BDR-XD07B UHD Flash
skrubbles
BDR-XD07B UHD Flash
I recently got a BDR-XD07B off of Ebay. Is it possible to flash this to enable UHD?
OS device name: /dev/rdisk2
Manufacturer: PIONEER
Product: BD-RW BDR-XD07
Revision: 1.02
Serial number:
Firmware date: 2019-09-05
Bus encryption flags: 13
Highest AACS version: 65
Drive platform: RS8D30
Firmware version: 1.02
Revision: 1.02
Serial number:
Re: BDR-XD07B UHD Flash
Raed the PM I will send to you.skrubbles wrote: Thu Aug 01, 2024 11:24 pm I recently got a BDR-XD07B off of Ebay. Is it possible to flash this to enable UHD?
Revision: 1.02
Serial number:
skrubbles
Thank you! Just finished flashing and everything seems to work
Phillipino
I have this same drive too! can it be made to work with 4K UHD as well? or is that the same as UHD? Please PM Me as well!
You need to post your Makemkv info.Phillipino wrote: Tue Dec 31, 2024 6:31 pm I have this same drive too! can it be made to work with 4K UHD as well? or is that the same as UHD? Please PM Me as well!
Phillipino
Forgive me, I'm still new. Is this the information that's on the bottom label of the drive? Or am I able to pull this info from elsewhere?Coopervid wrote: Tue Dec 31, 2024 7:47 pmYou need to post your Makemkv info.Phillipino wrote: Tue Dec 31, 2024 6:31 pm I have this same drive too! can it be made to work with 4K UHD as well? or is that the same as UHD? Please PM Me as well!
Install and run Makemkv. Then copy & paste the text it shows about your drive in your next post.Phillipino wrote: Thu Jan 02, 2025 6:39 amForgive me, I'm still new. Is this the information that's on the bottom label of the drive? Or am I able to pull this info from elsewhere?Coopervid wrote: Tue Dec 31, 2024 7:47 pmYou need to post your Makemkv info.Phillipino wrote: Tue Dec 31, 2024 6:31 pm I have this same drive too! can it be made to work with 4K UHD as well? or is that the same as UHD? Please PM Me as well!
Phillipino
OS device name: E:
Revision: 1.02
Serial number:
Highest AACS version: 81
Here's what I have!
Revision: 1.02
Serial number:
Here's what I have!
Chewey182
OS device name: E:
Revision: 1.03
Serial number: ...
Firmware date: 2020-08-20
Firmware version: 1.03
me too!
OS device name: E:
Revision: 1.03
Serial number: ...
me too!
RexRazor
I owned this drive for a few years now. I'm wondering what it will take to make it work to read UHD? Blu-ray disk works just fine. Any help would be greatly appreciated!
Revision: 1.02
Serial number: ...
Revision: 1.02
Serial number: ...
PM sent.Phillipino wrote: Fri Jan 03, 2025 9:15 am OS device name: E:
Revision: 1.02
Serial number:
Here's what I have!
PM sent.RexRazor wrote: Wed Jan 08, 2025 12:07 am I owned this drive for a few years now. I'm wondering what it will take to make it work to read UHD? Blu-ray disk works just fine. Any help would be greatly appreciated!
Revision: 1.02
Serial number: ...
Cush1978
I think I'm in the same boat here:
OS device name: E:
Revision: 1.03
Serial number: ...
OS device name: E:
Revision: 1.03
Serial number: ...
Your boat is floating.Cush1978 wrote: Tue Jan 14, 2025 9:44 pm I think I'm in the same boat here:
OS device name: E:
Revision: 1.03
Serial number: ...
LordBrandon
So it looks like I was fortunate enough to buy a drive that can support UHD disks, but it seems I need help in order for it to do so.
Is there someone who can help me to get it working?
OS device name: H:
Revision: 1.03
Serial number: ---
Highest AACS version: 56
I took out the serial number but can give it if needed.
Brandon
OS device name: H:
Revision: 1.03
Serial number: ---
Brandon
