Pioneer BDR-S09XLT LibreDrive ready but not ripping UHD-discs
Cristi1992
Re: Pioneer BDR-S09XLT LibreDrive ready but not ripping UHD-discs
No worries in the near future will be found a work around, maybe the officials of Pioneer will create a new update, and let the drive to read UHD like in the beginning when the drive could read it, because not many people buy UHD, and I don't think the fate of UHD Blu-ray will not be a good one, because most of the people just watch the stream services it's easier after a hard work day, I mean just the collectors like me watch now the UHD Blu-ray, the people that appreciate real quality, so I wish to you guys good luck in the future in finding a work around for this, what it's confusing to me it's you said if the drive it's released prior October 2015 the flash will not work. Anyway I can't spend 25 dollars even if you could help me, because I bought the drive with 60 dollars, and also I already have another drive Asus bw-16d1ht and that one I received it already flashed and works, so I will just keep one for burning and the other one for watching 4k Blu-ray, the Asus bw-16d1ht cost me 50 dollars, what can I surely say is japanese people really take care of their products Pioneer have a 2023 firmware update, and the other drive doesn't have a new firmware from long time ago, so I wish you all good luck in what you do and keep up the good work, you do an amazing job, they can jailbreak Nintendo Switch with chip so I'm sure in the future they will learn how to flash a drive with any firmware version.
Nice prayer. Amen.
Tektek
Hi everyone, for BDR-S09XLT does exist differents dates for this fw 1.55, if yes which is the dead line that is no return possible to UHD friendly ?Coopervid wrote: Sun Dec 29, 2024 4:07 pmUnfortunately you messed it up by installing the 2023 firmware.Cristi1992 wrote: Sat Dec 28, 2024 5:20 pmI think the drive it's too old, it's released in 2013, the firmware it's from 2023, and if it's prior octomber 2015 released can't be flushed, i'm right?
Thanks.
Tektek
If the "Firmware date" on the drive is 12/2022 or later, it's screwed. Consider it a non-UHD drive, because Pioneer removed that capability and locked it out.
Finelfish
Hi!
OS device name: E:
Manufacturer: PIONEER
Product: BD-RW BDR-S09
Revision: 1.34
Serial number: XXXXXXXXXXXX
Firmware date: 2016-04-25
Highest AACS version: 57
Drive platform: RS8600
Firmware version: 1.34/ID43
Can you help me too to get this drive to read UHD's?
Thank You!
OS device name: E:
Revision: 1.34
Thank You!
PM sent.Finelfish wrote: Wed Jan 22, 2025 6:14 pm Hi!
OS device name: E:
Revision: 1.34
Thank You!
discbandit
@Coopervid
Have an RS8600 and looking to enable UHD too. Thanks!
Info
Manufacturer: ASUS
Product: BW-12DIS-U
Revision: E401
Serial number: xxxxxxxxxxxx
Firmware date: 2013-09-10
Firmware version: E401/ID44
PM sent.discbandit wrote: Fri Jan 24, 2025 12:24 am @Coopervid
Info Drive Information OS device name: D: Manufacturer: ASUS Product: BW-12DIS-U Revision: E401 Serial number: xxxxxxxxxxxx Firmware date: 2013-09-10 Bus encryption flags: 1B LibreDrive Information Status: Enabled Drive platform: RS8600 Firmware name: PIONEER BDR-209 Firmware type: Original (unpatched) Firmware version: E401/ID44 DVD all regions: Yes BD raw data read: Yes BD raw metadata read: Yes Unrestricted read speed: Yes
discbandit
Worked great. Thanks!
Coopervid wrote: Fri Jan 24, 2025 10:32 amPM sent.discbandit wrote: Fri Jan 24, 2025 12:24 am @Coopervid
Finelfish
fon1105
Could you, please, help me with UHD?
Current profile: BD-R SRM
Revision: 1.55
Serial number: ...
Firmware date: 2023-02-16
Drive platform: Pioneer RS8600
Firmware version: ID43
Disc Information
Label: 4U6666
Timestamp: 2024-11-27 15:42:08
Data capacity: 41.89 Gb
Disc type: BD-R
Number of layers: 2
Revision: 1.55
Serial number: ...
Disc Information
Label: 4U6666
Disc type: BD-R
Number of layers: 2
zittrig
Nope, sorry, the installed firmware is younger than 11/2022. No downgrade / crossflash possible.
bigfatmonk
Hey! Could you pleas help me enable UHD on my drive?
No disc insertedDrive Information
Revision: 1.52
Serial number: ...
Firmware date: 2019-01-11
Highest AACS version: 16
Firmware version: 1.52/ID43
Prinz_Falafel
Hello everyone,
I also have a Pioneer BDR-S09.
Is my Pioneer suitable for flashing for UHD reading?
https://www.directupload.eu/file/d/8851 ... il_png.htm
Last edited by Prinz_Falafel on Thu Mar 13, 2025 8:47 pm, edited 2 times in total.
Yes. PM sent.Prinz_Falafel wrote: Fri Mar 07, 2025 9:40 pm
Hello everyone,
