Post by RESET_9999 » Sun Jan 05, 2025 2:12 am
PS, to those who generate DV...
I said a couple of times that I selected the mastering display luminance based on the content's actual brightness(measured in 6-2).
I said to use 1000nits MDL if 90%+ of the shots have highlights under 1000nits.
Well, this is not longer the right thing to do because I recently discovered that some players like the Ugoos, Oppo, x700, X800m2 will clip highlights if the content is brighter than the RPU mastering display luminance, regardless of the metadata. So it may not be a good idea after all to use 1000nits MDL even if there are only a few highlights brighter than 1000nits because they will be clipped if your TV is not capable of displaying this brightness.
Interestingly, the Shield, the AppleTV, C2-C1-C9 internal player and Hisense internal player do not have this behavior and will tone map the image correctly without clipping regardless of the MDL (as long as L1 is right). This finally explains the RPU response differences between TV-LED devices that we noticed a long time ago (years ago?).
I did some test files that clearly show what I'm talking about: https://drive.google.com/drive/u/1/fold ... URFcibN6X-
Specifically: ''Dolby Vision 1000nits RPU Harry 2848nits scene P8.mp4''
*** This is about TV-LED. LLDV seems to work properly. Confirmed on oppo, ugoos, C9 C1 C2 Hisense... I no longer have the x700 x800m2 but it is most likely the same as the oppo, they have the same soc
Post by SamuriHL » Sun Jan 05, 2025 3:37 am
RESET_9999 wrote:Yes, I tested hevc decoding not a long time ago and it still drops frames.
Try the Spears and Munsil demo clip, it drops frames almost instantly with the mkv container. If you remux it to mp4, the SM clip will work but it is still not 100% reliable.
SamuriHL wrote:
Sun Jan 05, 2025 1:36 am
Have you had a chance to test Davinci 19.x to see if it's still necessary to decode to prores first? Has their hevc support improved at all? I finally was able to fix my Davinci working with their support and I want to start playing with DV conversions soon. Thanks!
Good to know thanks. Prores it is then.
Sent from my SM-S928U1 using Tapatalk
darrrkmanxxx
Post by darrrkmanxxx » Sun Jan 05, 2025 12:32 pm
So do we have to re-generate to a higher mastering display (based on 6.2 measuremnts) or just edit L6?
Post by RESET_9999 » Sun Jan 05, 2025 2:14 pm
If you use a Oppo, X800m2 , x700 or Ugoos and the content has highlights brighter than 1000nits, it should be generated again. L6 is useless.
darrrkmanxxx
Post by darrrkmanxxx » Sun Jan 05, 2025 5:04 pm
alright thanks for the answer!
deadchip12
Post by deadchip12 » Mon Jan 06, 2025 4:56 am
@RESET_9999
I looked for Alien Romulus web rpu in your google drive folder and only saw Alien.Romulus.2024.UHD.BluRay.2160p.TrueHD.Atmos.7.1.DV.HEVC.REMUX-FraMeSToR Retail P7 FEL (cmv4.0 added).bin. Is this file the equivalent of CMV4.0_L3L8L9_transfered.bin? Do we just inject this directly to the bluray mkv file?
darrrkmanxxx
Post by darrrkmanxxx » Mon Jan 06, 2025 9:34 am
@RESET_9999
can you please share the link with all of the RPUs?
Post by RESET_9999 » Mon Jan 06, 2025 12:08 pm
The link is private...
Instructions on how to access it are in the Resolve Metadata Generation tutorial comments.
yes, I did all the possible movies on my GD.
darrrkmanxxx
Post by darrrkmanxxx » Tue Jan 07, 2025 1:20 pm
@RESET_9999
For devices who can't play P7, what would be the workflow to get the best out of dynamic metadata?
exmaple:
I have one profile 7 remux and a web-dl profile 8, which are compatible in brighntess.
- Extract rpu from web-dl p8
- convert P7 to P8 with dovi_tool
- inject into converted remux
Is that correct?
Post by RESET_9999 » Tue Jan 07, 2025 3:25 pm
just convert the P7 rip to P8 with workflow 4-1
darrrkmanxxx
Post by darrrkmanxxx » Tue Jan 07, 2025 3:40 pm
thanks, is this the same as with dovi_tool mode 2 from quietvoid?
Post by RESET_9999 » Tue Jan 07, 2025 3:49 pm
yes, all the workflows rely on dovi_tool.exe ... there's no other way.
fazambuja
Post by fazambuja » Wed Jan 08, 2025 2:18 am
Would it be possible to extract the HDR10plus of lower quality mkv and inject it into its higher quality variant?
File size                                : 23.3 GiB
Duration                                 : 1 h 59 min
Overall bit rate                         : 28.0 Mb/s
Frame rate                               : 23.976 FPS
Movie name                               : Alien Romulus (2024)
Encoded date                             : 2024-12-05 16:14:58 UTC
Writing application                      : mkvmerge v88.0 ('All I Know') 64-bit
Writing library                          : libebml v1.4.5 + libmatroska v1.7.1 / Lavf60.3.100
Cover                                    : Yes
Attachments                              : cover.jpg
Time code of first frame                 : 01:00:00:00
Time code source                         : Matroska tags
Video
HDR format                               : Dolby Vision, Version 1.0, Profile 8.1, dvhe.08.06, BL+RPU, no metadata compression, HDR10 compatible / SMPTE ST 2094 App 4, [B]Version HDR10+ Profile A, HDR10+ Profile A[/B] compatible
Bit rate                                 : 25.7 Mb/s
Height                                   : 1 608 pixels
Display aspect ratio                     : 2.39:1
Chroma subsampling                       : 4:2:0
Bits/(Pixel*Frame)                       : 0.173
Stream size                              : 21.4 GiB (92%)
Title                                    : HSaber <-|-> Z@X
Mastering display color primaries        : BT.2020
Maximum Frame-Average Light Level        : 400 cd/m2
File size                                : 53.6 GiB
Overall bit rate                         : 64.5 Mb/s
Movie name                               : Alien: Romulus - Ultra HD™
Encoded date                             : 2024-11-26 14:39:36 UTC
Cover                                    : Yes
Video
ID in the original source medium         : 4113 (0x1011)
HDR format                               : Dolby Vision, Version 1.0, Profile 7.6, dvhe.07.06, BL+EL+RPU, no metadata compression, Blu-ray compatible / SMPTE ST 2086, Version HDR10, HDR10 compatible
Bit rate                                 : 54.9 Mb/s
Bits/(Pixel*Frame)                       : 0.276
Stream size                              : 45.6 GiB (85%)
Title                                    : English
Post by RESET_9999 » Wed Jan 08, 2025 11:59 am
Yes, measure both videos if they are the same grade.
dkangel
Post by dkangel » Wed Jan 08, 2025 4:55 pm
RESET_9999 wrote:
Fri Dec 27, 2024 2:59 pm
Thanks for explaining. How to interpret those? Is the madvr plot the best, because it has the most dynamics?
If I do the madvr measuremnt, I adjust cmv4.0 when I generate from madvr file with dovi_tool ,e.g.
No, madvr generated metadata (3-2) is the worst and not really suited for DV playback. Also, Madvr scene cut detection is not very good. It's quite sensitive to flashes/explosions/fast movement and can sometimes miss obvious scene cuts. The best dv metadata generation is one of the analysis tunings using Davinci Resolve. I prefer the ''balanced tuning'' which is the dovi_scripts default in workflow 3-1
Hello
in your video you said that we should choose most highlights details in resolve but now i see that you prefer balanced. So what is the best ? :D
