Recovering from read errors in Linux
le_mulot
Re: Recovering from read errors in Linux
#31 Post by le_mulot » Mon Dec 30, 2024 2:23 am
For posterity, here is what finally worked for me :D
1. clean-up the disc with isopropyl alcohol
2. run ddrescue but with the "best recovery settings" from DDRescue GUI which in CLI are,
ddrescue --no-scrape --retry-passes=2 --sector-size=32  /dev/sr0 brimage mapfile
3. Follow with the disc backup instructions
kaysee
#32 Post by kaysee » Tue Dec 31, 2024 2:58 am
In the source code, the "best recovery settings" sets the cluster size (number of sectors per block for large reads), not the sector size (number of bytes per sector, which is 2048 for optical discs).
Line 3163 in the section you indicated is:
self.cluster_size_choice.SetSelection(3)
cluster_size_choice is described on line 3097:
#ClusterSize (No. of sectors to copy at a time) option.
The selection array is defined in lines 2969-2970:
self.cluster_size_choice = wx.Choice(self.panel, -1,                                    choices=['256', 'Default (128)', '64', '32'])
So the SetSelection(3) function points to '32' -- that is, 32 sectors per cluster for large reads during the first phase of ddrescue. That is the default setting in the ddrescue commandline:
-c sectors
--cluster-size=sectors
    Number of sectors to copy at a time. Defaults to 64 KiB / sector_size. Try smaller values for slow drives. The number of sectors per track (18 or 9) is a good value for floppies.
