Haikyu!! from eBay fails to open
duxster
Post by duxster » Sat Jan 04, 2025 7:06 pm
I received a box set of Haikyi!! from eBay of the english dub which is nearly impossible to find. It will play in any DVD player, so the discs operate. It also plays in VLC player without issue. I've tried it with my flashed LG blu-ray (LG Electronics WH14NS40 14X Blu-ray/DVD/CD Multi compatible Internal SATA Rewriter Drive, BDXL, M-DISC Support, Black) drive, and get this error.
MakeMKV v1.17.8 win(x64-release) started
Using LibreDrive mode (v06.3 id=7FA2657C7667)
Cells 14-21 were removed from title end
Title #1 was added (13 cell(s), 5:17:42)
Saving 1 titles into directory E:/MKV Output/MKV
Error 'Scsi error - ILLEGAL REQUEST:INVALID FIELD IN CDB' occurred while reading '/VIDEO_TS/VTS_01_1.VOB' at offset '292433920'
Error 'OS error - The specified request is not a valid operation for the target device' occurred while reading '\Device\CdRom0' at offset '292433920'
Failed to save title 0 to file E:/MKV Output/MKV/A1_t00.mkv
0 titles saved, 1 failed
If I used a regular external DVD drive that comes with a laptop, I get a file which has most of the episodes back to back but it only pulls 13 out of 20 episodes.
I'm wondering if the error message has any details that make sense of the issue. If it's just not going to work with this disc series, not the end of the world. If anyone has any ideas, I appreciate it.
Thanks,
Re: Haikyu!! from eBay fails to open
Post by dcoke22 » Mon Jan 06, 2025 6:07 am
Can you make a backup of the disc with MakeMKV?
On the first screen in MakeMKV, click the icon of the yellow folder with the green arrow. For a DVD, that'll make an .iso file of the whole disc. You can then open that .iso file in MakeMKV and create .mkv files of the various titles on the disc.
