Indiana Jones and the Dial of Destiny
Sonic76
#1 Post by Sonic76 » Sun Jan 05, 2025 11:34 am
I have the Scandinavian edition of Indiana Jones and the Dial of Destiny.
I can't get this to rip.
have understood it to mean that someone must create a Dump file.
Can anyone help with this?
Thanks in advance :)
Disc Information
Label: INDIANA_JONES_DIAL_OF_DESTINY
Timestamp: 2023-09-14 08:47:16
Protection: AACS2.0/C v77
Data capacity: 91.71 Gb
Disc type: BD-ROM UHD
Number of layers: 3
Bus encryption flags: 80
MakeMKV v1.17.8 win(x64-release) started
Using LibreDrive mode (v06.3 id=0FA242DD4D0B)
Error 'OS error - Access is denied' occurred while creating 'C:/Program Files (x86)/MakeMKV/MKB20_v77_INDIANA_JONES_AND_THE_DIAL_OF_DESTINY_B62E.tgz'
Re: Indiana Jones and the Dial of Destiny
#2 Post by Woodstock » Sun Jan 05, 2025 6:29 pm
Considering that YOU just created a dump file, did you submit it to svq@makemkv.com yet?
#3 Post by SamuriHL » Sun Jan 05, 2025 7:42 pm
Woodstock wrote: Sun Jan 05, 2025 6:29 pm Considering that YOU just created a dump file, did you submit it to svq@makemkv.com yet?
No it didn't....
The data directory in MakeMKV appears to either not be set or set to the program files directory which MakeMKV can't write to.
P.S. That also means that the hashed key updates likely fail since it can't write to that folder.
