storageisfun
Re: SDFtool Flasher
Post by storageisfun »
flashing did nothing to create this issue
It could. Before it at least recognized that there is a disc in there.
It still works fine on Standard Blu Rays and DVDs just not on 4K. It own't recognize that a disc has been inserted.
Re: SDFtool Flasher
storageisfun wrote: Mon Dec 30, 2024 6:55 am
4Ks need more power especially BD100s
storageisfun
Re: SDFtool Flasher
Billycar11 wrote: Mon Dec 30, 2024 7:18 am
I tried with both connected directly to a laptop or to a Powered USB hub with 45 watt power supply.
Anything I can do or do I have a busted drive?
Re: SDFtool Flasher
storageisfun wrote: Mon Dec 30, 2024 7:37 am
try cleaning the disc with a damp lint free cloth then immediately dry with another to avoid water spots
storageisfun
Re: SDFtool Flasher
Billycar11 wrote: Mon Dec 30, 2024 7:47 am
Still doesn't work after cleaning off the disc
storageisfun
Re: SDFtool Flasher
I did some more testing. It rips DVDs and blu rays just fine. I tried powered USB hubs, unpowered USB hubs. Before I flashed the new firmware the disc was recognized by Windows and MakeMKV. Now, my 4K disc won't be recognized by either the OS or MakeMKV>
Re: SDFtool Flasher
storageisfun wrote: Tue Dec 31, 2024 2:10 am
The firmware should not be the issue but if you want to, you could flash it to Buffalo PU3-BU10.
Also, do not open MakeMKV until the disc has been initialized by the OS.
storageisfun
Re: SDFtool Flasher
MartyMcNuts wrote: Tue Dec 31, 2024 3:01 am
Are you sure? Because before the flashing the disc was recognized but unable to be ripped. Now the disc is not able to be detected at all.
Re: SDFtool Flasher
storageisfun wrote: Tue Dec 31, 2024 6:37 am
Try it and see.
storageisfun
Re: SDFtool Flasher
What do you mean by this?
Re: SDFtool Flasher
storageisfun wrote: Tue Dec 31, 2024 7:38 pm
Exactly what I said. The firmware is 99.9% not your issue. On extremely rare occasions a flash may not have taken properly. If you want to know for sure, flash the drive to the Buffalo PU3-BU10 firmware.
corefunctions
Re: SDFtool Flasher
Post by corefunctions »
I am trying to flash my LG BP60NB10 and when I have my SDFtool open and ready to choose drive and firmware, then drop down menu of drive will not display my drive. Anyone got any tips for this?
Please and thank you.
Re: SDFtool Flasher
corefunctions wrote: Wed Jan 15, 2025 8:07 am I am trying to flash my LG BP60NB10 and when I have my SDFtool open and ready to choose drive and firmware, then drop down menu of drive will not display my drive. Anyone got any tips for this?
Do you have MakeMKV installed and in the default location?
corefunctions
Re: SDFtool Flasher
MartyMcNuts wrote: Wed Jan 15, 2025 11:05 pm
I have MakeMKV set up on my Mac but it's not able to open SDFTool so I used my friends PC to try and upload the software, but he doesn't have MakeMKV downloaded. This is what I see and my Player is connected and being read by the laptop.
Re: SDFtool Flasher
corefunctions wrote: Fri Jan 17, 2025 6:24 pm
SDFFlasher is just a GUI and needs Makemkv to be installed.
