Post
by Billycar11 » Mon Dec 30, 2024 6:50 am
storageisfun wrote: Mon Dec 30, 2024 6:45 am
copy paste your makemkv drive info section so we can check you flashed it right
Here is the information
OS device name: F:
Manufacturer: BUFFALO
Product: Optical Drive
Revision: 1.03
Serial number:
Highest AACS version: 72
Firmware version: 1.03
should work as is. it flashed correctly
if there something wrong you have a different problem bad drive or not enough power.
flashing did nothing to create this issue
storageisfun
Post
by storageisfun » Mon Dec 30, 2024 6:55 am
It could. Before it at least recognized that there is a disc in there.
It still works fine on Standard Blu Rays and DVDs just not on 4K. It own't recognize that a disc has been inserted.
Post
by Billycar11 » Mon Dec 30, 2024 7:18 am
storageisfun wrote: Mon Dec 30, 2024 6:55 am
4Ks need more power especially BD100s
storageisfun
Post
by storageisfun » Mon Dec 30, 2024 7:37 am
Billycar11 wrote: Mon Dec 30, 2024 7:18 am
I tried with both connected directly to a laptop or to a Powered USB hub with 45 watt power supply.
Anything I can do or do I have a busted drive?
Post
by Billycar11 » Mon Dec 30, 2024 7:47 am
storageisfun wrote: Mon Dec 30, 2024 7:37 am
try cleaning the disc with a damp lint free cloth then immediately dry with another to avoid water spots
storageisfun
Post
by storageisfun » Mon Dec 30, 2024 9:41 pm
Billycar11 wrote: Mon Dec 30, 2024 7:47 am
Still doesn't work after cleaning off the disc
storageisfun
Post
by storageisfun » Tue Dec 31, 2024 2:10 am
I did some more testing. It rips DVDs and blu rays just fine. I tried powered USB hubs, unpowered USB hubs. Before I flashed the new firmware the disc was recognized by Windows and MakeMKV. Now, my 4K disc won't be recognized by either the OS or MakeMKV>
Post
by MartyMcNuts » Tue Dec 31, 2024 3:01 am
storageisfun wrote: Tue Dec 31, 2024 2:10 am
The firmware should not be the issue but if you want to, you could flash it to Buffalo PU3-BU10.
Also, do not open MakeMKV until the disc has been initialized by the OS.
storageisfun
Post
by storageisfun » Tue Dec 31, 2024 6:37 am
MartyMcNuts wrote: Tue Dec 31, 2024 3:01 am
Are you sure? Because before the flashing the disc was recognized but unable to be ripped. Now the disc is not able to be detected at all.
Post
by MartyMcNuts » Tue Dec 31, 2024 7:50 am
storageisfun wrote: Tue Dec 31, 2024 6:37 am
Try it and see.
storageisfun
Post
by storageisfun » Tue Dec 31, 2024 7:38 pm
What do you mean by this?
Post
by MartyMcNuts » Wed Jan 01, 2025 12:15 am
storageisfun wrote: Tue Dec 31, 2024 7:38 pm
Exactly what I said. The firmware is 99.9% not your issue. On extremely rare occasions a flash may not have taken properly. If you want to know for sure, flash the drive to the Buffalo PU3-BU10 firmware.
corefunctions
Post
by corefunctions » Wed Jan 15, 2025 8:07 am
I am trying to flash my LG BP60NB10 and when I have my SDFtool open and ready to choose drive and firmware, then drop down menu of drive will not display my drive. Anyone got any tips for this?
Please and thank you.
Post
by MartyMcNuts » Wed Jan 15, 2025 11:05 pm
corefunctions wrote: Wed Jan 15, 2025 8:07 am
Do you have MakeMKV installed and in the default location?
corefunctions
Post
by corefunctions » Fri Jan 17, 2025 6:24 pm
MartyMcNuts wrote: Wed Jan 15, 2025 11:05 pm
I have MakeMKV set up on my Mac but it's not able to open SDFTool so I used my friends PC to try and upload the software, but he doesn't have MakeMKV downloaded. This is what I see and my Player is connected and being read by the laptop.
- Screenshot 2025-01-17 102026.png (16.48 KiB) Viewed 46143 times
