Verbatim 43888 (Pioneer BDR-UD04) not working with UHD 4K?
wailo
Post by wailo »
Hello dear community,
first of all, a happy new year.
I have an issue playing 4K UHD discs with the Verbatim 43888 (Pioneer BDR-UD04).
Here it was mentioned that all drives built after December 2022 won't (currently) work
viewtopic.php?style=10&p=164492#p164492
My drives firmware version is 1.14 and seems to be from 2020-06-15.
So it should work.(?)
Here the complete info:
Manufacturer: PIONEER
Product: BD-RW BDR-UD04
Revision: 1.14
Serial number: XXXXXXXXXX
Firmware date: 2020-06-15
Highest AACS version: 76
Drive platform: RS8A10
Firmware version: 1.14
Disc Information
Label: LOTR_FELLOWSHIP_OF_THE_RING_P1
Timestamp: 2020-10-29 19:40:43
Protection: AACS2.0/C v76
Data capacity: 93.22 Gb
Disc type: BD-ROM UHD
Number of layers: 3
Bus encryption flags: 80
Here the output of MakeMKV:
(had to skip some of that output)
Error 'Scsi error - ILLEGAL REQUEST:CANNOT WRITE MEDIUM - INCOMPATIBLE FORMAT' occurred while issuing SCSI command A30..0020..03F to device 'SPTI:\Device\CdRom0'
[...] I skipped some output here because of maximum allowed characters, was the same as above just with different values for the one which comes after "command", like A40..0020..0FF
Error 'Scsi error - ILLEGAL REQUEST:CANNOT WRITE MEDIUM - INCOMPATIBLE FORMAT' occurred while issuing SCSI command A40..002000800 to device 'SPTI:\Device\CdRom0'
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT ESTABLISHED' occurred while issuing SCSI command AD010..080002400 to device 'SPTI:\Device\CdRom0'
Error 'Scsi error - ILLEGAL REQUEST:CANNOT WRITE MEDIUM - INCOMPATIBLE FORMAT' occurred while issuing SCSI command A40..0020..03F to device 'SPTI:\Device\CdRom0'
Error 'Scsi error - ILLEGAL REQUEST:CANNOT WRITE MEDIUM - INCOMPATIBLE FORMAT' occurred while issuing SCSI command A30..0020..07F to device 'SPTI:\Device\CdRom0'
Error 'Scsi error - ILLEGAL REQUEST:CANNOT WRITE MEDIUM - INCOMPATIBLE FORMAT' occurred while issuing SCSI command A40..0020..07F to device 'SPTI:\Device\CdRom0'
Error 'Scsi error - ILLEGAL REQUEST:CANNOT WRITE MEDIUM - INCOMPATIBLE FORMAT' occurred while issuing SCSI command A30..0020..0BF to device 'SPTI:\Device\CdRom0'
Error 'Scsi error - ILLEGAL REQUEST:CANNOT WRITE MEDIUM - INCOMPATIBLE FORMAT' occurred while issuing SCSI command A40..0020..0BF to device 'SPTI:\Device\CdRom0'
Error 'Scsi error - ILLEGAL REQUEST:CANNOT WRITE MEDIUM - INCOMPATIBLE FORMAT' occurred while issuing SCSI command A30..0020..0FF to device 'SPTI:\Device\CdRom0'
Error 'Scsi error - ILLEGAL REQUEST:CANNOT WRITE MEDIUM - INCOMPATIBLE FORMAT' occurred while issuing SCSI command A40..0020..0FF to device 'SPTI:\Device\CdRom0'
Downloading latest HK to C:\Users\MyUser/.MakeMKV ...
Saved AACS dump file as C:\Users\MyUser/.MakeMKV/MKB20_v76_The_Lord_of_the_Rings-_The_Fellowship_of_the_Ring_(EXT_)_PT_1_B275.tgz
I thought the Verbatim 43888 with the Pioneer BDR-UD04 would work for UHD 4K.(?)
For normal Blu-Rays it works, but not for the 4K ones.
I ran MakeMKV for one normal Blu-Ray, which worked just fine.
Then the 4K ones:
- Fellowship of the ring Extended Part 1, Part 2 and the cinema version
- Two towers Extended Part 1, Part 2 and the cinema version
For none of these 4K ones did it work.
This was all done in Windows 11.
What I have done before:
In Linux I configured VLC to play Blu-Rays with this guide:
https://forum.videolan.org/viewtopic.ph ... 21#p548219
Worked for normal ones but for the 4K ones I got some AACS error.
For Windows I used the guide from here:
vlc-bluray.whoknowsmy.name
to play Blu-Rays, but again:
Normal ones work, 4K don't.
Now MakeMKV, as I thought, was my last straw to get them to work, but it seems 4K still not works...
I don't know if it's worth mentioning, but it was the lotr extended 4K version from 17.12.2020 amazon.de/dp/B08KHWNPTC.
Any ideas how to get those Blu-Rays to play on my PC?
Do you need additional info?
Thanks in advance for reading through all that.
Re: Verbatim 43888 (Pioneer BDR-UD04) not working with UHD 4K?
wailo wrote: Fri Jan 03, 2025 10:03 am Hello dear community,
Revision: 1.14
Disc Information
Number of layers: 3
Then the 4K ones:
Yes, your drive is UHD compatible out of the box. Playback can be done but isn't really a needed feature for most of us. For 99% of us, we want to rip them and play the MKV file, not play the discs!! I don't use Linux so can't help with that.
Anyway, here are the important steps to always follow:
1. Even if it looks pristine, give the disc a good clean!! (Especially the LotR discs as they are notoriously terrible quality)
2. Ensure you let the OS initialize the disc before opening the MakeMKV application
wailo
Post by wailo »
MartyMcNuts wrote: Sat Jan 04, 2025 12:46 am
Yes this was the solution, thank you very much.
Yesterday, in the meantime my post was under approval, I searched the forum a bit deeper and found that soltion here:
viewtopic.php?p=165422#p165422
But thank you anyway.
I wanted to edit my post and share that solution, but my post wasn't visible to me.
I will keep it in mind from now on:
Inserting the 4K Blu-Ray first into the drive and then opening MakeMKV when the system already recognized the disc.
This worked and no errors were thrown.
What I also experienced, it's probably not that interesting because your solution worked, but I thought it might be worth mentioning:
Ejecting the disc via the eject disc action, then putting in part 2. While MakeMKV is still open, the disc will not be recognized by the PC, in e.g. explorer.
Closing MakeMKV and then inserting the disc does not help, the disc is still not recognized by the system. Windows explorer might not responding and had to restarted.
System still not reading the disc.
Tried then Fellowship part 1 again, system recognized it.
Tried then Fellowship part 2 and it also got recognized.
Started then MakeMKV again and it could read it and show me the titles.
