BDR-XD07B UHD Flash
skrubbles
BDR-XD07B UHD Flash
Post by skrubbles » Thu Aug 01, 2024 11:24 pm
I recently got a BDR-XD07B off of Ebay. Is it possible to flash this to enable UHD?
OS device name: /dev/rdisk2
Manufacturer: PIONEER
Product: BD-RW BDR-XD07
Revision: 1.02
Serial number:
Firmware date: 2019-09-05
Bus encryption flags: 13
Highest AACS version: 65
Drive platform: RS8D30
Firmware version: 1.02
Re: BDR-XD07B UHD Flash
Post by Coopervid » Fri Aug 02, 2024 9:00 am
skrubbles wrote: Thu Aug 01, 2024 11:24 pm I recently got a BDR-XD07B off of Ebay. Is it possible to flash this to enable UHD?
Revision: 1.02
Serial number:
Raed the PM I will send to you.
skrubbles
Post by skrubbles » Sat Aug 03, 2024 2:00 am
Coopervid wrote: Fri Aug 02, 2024 9:00 am Raed the PM I will send to you.
Thank you! Just finished flashing and everything seems to work :)
Phillipino
Post by Phillipino » Tue Dec 31, 2024 6:31 pm
I have this same drive too! can it be made to work with 4K UHD as well? or is that the same as UHD? Please PM Me as well!
Post by Coopervid » Tue Dec 31, 2024 7:47 pm
Phillipino wrote: Tue Dec 31, 2024 6:31 pm I have this same drive too! can it be made to work with 4K UHD as well? or is that the same as UHD? Please PM Me as well!
You need to post your Makemkv info.
Phillipino
Post by Phillipino » Thu Jan 02, 2025 6:39 am
Coopervid wrote: Tue Dec 31, 2024 7:47 pm
Forgive me, I'm still new. Is this the information that's on the bottom label of the drive? Or am I able to pull this info from elsewhere?
Post by Coopervid » Thu Jan 02, 2025 2:02 pm
Phillipino wrote: Thu Jan 02, 2025 6:39 am
Install and run Makemkv. Then copy & paste the text it shows about your drive in your next post.
Phillipino
Post by Phillipino » Fri Jan 03, 2025 9:15 am
OS device name: E:
Revision: 1.02
Serial number:
Highest AACS version: 81
Here's what I have!
Chewey182
Post by Chewey182 » Sat Jan 04, 2025 12:29 pm
OS device name: E:
Revision: 1.03
Serial number: ...
Firmware date: 2020-08-20
Firmware version: 1.03
me too! :D
RexRazor
Post by RexRazor » Wed Jan 08, 2025 12:07 am
I owned this drive for a few years now. I'm wondering what it will take to make it work to read UHD? Blu-ray disk works just fine. Any help would be greatly appreciated!
Revision: 1.02
Serial number: ...
Post by Coopervid » Wed Jan 08, 2025 10:57 am
Phillipino wrote: Fri Jan 03, 2025 9:15 am OS device name: E:
Revision: 1.02
Serial number:
Here's what I have!
PM sent.
Post by Coopervid » Wed Jan 08, 2025 10:59 am
RexRazor wrote: Wed Jan 08, 2025 12:07 am I owned this drive for a few years now. I'm wondering what it will take to make it work to read UHD? Blu-ray disk works just fine. Any help would be greatly appreciated!
Revision: 1.02
Serial number: ...
PM sent.
Cush1978
Post by Cush1978 » Tue Jan 14, 2025 9:44 pm
I think I'm in the same boat here:
OS device name: E:
Revision: 1.03
Serial number: ...
Post by Coopervid » Tue Jan 14, 2025 10:31 pm
Cush1978 wrote: Tue Jan 14, 2025 9:44 pm I think I'm in the same boat here:
OS device name: E:
Revision: 1.03
Serial number: ...
Your boat is floating.
LordBrandon
Post by LordBrandon » Wed Jan 15, 2025 1:24 am
So it looks like I was fortunate enough to buy a drive that can support UHD disks, but it seems I need help in order for it to do so.
Is there someone who can help me to get it working?
OS device name: H:
Revision: 1.03
Serial number: ---
Highest AACS version: 56
I took out the serial number but can give it if needed.
Brandon
