darrrkmanxxx
Post by darrrkmanxxx »
RESET_9999 wrote:
Wed Jan 01, 2025 9:18 pm
yes all cmv4.0 movies have cmv2.9 fallback metadata. Your G3 + CE device should support cmv4.0.
Don't I have to add a 800nit trim to the RPU to get the most brightness out of it?
All the trims(100-600-1000) work together and the metadata can be extrapolated to any target brightness.
Cool, what would be the best way to create dv from hdr10 cm_analyzer or davinci resolve?
My primary device is still the cmv2.9 Philips TV 65oled934.
What I want is to create cmv4.0 DV Profile 8 with most compatibility for my my old philips tv while future proof for device like LG G3 and up as I share content with multiple deolby vision devices.
darrrkmanxxx wrote:
Thu Jan 02, 2025 12:58 pm
CM is 100% automated but can be slow and relies on madvr for the scene-cut detection
Resolve is not automated but is much faster and has slightly better scene-cut detection.
darrrkmanxxx
RESET_9999 wrote:
Thu Jan 02, 2025 2:24 pm
got you, I trying out both now. I'm on macos, so I'm running windows in parallels and davinci on macos.
what about comatibility with cmv2.9, any difference there?
What is the use case for "Transfer RPU levels" workflow 2-3?
on MAC without my scripts, CM should be as fast as Resolve.
https://www.youtube.com/watch?v=RI_e-MPIPlw
darrrkmanxxx
RESET_9999 wrote:
Thu Jan 02, 2025 2:39 pm
awesome, every DV Bluray will have only cmv2.9, even the recent ones?
Lets take Alien Romulus, the L1 Plots look about the same. Would it still be beneficial to take the Web-Dl's Rpu or Transfer Levels?
Do all the checks as I did in the video and find out.
This title is probably missing(IIRC) from my ''okay to transfer'' list because I deleted the old sheet by mistake.
ColonelBlimp043
Post by ColonelBlimp043 »
I found a bug in the latest version of workflow 6-2 when using the CLI. When calculating the MaxCLL and MaxFALL threshold percentages, the CLI reports an "unrecognized arguments: -m over" error, and the percentages all read "0" on the plot. "HDR10 Plotter" works, however, in the GUI.
update your tool folder.
darrrkmanxxx
RESET_9999 wrote:
Thu Jan 02, 2025 11:07 pm
thats great news! Thanks for letting me know.
Meanwhile, I ran the workflow 3-1 on my windows machine and unfortunately it took forever since I have an AMD RX 6900 XT (no CUDA) :(, which I plotted afterwards and now there a 10000nit spike:
https://drive.google.com/file/d/1zNmTGD ... sp=sharing
Can I ignore it or should I try to remove it form the metadata?
LV8HD
Post by LV8HD »
@RESET_9999 if I try using the latest version of madVR the workflow 6-2 doesn't work. Why is this?
The version I downloaded comes from https://www.videohelp.com/software/madVR
darrrkmanxxx wrote:
Fri Jan 03, 2025 9:38 am
run the xml/rpu in 6-2, it will tell you the first frame of the shot where this spike happens. I suspect there is a glitch in your video.
I don't know; I don't use the time-limited beta build. When they expire, they can break madmeasureHDR.exe.
I use the version included in the tool pack, the latest beta version before the time-limited ones.
darrrkmanxxx
RESET_9999 wrote:
Fri Jan 03, 2025 2:31 pm
your were right! It was a glitch. A real cool way btw to verify, thank you so much.
darrrkmanxxx
@RESET_9999
Another question:
I have a remux which is profile 8, but has only cmv2.9
L1: https://drive.google.com/file/d/1jALIu_ ... p=drivesdk
Should I transfer thle levels (like in your profile 7), or just go straight for cm_analyze?
What would be superior?
if there's a retail cmv4.0 RPU from streaming yes. Otherwise, it depends on whether the cmv2.9 rpu has trims or not.
deadchip12
Post by deadchip12 »
RESET_9999 wrote:
Fri Jan 03, 2025 11:49 pm
Could you elaborate on this? Which workflow to verify the web rpu has trims that the bluray does not?
