Se7en Dump File Submitted
Ralph P.
Post by Ralph P. » Mon Dec 30, 2024 6:53 pm
Greetings,
MKB20_v77_Se7en_25F8
I have also loaded the file onto Google Drive for sharing on Keydb.
Regards,
garnuts
Re: Se7en Dump File Submitted
Post by garnuts » Thu Jan 02, 2025 10:05 pm
Still not on key.db yet as of 01/02.
ColonelBlimp043
Post by ColonelBlimp043 » Fri Jan 03, 2025 2:55 am
The Unit Key is on keydb.cfg, but not the volume key required by MakeMKV. I was still ultimately able to rip the disc with MakeMKV after loading the latest keydb while running Xreveal.
erizock
Post by erizock » Fri Jan 03, 2025 4:25 pm
If it helps, I sent this AACS dump file for Se7en Gruv Steelbokk UHD in a public Dropbox folder to svq@makemkv.com:
https://www.dropbox.com/scl/fo/5ft8o3ek ... j5qy8&dl=0
erizock
Post by erizock » Fri Jan 03, 2025 4:26 pm
garnuts
Post by garnuts » Fri Jan 03, 2025 8:38 pm
ColonelBlimp043 wrote: Fri Jan 03, 2025 2:55 am The Unit Key is on keydb.cfg, but not the volume key required by MakeMKV. I was still ultimately able to rip the disc with MakeMKV after loading the latest keydb while running Xreveal.
Thanks, using Xreveal worked!
Toad King
Post by Toad King » Sat Jan 04, 2025 8:45 pm
The volume key for 25F8 is in KeyDB now, and possibly other versions as well.
Ralph P.
Post by Ralph P. » Sun Jan 05, 2025 2:09 pm
Greetings,
Yes, I can confirm the same. Thanks.
Regards,
erizock
Post by erizock » Sun Jan 05, 2025 3:07 pm
Sorry for the noob question but if the volume key is now in KeyDB and I have “enable internet access” checked on my MakeMKV, do you guys know why i still can’t decode/rip my Se7en UHD?
Post by SamuriHL » Sun Jan 05, 2025 4:10 pm
erizock wrote: Sun Jan 05, 2025 3:07 pm Sorry for the noob question but if the volume key is now in KeyDB and I have “enable internet access” checked on my MakeMKV, do you guys know why i still can’t decode/rip my Se7en UHD?
Because those two things are not the same. They KeyDB is a public database of keys not associated with MakeMKV. MakeMKV, however, can use it if it's extracted to the proper folder. MakeMKV maintains its own private key database commonly called the hashed keys that the enable internet access checkbox allows it to update. It sounds like the key is in the KeyDB public database however has not yet been added to the MakeMKV internal hashed keys yet. If you want to decrypt this title now, you can download the KeyDB zip file and extract it to the folder where MakeMKV puts the TGZ dump files, commonly c:\users\<usernamehere>\.MakeMKV on windows.
erizock
Post by erizock » Sun Jan 05, 2025 8:38 pm
Gotcha. It worked and I am ripping the UHD disc! Thanks 🙏
erizock
Post by erizock » Sun Jan 05, 2025 9:28 pm
Welp. Looks Like I spoke too soon. Followed the suggestion of downloading the KeyDB zip file and extracting it to the folder where MakeMKV puts the TGZ dump file.
And then I try to rip the UHD dis and this error message for all 32 titles...
"Error 'Scsi error - ILLEGAL REQUEST:INVALID FIELD IN CDB' occurred while reading '/BDMV/STREAM/00070.m2ts' at offset '0'
Failed to save title XX to file /Users/exxxxxxx/Movies/Se7en/Se7en (1995)_t31.mkv
0 titles saved, 32 failed"
Then I tried to back it up and got this error message...
"Using LibreDrive mode (v06.3 id=E064BA3E3F81)
Backing up disc into folder "/Users/exxxxxxx/Movies/backup/SEVEN"
Downloading latest HK to /Users/exxxxxxx/Movies ...
Error 'Scsi error - ILLEGAL REQUEST:INVALID FIELD IN CDB' occurred while reading '/BDMV/STREAM/00079.m2ts' at offset '16668819456'
Failed to save title /BDMV/STREAM/00079.m2ts to file /Users/exxxxxxx/Movies/backup/SEVEN/BDMV/STREAM/00079.m2ts
Backup done but 1 files failed hash check"
Post by SamuriHL » Sun Jan 05, 2025 10:00 pm
It's a read error. Clean the disc and/or try a different drive.
erizock
Post by erizock » Mon Jan 06, 2025 1:28 pm
All good. Clean disc and tried in another drive. It worked. Thanks for the help.
TORRRRR
Post by TORRRRR » Fri Jan 24, 2025 11:33 pm
Quick question - I see the full 4K feature as an "800" file, and another as an "801" file. Are they both good? One real one fake? The 800 file is 73.66GB and the 810 file is 73.48GB.
