Jurassic Park Trilogy
ricardozf
Post by ricardozf »
I'm having a problem trying to rip the disc of "The Lost World" (Jurassic Park 2).
I have the trilogy box (from Brazil, silver one), and was able to rip the JP3 movie without a problem. The first disc I got two "UNCORRECTABLE ERRORs" but the I also was able to rip the disc. But the JP2 movie disc won't load. I thought it was the discs because it was old, and yellowish.
So I bought another JP trilogy (used), the "collector's edition", that appears to be in good condition, no risks on the discs. But got the same behavior. JP3 loads fine, JP loads with a couple errors, and this time after a long wait and errors the JP2 disc loads.
I was able to start ripping JP2 but after about 14gb of write the disc fails. When I tried again the disc load after errors but won't start ripping. The bluray drive make strange noises, and start spinning fast and slow when I try to load the JP2 disc.
On the 3rd try...
After a long wait I got this log:
Error 'Scsi error - HARDWARE ERROR:TIMEOUT ON LOGICAL UNIT' occurred while reading 'BD-RE HL-DT-ST BD-RE WH16NS60 1.02 KLZNB2I1838' at offset '24978128896'
Error 'Scsi error - HARDWARE ERROR:TIMEOUT ON LOGICAL UNIT' occurred while reading 'BD-RE HL-DT-ST BD-RE WH16NS60 1.02 KLZNB2I1838' at offset '24978192384'
udf: node fe/efe failed!
Then I click to open the disc and get this after a couple minutes:
Using LibreDrive mode (v06.3 id=7FA2657C7667)
Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading 'BD-RE HL-DT-ST BD-RE WH16NS60 1.02 KLZNB2I1838' at offset '24978128896'
Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading 'BD-RE HL-DT-ST BD-RE WH16NS60 1.02 KLZNB2I1838' at offset '24978192384'
File 00077.mpls was added as title #0
File 00085.mpls was added as title #1
File 00086.mpls was added as title #2
File 00088.mpls was added as title #3
File 00089.mpls was added as title #4
File 00090.mpls was added as title #5
File 00091.mpls was added as title #6
File 00093.mpls was added as title #7
File 00096.mpls was added as title #8
File 00097.mpls was added as title #9
File 00098.mpls was added as title #10
File 00099.mpls was added as title #11
File 00100.mpls was added as title #12
File 00102.mpls was added as title #13
File 00800.mpls was added as title #14
File 00500.mpls was added as title #15
File 00501.mpls was added as title #16
File 00502.mpls was added as title #17
File 00503.mpls was added as title #18
File 00504.mpls was added as title #19
File 00505.mpls was added as title #20
File 00506.mpls was added as title #21
File 00507.mpls was added as title #22
File 00508.mpls was added as title #23
File 00509.mpls was added as title #24
File 00510.mpls was added as title #25
File 00511.mpls was added as title #26
File 00512.mpls was added as title #27
File 00513.mpls was added as title #28
File 00514.mpls was added as title #29
File 00515.mpls was added as title #30
File 00516.mpls was added as title #31
File 00517.mpls was added as title #32
File 00020.mpls was added as title #33
File 00061.m2ts was added as title #34
File 00062.m2ts was added as title #35
File 00078.m2ts was added as title #36
File 50204.m2ts was added as title #37
File 50279.m2ts was added as title #38
File 50280.m2ts was added as title #39
Title 50281.m2ts is equal to title 00800.mpls and was skipped
File 50282.m2ts was added as title #40
File 50283.m2ts was added as title #41
File 50284.m2ts was added as title #42
File 50285.m2ts was added as title #43
File 50286.m2ts was added as title #44
File 50287.m2ts was added as title #45
File 50288.m2ts was added as title #46
File 50289.m2ts was added as title #47
File 50308.m2ts was added as title #48
After unselecting unwanted languages and changing names I tried to rip again, with the folowing log:
Saving 1 titles into directory M:/Movies/The Lost World Jurassic Park (1997)
Error 'OS error - STATUS_DEVICE_DATA_ERROR' occurred while reading '\Device\CdRom0' at offset '24978192384'
Then the disc starts to rip with maximum speed rate of 2.0X (8.9 M/s).
And again it fails middle of copy:
The source file '/BDMV/STREAM/50281.m2ts' is corrupt or invalid at offset 17809551360, attempting to work around
The source file '/BDMV/STREAM/50281.m2ts' is corrupt or invalid at offset 17809600512, attempting to work around
The source file '/BDMV/STREAM/50281.m2ts' is corrupt or invalid at offset 17809612800, attempting to work around
The source file '/BDMV/STREAM/50281.m2ts' is corrupt or invalid at offset 17809612800-17809618944, attempting to work around
The source file '/BDMV/STREAM/50281.m2ts' is corrupt or invalid at offset 17809618944, attempting to work around
The source file '/BDMV/STREAM/50281.m2ts' is corrupt or invalid at offset 17809668096, attempting to work around
Hash check failed for file 50281.m2ts at offset 17809729536, file is corrupt.
The source file '/BDMV/STREAM/50281.m2ts' is corrupt or invalid at offset 17809729536, attempting to work around
The source file '/BDMV/STREAM/50281.m2ts' is corrupt or invalid at offset 17809729536-17809735680, attempting to work around
The source file '/BDMV/STREAM/50281.m2ts' is corrupt or invalid at offset 17809735680, attempting to work around
The source file '/BDMV/STREAM/50281.m2ts' is corrupt or invalid at offset 17809778688, attempting to work around
The source file '/BDMV/STREAM/50281.m2ts' is corrupt or invalid at offset 17809778688-17809784832, attempting to work around
The source file '/BDMV/STREAM/50281.m2ts' is corrupt or invalid at offset 17809784832, attempting to work around
The source file '/BDMV/STREAM/50281.m2ts' is corrupt or invalid at offset 17809717248, attempting to work around
Hash check failed for file 50281.m2ts at offset 17973897216, file is corrupt.
The source file '/BDMV/STREAM/50281.m2ts' is corrupt or invalid at offset 17973854208, attempting to work around
The source file '/BDMV/STREAM/50281.m2ts' is corrupt or invalid at offset 18041634816, attempting to work around
The source file '/BDMV/STREAM/50281.m2ts' is corrupt or invalid at offset 18041634816-18041640960, attempting to work around
Hash check failed for file 50281.m2ts at offset 18041726976, file is corrupt.
The source file '/BDMV/STREAM/50281.m2ts' is corrupt or invalid at offset 18044829696, attempting to work around
Hash check failed for file 50281.m2ts at offset 18044872704, file is corrupt.
The source file '/BDMV/STREAM/50281.m2ts' is corrupt or invalid at offset 18044841984, attempting to work around
The source file '/BDMV/STREAM/50281.m2ts' is corrupt or invalid at offset 18044940288, attempting to work around
Too many AV synchronization issues in file '/BDMV/STREAM/50281.m2ts' (title #-) , future messages will be printed only to log file
Hash check failed for file 50281.m2ts at offset 18045069312, file is corrupt.
Too many hash check errors in file 50281.m2ts.
Failed to save title 14 to file M:/Movies/The Lost World Jurassic Park (1997)/The Lost World Jurassic Park (1997).mkv
Encountered 6 errors of type 'HashCheck Error' - see http://www.makemkv.com/errors/hashcheck/...
0 titles saved, 1 failed
What is the possible problem?
Bad disc again?
I don't have another drive or player to test the disc, I will try to borrow one to test it.
ricardozf
Re: Jurassic Park Trilogy
Post by ricardozf »
Update:
I've tested the disc (JP2) on a Sony blu-ray player and it worked without any errors. It loads right away. Played the entire movie.
Errors like this:
or
indicate that the drive was unable to correctly read a spot on the disc.
The standard advice is to gently clean the disc and try again.
If you're experiencing rip errors, please read here first!
ricardozf
Post by ricardozf »
Thanks for the reply.
Last saturday arrived my new Jurassic Park (1) 4K disc, and I ripped without any problems. Then at night I gave another try to rip the JP2 disc, but this time only two errors occurred during the disc opening. So I tried to rip the main movie and for my surprise it was done without any other errors.
I'm glad it's not my drive and also because I was able to save the movie file.
