PM is coming.lurker2100 wrote: Sat Dec 28, 2024 2:10 am Based on recent messages, it looks like this drive can be made to read UHD discs. Is that true?
OS device name: E:
Manufacturer: PIONEER
Product: BD-RW BDR-XD05
Revision: 3.10
Serial number: ********
Firmware date: 2017-06-22
Highest AACS version: 47
Drive platform: RS8232
Firmware name: PIONEER BDR-XD05
Firmware version: 3.10/ID34
LibreDrive for Pioneer drives
lurker2100
Worked perfectly. Thank you.
mopato4931
I have this drive, I read on some on a forum that I was able to get the update to rip UHD discs from it? Thanks
OS device name: F:
Product: BD-RW BDR-X13U
Revision: 1.03
Serial number: CGDL300344UC
Firmware date: 2022-12-12
Highest AACS version: 61
Firmware version: ID29
OS device name: F:
Revision: 1.03
nah sorry man to new return it if you can see below for pioneers with old fwmopato4931 wrote: Sun Dec 29, 2024 5:12 am Hello,
OS device name: F:
Revision: 1.03
pacmansyu
From what I can tell, this drive is able to be flashed. What is the process for flashing it?
OS device name: E:
Product: BD-RW BDR-212D
Revision: 1.02
Firmware date: 2022-03-16
Bus encryption flags: 13
Highest AACS version: 63
Drive platform: RS8F00
Firmware version: 1.02/ID61
OS device name: E:
Revision: 1.02
send me an email see belowpacmansyu wrote: Sun Dec 29, 2024 11:47 pm From what I can tell, this drive is able to be flashed. What is the process for flashing it?
OS device name: E:
Revision: 1.02
send that same drive info
storageisfun
Well now pioneer drives don't work.
Can we put on the UHD Flashing Guide that Pioneer drives with newer firmware don't work.
i have pioneers with old fw see belowstorageisfun wrote: Mon Dec 30, 2024 6:36 am Well now pioneer drives don't work.
non-issue
I got this Verbatim/Pioneer drive recently and was hoping that it would work for opening UHD discs with MakeMKV.
It just starts the process and then ends on failed to open disc.
From what i could understand it is not to new to work. Could someone here please help me?
Thanks for any advice.
Product: BD-RW BDR-UD04
Revision: 1.14
Serial number: DFDL152xxxxx
Firmware date: 2020-06-15
Highest AACS version: 76
Drive platform: RS8A10
Firmware version: 1.14
Revision: 1.14
Yes, your drive is already UHD capable. Just clean the disc before trying again. Make sure the drive is getting enough power by using USB-C if possible or using USB-A port direclty off the motherboard or a powered (35+ watts) USB hub.non-issue wrote: Tue Dec 31, 2024 3:02 am Hi,
Revision: 1.14
Also, ensure the OS initializes the disc before opening MakeMKV.
kaysee
This is regarding a Pioneer BDR-209MBK.
MakeMKV 1.17.8
Info:
Product: BD-RW BDR-209M
Revision: 1.53
Firmware date: 2019-03-07
Highest AACS version: 81
Firmware version: ID04
Message:
Saved FW dump file as .../.MakeMKV/dump_FW_9F51EC0AA73BFBC989E2.tgz
Please send the file ".../.MakeMKV/dump_FW_9F51EC0AA73BFBC989E2.tgz" to support@makemkv.com
What is doable with this drive? Recommendations for firmware changes? Should I send the FW dump to the support email address?
CD-audio discs and DVDs are reading slowly (2X for CDs, 1+ hour for a dual-layer DVD), but accurately. I have not yet tried the Pioneer Drive Utility which is available at https://pioneer.jp/device_e/product-e/i ... iveUtility . There is not an exact match on that web page for this drive model. The closest seems to be:
"For BDR-209EBK, BDR-209UBK(BDR-2209)"
PioneerBDR-209-211_DriveUtility_v1.2.0.3.exe
(8.43 MB)
updated Jan 23, 2018
So I am unsure about how general Pioneer's utility software is for these model numbers -- whether "209" would cover "209M", "209D", etc.
MakeMKV 1.17.8
Info:
Revision: 1.53
Message:
(8.43 MB)
Your drive is a 212 type that is named 209 and mainly sold as an IOData in Japan? Isn't it. It needs to be flashed to be UHD capable. Check your PM and then use the Pioneer 212 utility.kaysee wrote: Wed Jan 01, 2025 7:28 pm This is regarding a Pioneer BDR-209MBK.
MakeMKV 1.17.8
Info:
Revision: 1.53
Message:
(8.43 MB)
So I am not unsure about how general Pioneer's utility software is for these model numbers -- whether "209" would cover "209M", "209D", etc.
kaysee
Thanks, got it. But first, how certain do we need to be about this model and the corresponding flashing software and new firmware before flashing the firmware? The label on the drive chassis is normal for a Pioneer-branded drive. And there are a number of models named "BDR-209*".Coopervid wrote: Wed Jan 01, 2025 7:39 pm Your drive is a 212 type that is named 209 and mainly sold as an IOData in Japan? Isn't it. It needs to be flashed to be UHD capable. Check your PM and then use the Pioneer 212 utility.
The only thing I am fairly confident about regarding this model number is that the "BK" is not important. In other words, I think "BDR-209MBK" just means a "BDR-209M" that has a black ("BK") front.
I can see it based on your firmware code. It's not a regular 209 but a camouflaged 212. Take it or leave it. 209s have 8600 or 8601.kaysee wrote: Wed Jan 01, 2025 8:09 pmThanks, got it. But first, how certain do we need to be about this model and the corresponding flashing software and new firmware before flashing the firmware? The label on the drive chassis is normal for a Pioneer-branded drive. And there are a number of models named "BDR-209*".Coopervid wrote: Wed Jan 01, 2025 7:39 pm Your drive is a 212 type that is named 209 and mainly sold as an IOData in Japan? Isn't it. It needs to be flashed to be UHD capable. Check your PM and then use the Pioneer 212 utility.
lee_bleh
Hi all,
hopefully someone could offer some advice on this drive
Revision: 1.00
Serial number: ...
Firmware date: 2021-12-19
Firmware version: ID43
From what I understand being on an early pre-22 (barely) firmware this should be suitable to use?
I did see in another thread (viewtopic.php?t=27378&start=345) Mike requested users to email dumps of their drives (which I did to the support mkv email address).
Any information would be appreciated.
Revision: 1.00
Serial number: ...
