darrrkmanxxx
Post by darrrkmanxxx » Fri Jan 03, 2025 9:38 am
RESET_9999 wrote: Thu Jan 02, 2025 11:07 pm Do all the checks as I did in the video and find out.
This title is probably missing(IIRC) from my ''okay to transfer'' list because I deleted the old sheet by mistake.
thats great news! Thanks for letting me know.
Meanwhile, I ran the workflow 3-1 on my windows machine and unfortunately it took forever since I have an AMD RX 6900 XT (no CUDA) :(, which I plotted afterwards and now there a 10000nit spike:
https://drive.google.com/file/d/1zNmTGD ... sp=sharing
Can I ignore it or should I try to remove it form the metadata?
LV8HD
Post by LV8HD » Fri Jan 03, 2025 10:58 am
@RESET_9999 if I try using the latest version of madVR the workflow 6-2 doesn't work. Why is this?
The version I downloaded comes from https://www.videohelp.com/software/madVR
Post by RESET_9999 » Fri Jan 03, 2025 2:31 pm
darrrkmanxxx wrote: Fri Jan 03, 2025 9:38 am Can I ignore it or should I try to remove it form the metadata?
run the xml/rpu in 6-2, it will tell you the first frame of the shot where this spike happens. I suspect there is a glitch in your video.
I don't know; I don't use the time-limited beta build. When they expire, they can break madmeasureHDR.exe.
I use the version included in the tool pack, the latest beta version before the time-limited ones.
darrrkmanxxx
Post by darrrkmanxxx » Fri Jan 03, 2025 8:59 pm
RESET_9999 wrote: Fri Jan 03, 2025 2:31 pm
your were right! It was a glitch. A real cool way btw to verify, thank you so much.
darrrkmanxxx
Post by darrrkmanxxx » Fri Jan 03, 2025 9:06 pm
@RESET_9999
Another question:
I have a remux which is profile 8, but has only cmv2.9
L1: https://drive.google.com/file/d/1jALIu_ ... p=drivesdk
Should I transfer thle levels (like in your profile 7), or just go straight for cm_analyze?
What would be superior?
Post by RESET_9999 » Fri Jan 03, 2025 11:49 pm
if there's a retail cmv4.0 RPU from streaming yes. Otherwise, it depends on whether the cmv2.9 rpu has trims or not.
deadchip12
Post by deadchip12 » Sat Jan 04, 2025 12:16 am
RESET_9999 wrote: Fri Jan 03, 2025 11:49 pm Otherwise, it depends on whether the cmv2.9 rpu has trims or not.
Could you elaborate on this? Which workflow to verify the web rpu has trims that the bluray does not?
Post by RESET_9999 » Sat Jan 04, 2025 12:24 am
(6-4) to plot the trims
valington
Post by valington » Sat Jan 04, 2025 11:45 am
RESET_9999 wrote: Sat Jan 04, 2025 12:24 am (6-4) to plot the trims
hallo reset is it good enough SEVEN with freman and pit from framestore hybrid 8 profile dolby vision or it s aggain fail from the framestore group and it s in cm4.0 or cm2.9 ?
darrrkmanxxx
Post by darrrkmanxxx » Sat Jan 04, 2025 12:41 pm
What exaclty should there be?
I used on workflow 6-4 on the example mentioned below (P8 Remux) here are the results:
If you have a few can you please take a look and myabe point out exaclty what should I look for and if this is worth of transferring genarted metadata?
Also how do I verify if FEL was baked in?
ps hope my questions will get less annoying once I start getting it :)
Post by RESET_9999 » Sat Jan 04, 2025 2:58 pm
valington wrote: Sat Jan 04, 2025 11:45 am hallo reset is it good enough SEVEN with freman and pit from framestore hybrid 8 profile dolby vision or it s aggain fail from the framestore group and it s in cm4.0 or cm2.9 ?
it looks ok.
cmv4.0
darrrkmanxxx wrote: Sat Jan 04, 2025 12:41 pm What exaclty should there be?
You can never transfer a generated cmv4.0 block into an original/retail cmv2.9 rpu
if the original cmv2.9 doesn't have any trims (or static ones), then you can completely discard the rpu and inject your generated cmv4.0 rpu
compare the encode with the original P7 rip in 7-2
darrrkmanxxx
Post by darrrkmanxxx » Sat Jan 04, 2025 4:06 pm
Sure, but what should I look for in my example. There are PNGs with L2 titles and there's some stuff in the graphs. Are those the trims?
Post by RESET_9999 » Sat Jan 04, 2025 4:11 pm
When 6-4 creates trims plot graph image(s), then yes your input contains trims...
if the graph is a straight line (like the Harry Potter movies), then it has static trims and you can discard the original RPU and use the cmv4.0 generated one.
daffie
Post by daffie » Sat Jan 04, 2025 4:13 pm
RESET_9999 wrote: Sat Jan 04, 2025 2:58 pm
it looks ok.
cmv4.0
So this Se7en framestore release with DoVi cm4.0 is actually better in terms of quality when compared with the HDR10 cm2.9 uhd retail bluray ?
LG OLED65G1RLA / Samsung HW-Q990D / Panasonic UB820 / Ugoos AM6B+ (CE with avdvplus Build)
Post by RESET_9999 » Sat Jan 04, 2025 4:19 pm
daffie wrote: Sat Jan 04, 2025 4:13 pm So this Se7en framestore release with DoVi cm4.0 is actually better in terms of quality when compared with the HDR10 cm2.9 uhd retail bluray ?
Well, 92% of the movie is under 600nits so pretty much all the TVs will be able to display it without tone mapping.
It shouldn't look much different than HDR10 playback unless you have a very low brightness TV/PJ.
The trim has a positive lift over 0.0025(2100) for the whole movie but it is ignored by all the HDMI devices.
