Putting new MKV file on 4K disc
Reinmar
#1 Post by Reinmar » Fri Jan 03, 2025 3:14 am
Does anybody know if its possible to put a new mkv file (I added a audio track + subs) on the 4K disc I ripped it from?
Re: Putting new MKV file on 4K disc
#2 Post by Woodstock » Fri Jan 03, 2025 8:57 pm
You want to put a new file on a read-only disk? Seems to be an impossible request.
arxripper85
#3 Post by arxripper85 » Sat Jan 11, 2025 1:40 am
Unfortunately no, this is not possible, but you might be able to write the new mkv to a BDXL disc if your drive supports it.
The disc you ripped it from is a ROM (Read-Only Memory) disc, and was made by pressing microscopic pits and lands into the plastic of the disc itself.
However, there *is* software out there that claims to be able to copy a UHD/4K video file (such as an mkv) to a BDXL 100GB disc, though full disclosure I have no idea how well it works. It's called DVDfab iirc, might be worth a shot for your use-case :)
alexmorph3us
#4 Post by alexmorph3us » Sun Feb 16, 2025 4:34 pm
Use ImgBurn. Not only that it knows how to create a BD compliant image (even BD XL 100GB for 4K) that can be used for burning, but it's also free. It's the best software for burning all types of things.
