MakeMKV Fail to Open DVD
redraidergrad
Post by redraidergrad » Sun Jan 05, 2025 4:01 am
I have ripped nearly my entire video collection using a combination of an old DVD drive and a blu-ray drive (WH16NS40 flashed to WH16NS60). I have not run into any problems until trying to rip a DVD copy of Harry Potter and the Order of the Phoenix. I have tried cleaning the DVD, but both drives fail to open the disc, providing the log below. If anyone has run into a similar problem, any help would be appreciated.
MakeMKV v1.17.8 win(x64-release) started
Using LibreDrive mode (v06.3 id=7FA2657C7667)
Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading 'BD-RE HL-DT-ST BD-RE WH16NS60 1.02 SIK97G8JI471' at offset '43581440'
Title #1 (2:18:04) was skipped due to navigation error
Title #2 has length of 12 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #3 has length of 12 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #4 has length of 21 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #5 has length of 12 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Cells 1-1 were removed from title start
Cells 7-7 were removed from title end
Title #6 declared length is 0:06:58 while its real length is 0:01:49 - assuming fake title
cecilb
Re: MakeMKV Fail to Open DVD
Post by cecilb » Mon Jan 06, 2025 2:07 am
noob here. I had working copy of Life of Pi and received same error
Next retail version of Top Gun and received same error,
Will look here for cause-solution
Post by dcoke22 » Mon Jan 06, 2025 5:47 am
There are different DVD Opening Modes you can try.
If you have the paid-for version of MakeMKV, you can try an older version of MakeMKV. Others on this forum have reported success with troublesome DVDs by trying an older version of MakeMKV. The DVD engine was rewritten recently and is generally better than the old one, but occasionally, the old one works better.
cecilb
Post by cecilb » Thu Jan 09, 2025 11:26 pm
I believe in the practice of taste and try before you buy. I should expect the beta/trial version be ready for prime time. The previous versions should be available if makemkv wants purchasers :)
Post by Woodstock » Fri Jan 10, 2025 12:05 am
The previous versions ARE available. Link given above. But they work the same if they're registered vs. not-registered, except for expiration.
There are a lot of people who claim they're "just trying" it for months (or years).
