Attempting to flash in macOS
Re: Attempting to flash in macOS
#76 Post by MartyMcNuts » Wed Mar 06, 2024 11:19 pm
eMouse wrote: Wed Mar 06, 2024 10:42 pm I'll run the latest OS update and see if it changes anything.
I had to re-download MakeMKV, so it is the latest version of that.
The drive is plugged into a USB hub, which is then plugged into the Mac. It's a Mac mini, and the drive requires two USB ports, so plugging it directly into the Mac isn't really an option.
If necessary, I can connect the drive to a windows machine, but this Mac is what I use 90% of the time.
If using a USB hub, make sure it is a powered one, not one that gets power from a USB port.
It would be quicker and easier to connect it to a Windows PC for flashing purposes as it only takes a minute.
eMouse
#77 Post by eMouse » Thu Mar 07, 2024 1:57 pm
I updated to the latest version of Sonoma. Still have the same issue where it doesn't show a usable identifier for the drive. I'm going to guess that Sonoma changed something about how that identifier is obtained and MakeMKV hasn't updated to handle that change yet.
Ended up flashing it with the visual flasher on Windows.
absent2999
#78 Post by absent2999 » Fri Dec 20, 2024 6:33 pm
Hi there, been trying on a Mac for awhile and having no luck. Keep getting the same error, no matter what firmware I try. And I feel like I've tried them all. Here's what I see in terminal:
Reading input file /tmp/HL-DT-ST-BD-RE_WH16NS40-NS50-1.05-NM00900-212005061440.bin
Current Drive ID: HL-DT-ST_BD-RE__WH16NS40_1.05_212005061440_M00MAEC4935
yes
6% ...
Write DRAM NG 04/08/03
Command produced error code 0x82040803
I get that same Write Dram and error code every time, regardless of firmware. Is there an obvious step I'm missing?
#79 Post by dcoke22 » Fri Dec 20, 2024 11:06 pm
absent2999 wrote: Fri Dec 20, 2024 6:33 pm Hi there, been trying on a Mac for awhile and having no luck. Keep getting the same error, no matter what firmware I try. And I feel like I've tried them all. Here's what I see in terminal:
yes
6% ...
What command are you using in terminal?
#80 Post by Billycar11 » Sat Dec 21, 2024 5:26 am
yes
6% ...
what your doing should work so issue is probably the usb to sata adapter
what adapter do you have?
absent2999
#81 Post by absent2999 » Wed Jan 01, 2025 7:07 pm
Billycar11 wrote: Sat Dec 21, 2024 5:26 am
I'm not sure what you mean by what adapter... I just have the usb cable from my enclosure to my Mac?
But I just tried this on a different drive, the BP50NB40, which just has a usb from the drive to the Mac, and I get the same error. Is there a different cable I should be using?
I never have trouble ripping blu rays with either of these drives, just trying to get started ripping 4k discs.
#82 Post by Billycar11 » Wed Jan 01, 2025 9:37 pm
absent2999 wrote: Wed Jan 01, 2025 7:07 pm
What case do you have I'm asking
The bp50 should definitely be able to be flashed what fw did you try on that? Well unless it's nb72
absent2999
#83 Post by absent2999 » Wed Jan 01, 2025 10:30 pm
Billycar11 wrote: Wed Jan 01, 2025 9:37 pm
Thank you for your help!
For the WH case, I don't know what case actually. It's an old generic case I got from a used computer store, so maybe that's the problem.
But for the BP50, it's NB52. This is what it says when I open MakeMKV
Product: BD-RE BP50NB40
Revision: 1.03
Serial number: ...
Firmware date: 2121-07-08 16:03
Highest AACS version: 81
Harware support: Yes
Firmware support: No
Firmware version: 1.03
And this is the error I get in Mac terminal:
Reading input file /tmp/DE_LG_BP60NB10_1.00_MK_HBD.bin
Current Drive ID: HL-DT-ST_BD-RE_BP50NB40_1.03_212107081603_SIM2222MK0421
Using USB chipset workaround for Desktop drive handshake
yes
98% .................................................
Write DRAM NG 05/24/00
Command produced error code 0x82052400
absent2999
#84 Post by absent2999 » Wed Jan 01, 2025 10:49 pm
Okay well actually I think I was able to get it to work on my BP50, I must have been using the wrong firmware in my last go round.
In Terminal, this is what happened:
Current Drive ID: HL-DT-ST_BD-RE_BP50NB40_1.03_212005070917_SIM2222MK0421
yes
100% Operation finished
Done successfully
MakeMKV now shows this:
Revision: 1.03
Serial number: ...
Currently ripping a disc now!
#85 Post by Coopervid » Wed Jan 01, 2025 11:03 pm
Your enclosure for the full size drive doesn't support flashing. Connect it to SATA with a desktop PC. And the slim drive has been flashed before as ist doesn't report to be what you tried to flash.
ThatGuyName
#86 Post by ThatGuyName » Wed Jan 22, 2025 5:03 pm
I'm still having a problem with actually flashing it. everything goes swell until the last step when it gives me the error:
"Input file not found -- /HL-DT-ST-BD-RE_BP60NB10-1.02-NM00800-212005070935
Internal error 0x83000001"
It also wont let me make a tmp folder for some reason?
"zsh: permission denied: /tmp"
#87 Post by dcoke22 » Thu Jan 23, 2025 4:36 pm
ThatGuyName wrote: Wed Jan 22, 2025 5:03 pm I'm still having a problem with actually flashing it. everything goes swell until the last step when it gives me the error:
Where did you put the firmware file you're trying to flash into your drive? Is it in a folder on your Desktop? Or perhaps in your Downloads folder?
Wherever it is, when you're typing the command in Terminal to perform the flash (aka Step 7 in the Mac/linux commands to flash in the Guide) when you get to the spot where you're supposed to type the firmware filename… don't type it, find the file in Finder and drag it into Terminal. Terminal will put the fully qualified pathname to the file wherever the cursor is in Terminal.
You can do the same thing for sdf.bin.
When the instructions in the Guide say, in step 4, to copy sdf.bin and the firmware file into /tmp, what it means is "put those two files into a temporary folder of your choosing." Later, when the commands reference '/tmp/sdf.bin' for example, what it means is "put the fully qualified path to the file here." On a Mac, the easiest way to do this is to drag & drop the relevant file from Finder into Terminal and it'll do the right thing.
The /tmp shorthand comes to us from Ye Olden Days™, before the internet existed and before the Mac was invented. Back then there really was a folder named 'tmp' at the root of the filesystem and you really could copy things there temporarily. As operating systems got more complicated and security got better, /tmp more or less disappeared or became hard to use but the shorthand of /tmp survives because 4 characters is way easier to type than the two paragraphs I've got here. :)
ThatGuyName
#88 Post by ThatGuyName » Fri Jan 24, 2025 12:10 am
dcoke22 wrote: Thu Jan 23, 2025 4:36 pm
So in the command where it says "/tmp" do I also replace that with the name of my chosen folder?
Or do I drag the folder whenever it says "tmp"? I've tried both ways and it's still not working. Do I have to put the two files into a folder or no? and If I choose not two what do I replace /tmp with? Desktop?
If my folder is named "rio" and it's in desktop, then is this correct:
./makemkvcon f -d '/IOBDServices/D5D25996' -f /Users/NAME/Desktop/rio/sdf.bin rawflash enc -i/Users/NAME/Desktop/rio/Users/NAME/Desktop/rio/HL-DT-ST-BD-RE_BP60NB10-1.02-NM00800-212005070935.bin ?
#89 Post by dcoke22 » Fri Jan 24, 2025 7:37 am
ThatGuyName wrote: Fri Jan 24, 2025 12:10 am So in the command where it says "/tmp" do I also replace that with the name of my chosen folder?
Where is says '/tmp/sdf.bin' in the command, drag the sdf.bin file into Terminal. And then for the part where the firmware goes, drag the firmware file into Terminal.
./makemkvcon f -d '/IOBDServices/D5D25996' -f /Users/NAME/Desktop/rio/sdf.bin rawflash enc -i /Users/NAME/Desktop/rio/HL-DT-ST-BD-RE_BP60NB10-1.02-NM00800-212005070935.bin
As a sidenote, you have to do step 6 and substitute your actual drive identifier into the correct spot in command used in step 7. The one in your command is the same as the example, which is very unlikely. :)
ThatGuyName
#90 Post by ThatGuyName » Fri Jan 24, 2025 5:34 pm
dcoke22 wrote: Fri Jan 24, 2025 7:37 am
ah, I see. sorry about that. I'll try again.
EDIT: IT WORKS!!!!! thanks so much. Sorry about all that. I'm not really good with terminal I'm more of an editing guy.
