(6-4) to plot the trims
hallo reset is it good enough SEVEN with freman and pit from framestore hybrid 8 profile dolby vision or it s aggain fail from the framestore group and it s in cm4.0 or cm2.9 ?
darrrkmanxxx
What exaclty should there be?
I used on workflow 6-4 on the example mentioned below (P8 Remux) here are the results:
If you have a few can you please take a look and myabe point out exaclty what should I look for and if this is worth of transferring genarted metadata?
Also how do I verify if FEL was baked in?
ps hope my questions will get less annoying once I start getting it
it looks ok.
cmv4.0
You can never transfer a generated cmv4.0 block into an original/retail cmv2.9 rpudarrrkmanxxx wrote: ↑Sat Jan 04, 2025 12:41 pmWhat exaclty should there be?
if the original cmv2.9 doesn't have any trims (or static ones), then you can completely discard the rpu and inject your generated cmv4.0 rpu
compare the encode with the original P7 rip in 7-2Also how do I verify if FEL was baked in?
darrrkmanxxx
Sure, but what should I look for in my example. There are PNGs with L2 titles and there's some stuff in the graphs. Are those the trims?You can never transfer a generated cmv4.0 block into an original/retail cmv2.9 rpu
When 6-4 creates trims plot graph image(s), then yes your input contains trims...
if the graph is a straight line (like the Harry Potter movies), then it has static trims and you can discard the original RPU and use the cmv4.0 generated one.
So this Se7en framestore release with DoVi cm4.0 is actually better in terms of quality when compared with the HDR10 cm2.9 uhd retail bluray ?
LG OLED65G1RLA / Samsung HW-Q990D / Sony UBP-X800M2 / Ugoos AM6B+ (CE with CPM Build)
Well, 92% of the movie is under 600nits so pretty much all the TVs will be able to display it without tone mapping.
It shouldn't look much different than HDR10 playback unless you have a very low brightness TV/PJ.
The trim has a positive lift over 0.0025(2100) for the whole movie but it is ignored by all the HDMI devices.
Thanks a lot for your reply!RESET_9999 wrote: ↑Sat Jan 04, 2025 4:19 pmWell, 92% of the movie is under 600nits so pretty much all the TVs will be able to display it without tone mapping.
"Unless you have a very low brightness TV."
I have a LG G1 OLED. That should be fine I guess in terms of brightness?
darrrkmanxxx
Thanks for the answer. That clarifies a lot for me.RESET_9999 wrote: ↑Sat Jan 04, 2025 4:11 pmWhen 6-4 creates trims plot graph image(s), then yes your input contains trims...
However when I plot a cmv4.0 there are no L2 trims being created but the L1 Plot list it. Are those produced from L8 now and is it also backwards compatible with cmv2.9 devices?
I'm pretty late to the party, but what is your guy's suggestion to a Samsung TV owner with only HDR10plus available?
Is it even worth getting something like a Ugoos AM6B? I'm currently using an Apple TV 3rd gen with Infuse.
I mainly download and occasionally rip some UHD Blu-rays.
Yes, the ugoos supports DV + FEL(LLDV) on any display (SDR/HDR10).
All the original/retail CMV4.0 rpu will have L2.However when I plot a cmv4.0 there are no L2 trims being created but the L1 Plot list it.
I just noticed the latest script version has the L2 trims plot disabled by default. So re-enable it at line 185
:: plot cmv4.0 only in 6-4. This disable L2 plot (default = NO)
set cmv4.0.only=NO
Have you had a chance to test Davinci 19.x to see if it's still necessary to decode to prores first? Has their hevc support improved at all? I finally was able to fix my Davinci working with their support and I want to start playing with DV conversions soon. Thanks!
P.S. Apparently when I installed the pre-reqs for DoVi Tools, the version of Python that got installed from the Windows store broke Davinci and it was no longer able to start. Throwing that out there as a warning for anyone else who may run into that issue. I will need to solve the Python version issue before I get too far.
Yes, I tested hevc decoding not a long time ago and it still drops frames.
Try the Spears and Munsil demo clip, it drops frames almost instantly with the mkv container. If you remux it to mp4, the SM clip will work but it is still not 100% reliable.
SamuriHL wrote: ↑Sun Jan 05, 2025 1:36 amHave you had a chance to test Davinci 19.x to see if it's still necessary to decode to prores first? Has their hevc support improved at all? I finally was able to fix my Davinci working with their support and I want to start playing with DV conversions soon. Thanks!
