BDR-XD07TS recently bought, looking for crossflash info!
Hi guys, I'm new here and have recently acquired the above bluray drive to backup my discs for plex use etc. Have noticed it seems possible to cross flash to enable the ripping of UHD discs with this drive, could anyone provide further info please?
Re: BDR-XD07TS recently bought, looking for crossflash info!
Further info depends on info from you - what does MakeMKV say about your drive? Pioneer drives have issues with when their BIOS was written. If the BIOS was 12/2022 or after, they won't work.
Provide your drive / libredrive info sections.
Thanks both.
OS device name: E:
Manufacturer: PIONEER
Product: BD-RW BDR-XD07
Revision: 1.03
Serial number: ...
Firmware date: 2020-08-20
Bus encryption flags: 13
Drive platform: RS8D30
Firmware version: 1.03
OS device name: E:
Revision: 1.03
Serial number: ...
you can email me for a pioneer auto flasher see belowChewey182 wrote: ↑Sat Jan 04, 2025 11:58 pmThanks both.
OS device name: E:
Revision: 1.03
Serial number: ...
EmailedBillycar11 wrote: ↑Sun Jan 05, 2025 12:00 amyou can email me for a pioneer auto flasher see belowChewey182 wrote: ↑Sat Jan 04, 2025 11:58 pmThanks both.
OS device name: E:
Revision: 1.03
Serial number: ...
Sorry for the delay I’ve sent the reply email and fulfilled requests.Billycar11 wrote: ↑Sun Jan 05, 2025 12:00 amyou can email me for a pioneer auto flasher see belowChewey182 wrote: ↑Sat Jan 04, 2025 11:58 pmThanks both.
OS device name: E:
Revision: 1.03
Serial number: ...
Hi guys,
just new here and looking for some help. I bought a BDR-X07TS drive to be able to read or write 4K BD´s.
Can you please help me out with the flashing for the drive.
the MakeMKV info:
Hope it´s not a problem with the language.
Laufwerksinformation
OS-Gerätename: /dev/rdisk6
Aktuelles Profil: BD-ROM
Produzent: PIONEER
Produkt: BD-RW BDR-XS07
Revision: 1.01
Serienummer: ...
Firmware-Datum: 2020-09-03
Markierungen der Bus-Verschlüsselung: 13
Highest AACS version: 66
Drive platform: RS8E20
Firmware version: 1.01
Any info will be highly appreciated.
Thank you
the MakeMKV info:
Produzent: PIONEER
Revision: 1.01
Serienummer: ...
Thank you
PM sent.breitkurt wrote: ↑Fri Jan 10, 2025 12:54 amHi guys,
the MakeMKV info:
Produzent: PIONEER
Revision: 1.01
Serienummer: ...
Thank you
Thank you so much. That was easy. And the best thing .. it works. Now I´m able to read 4K BD´s.Coopervid wrote: ↑Fri Jan 10, 2025 10:30 amPM sent.breitkurt wrote: ↑Fri Jan 10, 2025 12:54 amHi guys,
the MakeMKV info:
Produzent: PIONEER
Revision: 1.01
Serienummer: ...
Thank you
You´ve done an amazing job for me. Jumping into the forum and asking for help and nearly 12 hours later I have the solution.
Now I´ll buy the MakeMKV license. Writing is not tested yet but it´s not my no. 1 goal.
what you do a charge back for thats a mean moveChewey182 wrote: ↑Sun Jan 05, 2025 9:51 pmSorry for the delay I’ve sent the reply email and fulfilled requests.Billycar11 wrote: ↑Sun Jan 05, 2025 12:00 amyou can email me for a pioneer auto flasher see belowChewey182 wrote: ↑Sat Jan 04, 2025 11:58 pmThanks both.
OS device name: E:
Revision: 1.03
Serial number: ...
i have same drive, any help would be appreciated.
Informacje o napędzie
Nazwa systemowa: J:
Producent: PIONEER
Produkt: BD-RW BDR-XD07
Wersja: 1.03
Numer seryjny: ...
Data firmware: 2020-08-20
Flagi szyfrowania bus: 13
Nazwa systemowa: J:
Producent: PIONEER
Wersja: 1.03
Numer seryjny: ...
I'll replace my 43890 by the following BDR-XD07TS. Any support for a 4k flash is welcome. Thank you in advance at this point.
OS-Gerätename: F:
Produzent: PIONEER
Revision: 1.03
Serienummer: xxxxxxxxxxx
Firmware-Datum: 2020-08-20
Highest AACS version: 77
OS-Gerätename: F:
Produzent: PIONEER
Revision: 1.03
PM is coming.zittrig wrote: ↑Mon Feb 24, 2025 4:22 pmI'll replace my 43890 by the following BDR-XD07TS. Any support for a 4k flash is welcome. Thank you in advance at this point.
OS-Gerätename: F:
Produzent: PIONEER
Revision: 1.03
PM sent.annqu wrote: ↑Sat Feb 22, 2025 10:18 pmi have same drive, any help would be appreciated.
Nazwa systemowa: J:
Producent: PIONEER
Wersja: 1.03
Numer seryjny: ...
