The Pioneer BD-RW-BDR-XS07TS Drive
danieboy
Post by danieboy »
Not sure if I have posted in the correct topic but,
I'm all new to this game and have just purchased a Pioneer BD-RW-BDR-XS07TS Drive, I have been reading up on the forums and I am well aware the current version I have at the moment 1.03 won't as I understand it rip UHD Disc. I am ok with that as I have a large DVD and Blu-Ray collection to backup so won't be going to UHD for some time.
However correct me if I am wrong but I should be able to rip blu-ray and DVDs correct?
I have place a DVD in the drive and it has come back with the following:-
P.S. It also created a dump file "dump_FW_D9592FA06360AC902362.tgz" Do you require this?
Spec of Pioneer (New Drive):-
Current profile: DVD-ROM
Manufacturer: PIONEER
Product: BD-RW BDR-XS07
Revision: 1.03
Serial number:...
Firmware date: 2023-01-06
Bus encryption flags: 13
Drive platform: Pioneer RS8E20
Firmware version: GENE
Disc Information
Label: BBCDVD2688
Timestamp: 2008-10-06 14:57:59
Protection: CSS/CPPM
Data capacity: 7.17 Gb
Disc type: DVD-ROM
Disc size: 120mm
Maximum read rate: 10.08 Mbps [1x]
Number of layers: 2 (OTP)
It's doing below :-
MakeMKV v1.17.8 win(x64-release) started
Calculated BUP offset for VTS #1 does not match one in IFO header.
Calculated BUP offset for VTS #2 does not match one in IFO header.
Complex multiplex encountered - 25 cells and 28408 VOBUs have to be scanned. This may take some time, please be patient - it can't be avoided.
It has finally read the disc and has come back with some interesting readings, firstly :-
Region setting of drive PIONEER:BD-RW BDR-XS07 does not match the region of currently inserted disc, trying to work around...
I purchased this Drive from Amazon UK and the Disc is a BBC UK DVD so the region should be correct??, Right??
I have also got Angle 1 and Angle 2 , not see that before? I just left it as default selection of angle 1. what is that?
When Ripping (Read Rate) the speeds was around 3X-4X 4-5M/s, I have it connected USB-C to USB-C.
I was expecting a little faster or does that sound about right?
Any help tips, trick or just pointing me in the right direction would be much appreciated.
Thanks.
Re: The Pioneer BD-RW-BDR-XS07TS Drive
danieboy wrote: Fri Jan 03, 2025 8:02 pm Hi,
Revision: 1.03
Serial number:...
Disc Information
Label: BBCDVD2688
Disc type: DVD-ROM
Disc size: 120mm
It's doing below :-
Thanks.
MakeMKV really isn't the best software for ripping DVD's. It can do it but there should be better software around for DVD's. Your drive should be fine ripping blu-ray discs.
