Pioneer BD-RW BDR-XD07 - Troubleshooting 4kUHD discs not reading
corral9494
Re: Pioneer BD-RW BDR-XD07 - Troubleshooting 4kUHD discs not reading
#61 Post by corral9494 » Wed Dec 18, 2024 3:44 am
hi all,
first time poster but not new to makemkv.. i've had this same drive fr awhile and i would also like to get it working w/ uhd.. would someone be willing to help? thank u much in advance
OS device name: /dev/sr0
Manufacturer: PIONEER
Product: BD-RW BDR-XD07
Revision: 1.03
Serial number: <redacted>
Firmware date: 2020-08-20
Bus encryption flags: 13
Highest AACS version: 81
Drive platform: RS8D30
Firmware version: 1.03
#62 Post by Coopervid » Wed Dec 18, 2024 10:26 am
axone wrote: Tue Dec 17, 2024 9:31 pm Hi, I also would like to get the 4k up and running.
my drive infos are the following:
Revision: 1.03
Serial number: [redacted]
PM sent.
axone
#63 Post by axone » Mon Dec 23, 2024 8:19 am
Coopervid wrote: Wed Dec 18, 2024 10:26 am
Revision: 1.03
PM sent.
Works perfectly, thank you very much.
werdiknight
#64 Post by werdiknight » Sat Dec 28, 2024 11:06 pm
Hi Coopervid,
same problem here. I'd also like to get 4k going (I actually just now realized I couldn't use them when I already bought some... :( )
Makemkv is installed, here are the drive infos:
OS device name: E:
Revision: 1.03
Serial number: ...
Would you be so kind to also send me your PM? Would be greatly appreciated. :)
werdiknight
#65 Post by werdiknight » Tue Dec 31, 2024 2:45 am
After reading more and more into it I first thought I'd just needed the fitting firmware (but didn't know which).... until finally noticing that it wouldn't work anyway. I have a dGPU and AMD CPU which I'm not changing - so unfortunately there is that... :(
#66 Post by Coopervid » Tue Dec 31, 2024 9:22 pm
werdiknight wrote: Tue Dec 31, 2024 2:45 am After reading more and more into it I first thought I'd just needed the fitting firmware (but didn't know which).... until finally noticing that it wouldn't work anyway. I have a dGPU and AMD CPU which I'm not changing - so unfortunately there is that... :(
WTF you are talking about? All you need is a Windows PC that is not based on ARM.
werdiknight
#67 Post by werdiknight » Wed Jan 01, 2025 3:51 am
Coopervid wrote: Tue Dec 31, 2024 9:22 pm
Read this somewhere. I have a Windows PC. Maybe I could just try it?
#68 Post by Coopervid » Wed Jan 01, 2025 6:26 pm
werdiknight wrote: Wed Jan 01, 2025 3:51 am
You have a typo in your forum name. Should be weirdknight... :D :D . You have a PM. And let me know where you have read that BS you posted above.
werdiknight
#69 Post by werdiknight » Thu Jan 02, 2025 6:11 am
I'm very sorry... I am ABSOLUTELY new to all of this so I cannot judge what is wrong or what is right from the getgo. And to be honest, it's not the time in my life at the moment to read dozens of hours through a topic I don't know nothing about... soooo, when I read something that COULD be true it may be just that at first glance. It was CyberLink BluRay Advisor (an analytics tool) which told me that my PC like mentioned above is not able to read UHDs, no matter which BD-Player I used.
Thanks for the PM, I may test it these days and let you know of the result. The flashing seemed to have worked but unfortunately I haven't any 4k Discs here anymore to test it right away.
VincentVega
#70 Post by VincentVega » Thu Jan 02, 2025 3:24 pm
Hey there,
first-time-poster aswell. Started archieving my BD-Collection several month ago. Everything worked fine till I got to my UHD. After reading in this forum, I bought the following drive with an older firmware, hoping that it would work out of the box. Unfortunatly that is not the case, so I am looking for help :D
Laufwerksinformation
OS-Gerätename: G:
Produzent: PIONEER
Produkt: BD-RW BDR-XD07
Revision: 1.03
Serienummer: ***
Firmware-Datum: 2020-08-20
Markierungen der Bus-Verschlüsselung: 13
Highest AACS version: 78
Keine Disk eingelegt
galkern
#71 Post by galkern » Thu Jan 02, 2025 11:34 pm
Hello Coopervid, I have the following:
Revision: 1.03
Serial number: ...
Is there any way you could help me get UHD working?
#72 Post by Coopervid » Fri Jan 03, 2025 4:58 pm
VincentVega wrote: Thu Jan 02, 2025 3:24 pm Hey there,
OS-Gerätename: G:
Produzent: PIONEER
Revision: 1.03
Serienummer: ***
PM is coming.
#73 Post by Coopervid » Fri Jan 03, 2025 5:00 pm
galkern wrote: Thu Jan 02, 2025 11:34 pm Hello Coopervid, I have the following:
Revision: 1.03
Serial number: ...
PM is coming.
VincentVega
#74 Post by VincentVega » Fri Jan 03, 2025 10:04 pm
Works perfectly! Thank you very much, Coopervid :wink:
galkern
#75 Post by galkern » Fri Jan 03, 2025 11:53 pm
Coopervid wrote: Fri Jan 03, 2025 5:00 pm
Revision: 1.03
Serial number: ...
PM is coming.
Thank you Coopervid! Worked without a hitch. I even installed it via a Windows 11 vm on Fedora 41, no issues! You rock!
