When 6-4 creates trims plot graph image(s), then yes your input contains trims...
if the graph is a straight line (like the Harry Potter movies), then it has static trims and you can discard the original RPU and use the cmv4.0 generated one.
daffie
Post by daffie »
RESET_9999 wrote:
Sat Jan 04, 2025 2:58 pm
valington wrote:
Sat Jan 04, 2025 11:45 am
hallo reset is it good enough SEVEN with freman and pit from framestore hybrid 8 profile dolby vision or it s aggain fail from the framestore group and it s in cm4.0 or cm2.9 ?
it looks ok.
cmv4.0
So this Se7en framestore release with DoVi cm4.0 is actually better in terms of quality when compared with the HDR10 cm2.9 uhd retail bluray ?
LG OLED65G1RLA / Samsung HW-Q990D / Panasonic UB820 / Ugoos AM6B+ (CE with avdvplus Build)
daffie wrote:
Sat Jan 04, 2025 4:13 pm
Well, 92% of the movie is under 600nits so pretty much all the TVs will be able to display it without tone mapping.
It shouldn't look much different than HDR10 playback unless you have a very low brightness TV/PJ.
The trim has a positive lift over 0.0025(2100) for the whole movie but it is ignored by all the HDMI devices.
daffie
Post by daffie »
RESET_9999 wrote:
Sat Jan 04, 2025 4:19 pm
Thanks a lot for your reply!
"Unless you have a very low brightness TV."
I have a LG G1 OLED. That should be fine I guess in terms of brightness?
yes
darrrkmanxxx
Post by darrrkmanxxx »
RESET_9999 wrote:
Sat Jan 04, 2025 4:11 pm
Thanks for the answer. That clarifies a lot for me.
However when I plot a cmv4.0 there are no L2 trims being created but the L1 Plot list it. Are those produced from L8 now and is it also backwards compatible with cmv2.9 devices?
fazambuja
Post by fazambuja »
I'm pretty late to the party, but what is your guy's suggestion to a Samsung TV owner with only HDR10plus available?
Is it even worth getting something like a Ugoos AM6B? I'm currently using an Apple TV 3rd gen with Infuse.
I mainly download and occasionally rip some UHD Blu-rays.
fazambuja wrote:
Sat Jan 04, 2025 11:48 pm
Yes, the ugoos supports DV + FEL(LLDV) on any display (SDR/HDR10).
All the original/retail CMV4.0 rpu will have L2.
I just noticed the latest script version has the L2 trims plot disabled by default. So re-enable it at line 185
:: plot cmv4.0 only in 6-4. This disable L2 plot (default = NO)
set cmv4.0.only=NO
Post by SamuriHL »
Have you had a chance to test Davinci 19.x to see if it's still necessary to decode to prores first? Has their hevc support improved at all? I finally was able to fix my Davinci working with their support and I want to start playing with DV conversions soon. Thanks!
P.S. Apparently when I installed the pre-reqs for DoVi Tools, the version of Python that got installed from the Windows store broke Davinci and it was no longer able to start. Throwing that out there as a warning for anyone else who may run into that issue. I will need to solve the Python version issue before I get too far.
Yes, I tested hevc decoding not a long time ago and it still drops frames.
Try the Spears and Munsil demo clip, it drops frames almost instantly with the mkv container. If you remux it to mp4, the SM clip will work but it is still not 100% reliable.
SamuriHL wrote:
Sun Jan 05, 2025 1:36 am
PS, to those who generate DV...
I said a couple of times that I selected the mastering display luminance based on the content's actual brightness(measured in 6-2).
I said to use 1000nits MDL if 90%+ of the shots have highlights under 1000nits.
Well, this is not longer the right thing to do because I recently discovered that some players like the Ugoos, Oppo, x700, X800m2 will clip highlights if the content is brighter than the RPU mastering display luminance, regardless of the metadata. So it may not be a good idea after all to use 1000nits MDL even if there are only a few highlights brighter than 1000nits because they will be clipped if your TV is not capable of displaying this brightness.
Interestingly, the Shield, the AppleTV, C2-C1-C9 internal player and Hisense internal player do not have this behavior and will tone map the image correctly without clipping regardless of the MDL (as long as L1 is right). This finally explains the RPU response differences between TV-LED devices that we noticed a long time ago (years ago?).
I did some test files that clearly show what I'm talking about: https://drive.google.com/drive/u/1/fold ... URFcibN6X-
Specifically: ''Dolby Vision 1000nits RPU Harry 2848nits scene P8.mp4''
*** This is about TV-LED. LLDV seems to work properly. Confirmed on oppo, ugoos, C9 C1 C2 Hisense... I no longer have the x700 x800m2 but it is most likely the same as the oppo, they have the same soc
Post by SamuriHL »
RESET_9999 wrote:Yes, I tested hevc decoding not a long time ago and it still drops frames.
Good to know thanks. Prores it is then.
Sent from my SM-S928U1 using Tapatalk
darrrkmanxxx
RESET_9999 wrote:
Sun Jan 05, 2025 2:12 am
So do we have to re-generate to a higher mastering display (based on 6.2 measuremnts) or just edit L6?
darrrkmanxxx wrote:
Sun Jan 05, 2025 12:32 pm
If you use a Oppo, X800m2 , x700 or Ugoos and the content has highlights brighter than 1000nits, it should be generated again. L6 is useless.
darrrkmanxxx
RESET_9999 wrote:
Sun Jan 05, 2025 2:14 pm
alright thanks for the answer!
