9CD37B5DF3E7CE9F3E735DED77CF9F2A7CA9F3EFFE2EAD9DF39B6F7542BA2
    1   1792 002001     1105920000       34560000 057DEB77 0B775B411E40E1DC1DCB807E41FEB2E82825102BA04094404689082AAE865254B9D3A8509F3F495ABC34AF9F45C0BB7DDAB6FB3A17D477BE555D2C2AEA6956CCF9FB9A4F69704C8926B83AE75676A9CBF4AFCB3A42F953E4EA695748FBFB2F9FB9AEFA1A5554A1B9A55D5218649F3E535A96B530C9358696BA67B4A94374E952
    1   1792 002001     1140480000       34560000 6F50707F 0B77A5C81E40E1DFF1CB807E05FEB2E8384D002EA343F484A29F135EAE842084FE1427B5E1FB2F72B6C07D61FA9A35A9B94C6E2B8994E7836DDA57CA86BECF8D87F4A45B7EFA956AF5EB5686FA1428EA9FA9B55DF3E7CF9F3F4B4D52586A5F3EA4FD2BE8695FA97EA601141A9FF55A1BDAD5A93EDEA61AA54E9329B54A9482AF
    1   1792 002001     1175040000       34560000 D5184105 0B77AF081E40E1DFEDCB807FF1FEB2E9E0ED0F08A703351892A211BB4E462F50CFB3E7CB9F3EA692DDB4E95358E961317AE162DAB9B1DD3DB231598B4347D90EA297D4D29FF346C267D5B839575DCBB554D2D7A34D53E54F933A4CE5FB98EF92D1B6FA1917D49D42839CAB97642E88A6E567D0D591A559D3E7EA614EB695D3F2
    1   1792 002001     1209600000       34560000 4E281B18 0B7788391E40E1DFEDCB807FEDFEB2E9E8DD0F07A723D5109AA212BBAE442A9C6EED274AC9297D09FB9A55D344E97118FCEC9AC39A549D567E45F18F435C8F21F444AF5F38C2992C37EFEBBE5E95F56855DD3D7D5A9A586E2E3DA4FD339A50DABF735A93E536DF3E7D9E3F8FE1EBAEFCABE7EF88C27FD42A4F9F42850A953734
    1   1792 002001     1244160000       34560000 F87C3AE5 0B77D01D1E40E1DFEDCB807FEDFEB2E9D8CD0F09A7A3551092A2122AAE483E7AD2EBEA509F3E5559FA97D49FD8EAA8BB5CAF5AF3E87506577DC14D77D1ABD322F9F3E7CFA1AA4B4D2C2569693EA4FD2BE7EA92BEA4F953F496D4D6A4FCCA02ECA9E35A3AA7AF9C5CAD110BAB90DF427DAD33E7CF9F1586E9ED2A36EB444AA92B
    1   1792 002001     1278720000       34560000 D0544572 0B777D4E1E40E1DFEDCB807FEDFEB2E9D8DD0F08A7A3750C8EA192AAAE15A584CF8A9AF0D32A4B59FBDAEF94DDC2F8B175850E056D8FABBE871DD467B61F2A7B5A356E71A9574C95F3F5C95F534161E57A695FA5A49A0C2AD0DCDB7B58B7A1EC438562BBDACF9C5C854A9AED95DF54495A93F7AFDF29755DF25AD5A9674AF9F5
    1   1792 002001     1313280000       34560000 ACA31911 0B772F831E40E1DFEDCB807FEDFEB2E9E0DD0F08A763951092A19232AE45BF9C7BBBA7299F3ED54AB577CA94DEDFB4B1E1B973771755DED77CFA94686A69A5D6A6B3DB8854DA2E887D10EC4E8891F25CCFE93E7EFD7D2B746DD2854D2D27EE94C352FAB534CE9AD34CA9EBE7CF6BBA54FDC5754AB2C772943B2FD33F7EF695B7
    1   1792 002001     1347840000       34560000 7CA04F3B 0B7708F01E40E1DFEDCB807FEDFEB2E9E0ED0F08A7A3350C92A112AEAE4629B02B85C72FAB51AF0D32A4B4DF57EBC0F1714AFE2AA7EFE13A80F9D267D4AB5774E953E85497BA4AFA942ACFD24452FA9429B5D5A57D4DD299D49D3DAEF9B09EA6C3F4FA93E7B46FD6859E2AF0EC3F88EA95B7CFE13EDF0A1A6A4FC8C286992C2A
    1   1792 002001     1382400000       34560000 B8D7EBC7 0B7757D51E40E1DFEDCB807FEDFEB2E9E8ED0F07A7E3751C96A393AEAE503E7E2B0BF4AFD33E4B0DF3E54A9544C2F8F1587D21DD7809953A7DD152A73B133E54FA942AEA92BF4CE693F4AFA93EA4F5F5754F9D3EA6E21AA7CE9FA48895909B15D6E44E35C54B9CD6B51E1ECA57C57D1E9A5D75E1A9AEFD592430A93E86A953D8
    1   1792 002001     1416960000       34560000 DA304488 0B77343B1E40E1DFEDCB807FEDFEB2E920ED0F06A423D52CA2A592AAAE43EB7CDFAC67D4D2D7530A15755A9EE28F5CF15C85115D86CFDFCDAD0ADBED6AD4D6A70DCBA7E9693E835E9B97CF9FA8A6A9F3F4AFA1B4AEF9D3E7D4A95254A9B361D5C2A76DF3E4C968BEB4FA943855ADD35B4E1BA4EA9F5776E6AF07CFD4BE86E95C
    1   1792 002001     1451520000       34560000 E96041DE 0B77E2FF1E40E1DFEDCB807FEDFEB2E908E50F06A403D51C96A393AAAE152A7C1F85B84F9F3F730D33E4E3675CF2FD24E07D0E25B88E9F3F550C8C354BDEC356937B9B6FD32A72F9F427D09F2A5695FB97CFD4BDAF09F3E7EA2BBE8041B0E7D7D2A74E1517EF9D4D7C957AA7D4ABDB7B5E93EAF11CBE7E9953F4BADF40414E14
    1   1792 002001     1486080000       34560000 096D8C1F 0B7787911E40E1DFEDCB807FEDFEB2E9F8DD0F07A7E3B5288EA4922AAE4E3F4222BC374B9F3E7E961AA4B5DD4990F8E4F57D615D7B099FA5AF19F3F54A9F437B6DF3E7CF96D7AD09F4E7CF61BF22AD2D27CF9F3D8749F534C888BDB748B0C8243E7CFAE3E6A45FB47E992C2AF5DFBE769A8A6AF51F29AF0953E80AD23F7D0AAC
    1   1792 002001     1520640000       34560000 7298DB48 0B77DEA61E40E1DFEDCB807FEDFEB2E9E8ED0F07A7E3751C96A392AECE484284230527CF9FA5AEE9CD686F61C4E15D24DC7EEA4DAA89DEC6AF5ABBE850DF3F496E93E7D49ED6D75A13986FD3218692BE65695F3E76A92577D49F518E99909850BEE15F853869A0D4499C9BAFDF457D11CC9410EDBE7CFDF9184F9F4283B46A98
    1   1792 002001     1555200000       34560000 2095A75F 0B77113D1E40E1DFEDCB807FEDFEB2E9F8E50F08A763750C8EA2922AAE523E741FA677BAE1302109FAE4AFD2E1EB0CB175B55ECBF7EE9FBE855DB574CE9F9242FA952AD108BDA699A3F7CA9FB9850D25824995297E956D37CFA8D7A548C36E5FE69139FA57B0A1535506DC3B0AAB6AE0AD242DEEA0D854F9CD67D49F2AA4FD32
    1   1792 002001     1589760000       34560000 7541C816 0B77A3621E40E1DFEDCB807FEDFEB2E9E0B50F0AA763351482A2112ACE46265AD38BA54F9D2A7E8693F535A15DF2A8EF5CAEFAEEB54FDFA9AF716C37B0DEEBA549F3E7CA9F3F4B36E257CA9CEB84B9F534B0123DB70CA5822A9ED752FDB48229BEAF5913E54F9F3EB8E92595EFE9427CFD1218092BAA76429BDA50A1BEA35D3A
    1   1792 002001     1624320000       34560000 2492F396 0B77F2431E40E1DFEDCB807FEDFEB2E9D0D50F08A72375108EA2112AAE13274A1EEAA7E992BE7646B582AE92F2E0F8FB70AEBAED37EFD525AF6DF3F4CA9FA98499D534CA5F3E7B4DFA9A54D2C018FDEBEA50A13E555D2D254F9EBF7B4DC4681FD787090AA84838A6A4F6DAA916294E75007BEA6A9F3E7E460D848FEB437CAD4B
    1   1792 002001     1658880000       34560000 608BD1EC 0B772F881E40E1DFEDCB807FEDFEB2E9E0FD0F07A7E3751C8EA2922EAE443E9AD38D254A9F3E7D59F43730DD49E098F1EC7EAA1EFB14A1D343712D67B5EBB9B858B257CFDCD1889614274A95A57CF9EEC7B09F3E7D5D2C2549A74254A9B05C1DBFB8FA3537EA95AA4C9E2E2F95C555008D3A4FADCF54FD5264AFDF26849953D7
    1   1792 002001     1693440000       34560000 5AC280C5 0B77CBE21E40E1DFEDCB807FEDFEB2E900FD0F05A783F5209EA412AAAE153E846F8D27CF9F537B5ABBD7EE9F45B8FCF1617CFB05886FE93E7F492DB54FA1AA7E95D3F7349F3AAE99D21882EBBE7CB9F3ECBB126C2359FB954F9F29AF0DB3E22E3A4D50FC049ADCD65359FBA855E4257E96E26A6F9CC3CEF9F437CFABA486FD61
s=2 n=51 o=317440
    2    768 002001       34560000       34560000 D6A96979 0B77540714405371072E0E41E6C5B8404040410808080820AE3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F7FCEAF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F7FF3ABE7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7DE53E2891224000
    2    768 002001       69120000       34560000 D6A96979 0B77540714405371072E0E41E6C5B8404040410808080820AE3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F7FCEAF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F7FF3ABE7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7DE53E2891224000
    2    768 002001      103680000       34560000 D6A96979 0B77540714405371072E0E41E6C5B8404040410808080820AE3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F7FCEAF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F7FF3ABE7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7DE53E2891224000
    2    768 002001      138240000       34560000 D6A96979 0B77540714405371072E0E41E6C5B8404040410808080820AE3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F7FCEAF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F7FF3ABE7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7DE53E2891224000
    2    768 002001      172800000       34560000 D6A96979 0B77540714405371072E0E41E6C5B8404040410808080820AE3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F7FCEAF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F7FF3ABE7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7DE53E2891224000
    2    768 002001      207360000       34560000 D6A96979 0B77540714405371072E0E41E6C5B8404040410808080820AE3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F7FCEAF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F7FF3ABE7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7DE53E2891224000
    2    768 002001      241920000       34560000 D6A96979 0B77540714405371072E0E41E6C5B8404040410808080820AE3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F7FCEAF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F7FF3ABE7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7DE53E2891224000
    2    768 002001      276480000       34560000 D6A96979 0B77540714405371072E0E41E6C5B8404040410808080820AE3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F7FCEAF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F7FF3ABE7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7DE53E2891224000
    2    768 002001      311040000       34560000 D6A96979 0B77540714405371072E0E41E6C5B8404040410808080820AE3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F7FCEAF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F7FF3ABE7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7DE53E2891224000
    2    768 002001      345600000       34560000 D6A96979 0B77540714405371072E0E41E6C5B8404040410808080820AE3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F7FCEAF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F7FF3ABE7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7DE53E2891224000
    2    768 002001      380160000       34560000 D6A96979 0B77540714405371072E0E41E6C5B8404040410808080820AE3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F7FCEAF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F7FF3ABE7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7DE53E2891224000
    2    768 002001      414720000       34560000 D6A96979 0B77540714405371072E0E41E6C5B8404040410808080820AE3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F7FCEAF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F7FF3ABE7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7DE53E2891224000
    2    768 002001      449280000       34560000 D6A96979 0B77540714405371072E0E41E6C5B8404040410808080820AE3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F7FCEAF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F7FF3ABE7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7DE53E2891224000
    2    768 002001      483840000       34560000 D6A96979 0B77540714405371072E0E41E6C5B8404040410808080820AE3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F7FCEAF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F7FF3ABE7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7DE53E2891224000
    2    768 002001      518400000       34560000 D6A96979 0B77540714405371072E0E41E6C5B8404040410808080820AE3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F7FCEAF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F7FF3ABE7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7DE53E2891224000
    2    768 002001      552960000       34560000 D6A96979 0B77540714405371072E0E41E6C5B8404040410808080820AE3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F7FCEAF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F7FF3ABE7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7DE53E2891224000
    2    768 002001      587520000       34560000 D6A96979 0B77540714405371072E0E41E6C5B8404040410808080820AE3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F7FCEAF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F7FF3ABE7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7DE53E2891224000
    2    768 002001      622080000       34560000 D6A96979 0B77540714405371072E0E41E6C5B8404040410808080820AE3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F7FCEAF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F7FF3ABE7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7DE53E2891224000
    2    768 002001      656640000       34560000 D6A96979 0B77540714405371072E0E41E6C5B8404040410808080820AE3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F7FCEAF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F7FF3ABE7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7DE53E2891224000
    2    768 002001      691200000       34560000 D6A96979 0B77540714405371072E0E41E6C5B8404040410808080820AE3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F7FCEAF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F7FF3ABE7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7DE53E2891224000
    2    768 002001      725760000       34560000 D6A96979 0B77540714405371072E0E41E6C5B8404040410808080820AE3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F7FCEAF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F7FF3ABE7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7DE53E2891224000
    2    768 002001      760320000       34560000 D6A96979 0B77540714405371072E0E41E6C5B8404040410808080820AE3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F7FCEAF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F7FF3ABE7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7DE53E2891224000
    2    768 002001      794880000       34560000 D6A96979 0B77540714405371072E0E41E6C5B8404040410808080820AE3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F7FCEAF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F7FF3ABE7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7DE53E2891224000
    2    768 002001      829440000       34560000 D6A96979 0B77540714405371072E0E41E6C5B8404040410808080820AE3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F7FCEAF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F7FF3ABE7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7DE53E2891224000
    2    768 002001      864000000       34560000 D6A96979 0B77540714405371072E0E41E6C5B8404040410808080820AE3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F7FCEAF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F7FF3ABE7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7DE53E2891224000
    2    768 002001      898560000       34560000 D6A96979 0B77540714405371072E0E41E6C5B8404040410808080820AE3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F7FCEAF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F7FF3ABE7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7DE53E2891224000
    2    768 002001      933120000       34560000 D6A96979 0B77540714405371072E0E41E6C5B8404040410808080820AE3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F7FCEAF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F7FF3ABE7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7DE53E2891224000
    2    768 002001      967680000       34560000 D6A96979 0B77540714405371072E0E41E6C5B8404040410808080820AE3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F7FCEAF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F7FF3ABE7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7DE53E2891224000
    2    768 002001     1002240000       34560000 D6A96979 0B77540714405371072E0E41E6C5B8404040410808080820AE3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F7FCEAF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F7FF3ABE7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7DE53E2891224000
    2    768 002001     1036800000       34560000 6505AEB2 0B77673114405371072E0E41E6C5BA0A080C0D41C20181A0AE3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F7FBB2A49AAAD5DF3E7B0D53E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F7FEECA94F5DF3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7DE53E2081024000
    2    768 002001     1071360000       34560000 59EC6457 0B77A1ED14405371072E0E41E6C5BA0C0A0A0B4181C1C1FEAE11214DFB8E8A21BED646B3A7B4EAD290E10DBB5C12C625093255CFADBE575DF7497FA895D2B0A4A140FF311A759DAA735F33E5655FCD76F9FA544A573F49D1F7B89FCD2DDF83A7CF9F3E7CF9D3A7CE9F3DA55DCD77CF9F3E7B577D77CF6BBE7DE53DE89122403C
    2    768 002001     1105920000       34560000 4E1269F9 0B77D9FB14405370E72E0E41E6C5BA0C0C0A0D4181C1C1BED58C7CFDF2AACF6B577EA552674AD0544AE26F171708AF4B5A956A6E92BEB9C1F7314EFE0247D112C27D61AC1B79D4D2D5EC975EECA4A8461532A99ED84C99CCEA5E53DA0810240225C8AC299E567DF1F140BFC387E7FE03FA6459DD83E4DF7830D5FD1D0DEC5B88
    2    768 002001     1140480000       34560000 81750CF8 0B772A0714405370872E0E2BE6C5BA100E0C0D410181C1FEED907BB1CC37AF9F3F4C95FA57EE9C577E9465D6B4D2A9AF96E38AEF95BDB30DF418F8CDF488F224B9D3170A8AFB447BB1CD254BD0C3696DFAAA6F9D427D49F53AD4D2BF4B4ABBB1CE3CB7B010204803235D03F61F8CDFDF762FD3046010F201CFD109A19F1867E0
    2    768 002001     1175040000       34560000 43A6EC7A 0B77CD6D14405370672E0E1FE6C5BA0C0C0C0D41818181BEAD887B612BE7E95F3E7E95F518561329A731CC47B0DCD774EC8CDA55D339C3C1F2E2D8FAC5CB8FE13E20D2F10A54D570534A1BE7E95FBE74FAAEF855D2D37B5ABE927B3E877AE3FAEF9C5386F6BAE7EAA3A12CF9F534CF9556D35AC25AD0AB3EAD65BD8489124012
    2    768 002001     1209600000       34560000 F65DDAF7 0B77904614405370672E0E1BE6C5BA0A0E0C0D41C18181FEAD885D369574CE95667CB6BBDAD5AB434E810D7B0329A5882EBC39D394D38171D2E2E7BEE6CD91E1A47AD2EB97CFDF6B8735FBF4AF9F584B0DCC2868613F4AFA96B278587F163D790F9FA08EFA9569095FA57CFDF39AD0DF527D4C8BE7D5A9BD7F65BD848912403C
    2    768 002001     1244160000       34560000 AB58667A 0B77A72114405370672E0E19E6C5BA100A0C0D4101C181AEAD878EF9F4DCD5ABAA7B5D33DAE95F4276E1EE0850AB2E855A93E84F9F29C56E9AFBDF0E1DC8F62BA47AE30427EF75C2AEFA1B9AEF9FBA4B5DFA1A5475BE7ED3869EEE404F02C137F5DCD2B0892BE7B115297D4D4D34E85F52A4FA13A84FA952A7E5BD848912400A
    2    768 002001     1278720000       34560000 4C5F1F8C 0B778A2614405370672E0E19E6C5BA0E0C0E0D41818181BEAD265542C3A54F94C284FDEC27D0AC0CACE66D87E9692A7D49F527CF6BA5BBD552C9E15F8AFB0FEB904B32EBDAD1A9D85B0DCC37CA6DC371C4A53535AB3F7CF9DEB2765BD926BCFA7B5039B74A1BA4CFD32D7D4D4BE86AA8EB7D09F6A84FA9BE4BE5BD8081024016
    2    768 002001     1313280000       34560000 BCC6B19A 0B77A47314405370672E0E19E6C5BA0C0C0C0F41818181AEAD257B612C27E961A67496B2B44A693DA6F90AB535DF3E74AD320B6FA8D2BB85F2CAC0BAE407EFE2077B36E3DD6FAD5BA6EA13B71AE1AB717E33EA55DF2A54F5FEB8ABD7B1C2B597FB4FD784ED2D7730E352A5495A9AD49FBA7CEA352A320AD67DE5BD7891224002
    2    768 002001     1347840000       34560000 FB5ECF33 0B77550814405370672E0E19E6C5BA0C0E0C0D41818181BEFD08D6F9FBA4A96BBB4C82E2554F953DB0446478835F3E74F9EC2ACF9F4789821BC9BC95F57B9761D2DB17CE10A24054FDCF96F502040900B065F10501F73779022FBC88A3C1D0B5C8C48EACBE07FA14AE1F2798AFC3FB367CF658A80484B9CE8FFB4242D689578A
    2    768 002001     1382400000       34560000 5763DD4E 0B77067B14405370672E0E19E6C5BA0A0E0C0D41C18181BEFD1BB0ED2B97D9B4295B5E13A54F94C67E99057A6A9D4DD6A9F297EF5FBA61729C18B2A5CF1B975F43DEF7CCEE6C58850DF796F4F264C9001C6BA83BF45F9B1BF0FB1D6FE0E0D3E0C5ACFE23287E19E03D03C058AFC02B30507B0FC17FFDA08ED262F57130841931
    2    768 002001     1416960000       34560000 DF7EF00E 0B77AFC014405370672E0E19E6C5BA0C0A0C0D41C1C181BEAD087B5E8D7AD5A15754F9F4E7CF6D428695CDB7CF9F534C85FAA4CE55B8BD85536268FE1BFB55F5517E854BE4CF6BDB7D212BAAF59F3EAF0DFAB4AE6EA9ACFDEEB8A6BF85F2C5872F9CB8DDAD2BE5EAD33F4B4AA3D86E6E3EACFB5568511CC2A3E5BD2E9D3A401B
    2    768 002001     1451520000       34560000 56D934D8 0B77495E14405370672E0E19E6C5BA0C0C0C0D41818181BEACA1D5ADCEB9E561A64CE9CC3A4A9CAE7CF92DC715DF434AE6C424AA9329BD71FAE1DD1F621ADC9E914AF9EBF190B5D3A3C1552AD5D33F7F56BAA84FABC37EF69ED26AC7D1CAC43A4E90BA72F92444CFA195D8E6BC1AF0133E7CF73BEAD5DF434BE5BD2A952A403F
    2    768 002001     1486080000       34560000 99EE9DDF 0B77BCA014405370672E0E19E6C5BA0C0C0C0D41818181BEACA6A559D3F4C96B3F4CA5F3E7D206534AA9CC4495E13B42E63D31A9A1A0E3D53B497B729579F11F23836AAD82485F677EAA1537D59F437DBE92CA2AF593834976B8A8E0D5F1FDC7CA133E78F9FA186BA3BEA659FBDA55E3BE8CFA1D1A55EB427FE5BD3D9B36400A
    2    768 002001     1520640000       34560000 BADDB82F 0B77196514405370672E0E19E6C5BA0E0C0C0D41818181BEAD0C7D477D2A50A9A97D59FA9AD5953E7D45CDC7BADED77E9612B4B36395E5C1D27CA365F5C4F009245B5A9A9850DFA58643A51B949747836DF51DA7EDAF7B1DF6D275727576C42B89A8D286E8B3D86F9F3E86994D34D06BA6764692A7D5DD3D8FE5BD6081024010
    2    768 002001     1555200000       34560000 6C62FE66 0B7734CC14405370672E0E19E6C5BA0C0C0C0D41818181BEACA988D6152A4F9F55875DF2A496DCDD18F90BF7D49D3DD6A5FBEA4E5FB5BB855AE2AF720E0AE4F34E695ABAE836E9C454F94D7A4F9FB98745FBDB099CD7535DEE9DB858ABF1FD790888A1854AB43869693F530A95686E9D3D90921C27CFABAA75E5BD5E9D3A4003
    2    768 002001     1589760000       34560000 F1209DF5 0B77136414405370672E0E1BE6C5BA0C0C0C0D41818181BEED23AD5DF4284AD339A54A1BE72A6C2583992DC7D369B67AF75BF7AF6BBDE581FB7CB0FB378B0BA1BAD716B80ABDC355C45BB4C46BBE9CAAC257EE6B3F7CF94D78356DD75695FBB490FCB7AB12244805B423F200038010D57CABD6DB3065A62349F75488EDFF0486
    2    768 002001     1624320000       34560000 0EE428B8 0B77D49514405370672E0E1BE6C5BA0C0C0C0D41818181BEAD0C735E8D77D061BEA36E32A84AA12B4AF5CDBAE969677CE9CAE7D49FA4E57202E2E0FA9D474861BE11ADFBE9CE5FAFA74DD265E8533E7EF5F568096990DF49F6D8AB3FA7EDFBB86A526D24D692985129A97EA75A97CFABBE7CFA13E7C9D529BFE5BD53870E402F
    2    768 002001     1658880000       34560000 9EB0E9D0 0B772DB814405370672E0E1BE6C5BA0C0C0C0D41818181BEAD0C54A9D3E4B6D4D688A5FB98509F2772E905C54F94AC48FD2BE7CF9FA1B9D9334A41821C2AEE6E2876554D372E9D43AEAB542B936B57B70DF3DB75D7A580A2BEBDD060AFF15A588DE95684F9F257D12944415B88D7CFABD2A832210AEFD3397DE5BD3A952A4011
    2    768 002001     1693440000       34560000 D52C24B9 0B77CAED14405370772E0E1BE6C5BA0C0C0C0D41818181BEACA17D0A9CE7CE6B6EAF09F528499CD449590C4734D2D838A9F565E9600C89D55B62436E952BAE61A4AE95F259D4A9A6550DF3F4D6503F7C96BC37EE94BFA70A9EB89D7075F15BE84E6B397CF5FA64D09F5C9B0A1DC52BA1BE7CFA9BA53712AE75E5BD378F1E4017
    2    768 002001     1728000000       34560000 D5122A31 0B77D3BB14405370772E0E1BE6C5BA0C0C0C0D41818181BEFD0B86F9FA086E9F3EA4A9D3E8499D3F4AE5ADC52F9F3F431D2AE83AD6D791D60445B892BD78A8ABABDBBFC9071FC9A30E1796F522448900854BF50E12B4F3F0034016869295E913780020AD3219A09A83043E771D699C4833A7F0276E26B40064977697D0CCD6A0
    2    768 002001     1762560000       34560000 2ABD59B3 0B7705C214405370772E0E1BE6C5BA0C0C0C0D41818181BEAD0C835DD41D55E942ACF9FB9550AB2A7AF9C717AFABA672AA7A64B69EC2F3D55AF774BAC3DE10F32B214A6DB7682B6C8F5DF3F4CFDEB97EA77D27EF932B535D4EB8B3ADE3EA4487E41D399E4613ACF4B5587B4E0D74CA9ED3A4E61BE7D49FAA73E5BD558B164004
s=3 n=0 o=0
005003:0000 Failed to save title 0 to file [Redacted]/Numb3rs/Season 1/Numbers.mkv
[Removed duplicates for other 3 titles due to character limits]
005004:0080 0 titles saved, 4 failed
005037:0204 Copy complete. 0 titles saved, 4 failed.
Application exited at Tue Jan 07 02:18:10 2025
Ezatoka
Re: Numb3rs DVDs Not Reading
Post by Ezatoka »
Is there a change if you try deselecting Subtitle and/or Audio tracks as a test?
Vrykodin
Post by Vrykodin »
Seems deselecting subtitles did work. Possibly something with CCExtractor?
Vrykodin
Post by Vrykodin »
I figured it out. I had the wrong exe selected for CCExtractor. Thanks!
jaydear
Post by jaydear »
So was the correct one "ccextractorwinfull.exe' ? I'm not getting anything with that one or the gui version.
