Hi Guys, Hope you can help.
I've been using the same drive to rip 4k UHD movies with no issues, however its suddenly not working. It can ready all other DVD / HD Bluray discs fine, just not 4k. It just spins for ages and eventually says "No Disc Inserted".
Would this be a faulty drive or a software issue?
Drive Info:
OS device name: F:
Manufacturer: ASUS
Product: BC-12D2HT
Revision: 1.00
Serial number: ...
Firmware date: 2113-06-14 12:00
Bus encryption flags: 1E
Drive platform: MT1939
Firmware version: 1.00
BD raw metadata read: Partial
ASUS Bluray Dive No longer opening 4k UHD Discs
mark_walker2012
Re: ASUS Bluray Dive No longer opening 4k UHD Discs
Your firmware is from several years before UHD was a thing. If it were a Pioneer, it MAY have been possible to update it, but an Asus, no. You've got its capabilities already.
The info shows that it has the old, wrong MT1939 drive platform. That drive has never and will never be able to read UHD discs. It simply doesn't have the right hardware in it.mark_walker2012 wrote: ↑Mon Dec 30, 2024 12:36 pmHi Guys, Hope you can help.
Drive Info:
OS device name: F:
Manufacturer: ASUS
Product: BC-12D2HT
Revision: 1.00
Serial number: ...
