Thank you so much for making it available again!RESET_9999 wrote: ↑Tue Dec 31, 2024 1:29 pmYeah, I'm stupid. I was making space in my Google Drive and deleted a folder that contained the Excel sheet. I did a backup recently, so only one month of data is missing.voodoomamajuju wrote: ↑Tue Dec 31, 2024 12:59 am@RESET_9999 Just wanted to say thanks for the Dolby_vision_stuff sheet but I just noticed that the link is broken. Is the sheet hosted somewhere else now? Thanks again!
the new link in my signature should work
Cool, what would be the best way to create dv from hdr10 cm_analyzer or davinci resolve?RESET_9999 wrote: ↑Wed Jan 01, 2025 9:18 pmyes all cmv4.0 movies have cmv2.9 fallback metadata. Your G3 + CE device should support cmv4.0.
All the trims(100-600-1000) work together and the metadata can be extrapolated to any target brightness.Don't I have to add a 800nit trim to the RPU to get the most brightness out of it?
My primary device is still the cmv2.9 Philips TV 65oled934.
What I want is to create cmv4.0 DV Profile 8 with most compatibility for my my old philips tv while future proof for device like LG G3 and up as I share content with multiple deolby vision devices.
CM is 100% automated but can be slow and relies on madvr for the scene-cut detectiondarrrkmanxxx wrote: ↑Thu Jan 02, 2025 12:58 pmCool, what would be the best way to create dv from hdr10 cm_analyzer or davinci resolve?
Resolve is not automated but is much faster and has slightly better scene-cut detection.
got you, I trying out both now. I'm on macos, so I'm running windows in parallels and davinci on macos.RESET_9999 wrote: ↑Thu Jan 02, 2025 2:24 pmCM is 100% automated but can be slow and relies on madvr for the scene-cut detectiondarrrkmanxxx wrote: ↑Thu Jan 02, 2025 12:58 pmCool, what would be the best way to create dv from hdr10 cm_analyzer or davinci resolve?
what about comatibility with cmv2.9, any difference there?
What is the use case for "Transfer RPU levels" workflow 2-3?
on MAC without my scripts, CM should be as fast as Resolve.
https://www.youtube.com/watch?v=RI_e-MPIPlwWhat is the use case for "Transfer RPU levels" workflow 2-3?
awesome, every DV Bluray will have only cmv2.9, even the recent ones?RESET_9999 wrote: ↑Thu Jan 02, 2025 2:39 pmon MAC without my scripts, CM should be as fast as Resolve.
Lets take Alien Romulus, the L1 Plots look about the same. Would it still be beneficial to take the Web-Dl's Rpu or Transfer Levels?
Do all the checks as I did in the video and find out.
This title is probably missing(IIRC) from my ''okay to transfer'' list because I deleted the old sheet by mistake.
I found a bug in the latest version of workflow 6-2 when using the CLI. When calculating the MaxCLL and MaxFALL threshold percentages, the CLI reports an "unrecognized arguments: -m over" error, and the percentages all read "0" on the plot. "HDR10 Plotter" works, however, in the GUI.
update your tool folder.
thats great news! Thanks for letting me know.RESET_9999 wrote: ↑Thu Jan 02, 2025 11:07 pmDo all the checks as I did in the video and find out.
Meanwhile, I ran the workflow 3-1 on my windows machine and unfortunately it took forever since I have an AMD RX 6900 XT (no CUDA)
https://drive.google.com/file/d/1zNmTGD ... sp=sharing
Can I ignore it or should I try to remove it form the metadata?
@RESET_9999 if I try using the latest version of madVR the workflow 6-2 doesn't work. Why is this?
The version I downloaded comes from https://www.videohelp.com/software/madVR
run the xml/rpu in 6-2, it will tell you the first frame of the shot where this spike happens. I suspect there is a glitch in your video.darrrkmanxxx wrote: ↑Fri Jan 03, 2025 9:38 amCan I ignore it or should I try to remove it form the metadata?
I don't know; I don't use the time-limited beta build. When they expire, they can break madmeasureHDR.exe.@RESET_9999 if I try using the latest version of madVR the workflow 6-2 doesn't work. Why is this?
I use the version included in the tool pack, the latest beta version before the time-limited ones.
your were right! It was a glitch. A real cool way btw to verify, thank you so much.RESET_9999 wrote: ↑Fri Jan 03, 2025 2:31 pmrun the xml/rpu in 6-2, it will tell you the first frame of the shot where this spike happens. I suspect there is a glitch in your video.darrrkmanxxx wrote: ↑Fri Jan 03, 2025 9:38 amCan I ignore it or should I try to remove it form the metadata?
@RESET_9999
Another question:
I have a remux which is profile 8, but has only cmv2.9
L1: https://drive.google.com/file/d/1jALIu_ ... p=drivesdk
Should I transfer thle levels (like in your profile 7), or just go straight for cm_analyze?
What would be superior?
Another question:
if there's a retail cmv4.0 RPU from streaming yes. Otherwise, it depends on whether the cmv2.9 rpu has trims or not.
