Do all the checks as I did in the video and find out.
This title is probably missing(IIRC) from my ''okay to transfer'' list because I deleted the old sheet by mistake.
ColonelBlimp043
I found a bug in the latest version of workflow 6-2 when using the CLI. When calculating the MaxCLL and MaxFALL threshold percentages, the CLI reports an "unrecognized arguments: -m over" error, and the percentages all read "0" on the plot. "HDR10 Plotter" works, however, in the GUI.
update your tool folder.
darrrkmanxxx
thats great news! Thanks for letting me know.RESET_9999 wrote: Thu Jan 02, 2025 11:07 pm Do all the checks as I did in the video and find out.
Meanwhile, I ran the workflow 3-1 on my windows machine and unfortunately it took forever since I have an AMD RX 6900 XT (no CUDA)
https://drive.google.com/file/d/1zNmTGD ... sp=sharing
Can I ignore it or should I try to remove it form the metadata?
@RESET_9999 if I try using the latest version of madVR the workflow 6-2 doesn't work. Why is this?
The version I downloaded comes from https://www.videohelp.com/software/madVR
run the xml/rpu in 6-2, it will tell you the first frame of the shot where this spike happens. I suspect there is a glitch in your video.darrrkmanxxx wrote: Fri Jan 03, 2025 9:38 am Can I ignore it or should I try to remove it form the metadata?
I don't know; I don't use the time-limited beta build. When they expire, they can break madmeasureHDR.exe.@RESET_9999 if I try using the latest version of madVR the workflow 6-2 doesn't work. Why is this?
I use the version included in the tool pack, the latest beta version before the time-limited ones.
darrrkmanxxx
your were right! It was a glitch. A real cool way btw to verify, thank you so much.RESET_9999 wrote: Fri Jan 03, 2025 2:31 pmrun the xml/rpu in 6-2, it will tell you the first frame of the shot where this spike happens. I suspect there is a glitch in your video.darrrkmanxxx wrote: Fri Jan 03, 2025 9:38 am Can I ignore it or should I try to remove it form the metadata?
darrrkmanxxx
@RESET_9999
Another question:
I have a remux which is profile 8, but has only cmv2.9
L1: https://drive.google.com/file/d/1jALIu_ ... p=drivesdk
Should I transfer thle levels (like in your profile 7), or just go straight for cm_analyze?
What would be superior?
Another question:
if there's a retail cmv4.0 RPU from streaming yes. Otherwise, it depends on whether the cmv2.9 rpu has trims or not.
deadchip12
Could you elaborate on this? Which workflow to verify the web rpu has trims that the bluray does not?RESET_9999 wrote: Fri Jan 03, 2025 11:49 pm Otherwise, it depends on whether the cmv2.9 rpu has trims or not.
(6-4) to plot the trims
hallo reset is it good enough SEVEN with freman and pit from framestore hybrid 8 profile dolby vision or it s aggain fail from the framestore group and it s in cm4.0 or cm2.9 ?
darrrkmanxxx
What exaclty should there be?
I used on workflow 6-4 on the example mentioned below (P8 Remux) here are the results:
If you have a few can you please take a look and myabe point out exaclty what should I look for and if this is worth of transferring genarted metadata?
Also how do I verify if FEL was baked in?
ps hope my questions will get less annoying once I start getting it
it looks ok.valington wrote: Sat Jan 04, 2025 11:45 am hallo reset is it good enough SEVEN with freman and pit from framestore hybrid 8 profile dolby vision or it s aggain fail from the framestore group and it s in cm4.0 or cm2.9 ?
cmv4.0
You can never transfer a generated cmv4.0 block into an original/retail cmv2.9 rpudarrrkmanxxx wrote: Sat Jan 04, 2025 12:41 pm What exaclty should there be?
if the original cmv2.9 doesn't have any trims (or static ones), then you can completely discard the rpu and inject your generated cmv4.0 rpu
compare the encode with the original P7 rip in 7-2Also how do I verify if FEL was baked in?
darrrkmanxxx
Sure, but what should I look for in my example. There are PNGs with L2 titles and there's some stuff in the graphs. Are those the trims?You can never transfer a generated cmv4.0 block into an original/retail cmv2.9 rpu
