I was told to return a Pioneer drive that I got since it had firmware that would not work and I could not flash new firmware.
On the list of compatible drives it showed a model by Buffalo, the BRUHD-PU3 as compatible.
I found the GUI to flash the firmware but I can't find the specific firmware that works on this drive.
Please help thank you
Get firmware for Buffalo BRUHD-PU3
storageisfun
Re: Get firmware for Buffalo BRUHD-PU3
Nevermind I found multiple conflicting firmware files but I don't know which one to use and the SDF flasher tool makes erorrs.
email me or marty for an auto flasher
or see guide below its is accurate for that drive unless they changed whats inside send a copy past of makemkv drive info in the email
