Main Title Succeeds But Other Titles Fail
eddified
#1 Post by eddified » Thu Dec 26, 2024 3:56 pm
I have a few fairly new 4K UHD discs (All are brand new, recently purchased). There is a pattern here: main title succeeds, but other titles fail.
  • Wild Robot (2024) 4k UHD - Main Title succeeded, and a few of the other titles also succeeded, but many of the other titles failed
  • Despicable Me 4 (2024) 4k UHD - Main Title succeeded, ALL other titles failed
  • Migration (2023) 4k UHD - Main Title Succeeded, ALL other titles failed
What I tried: Rebooting (before I ripped "Migration"). Inspecting the discs: I see no smudges or damage.
I see the link to the website https://www.makemkv.com/errors/hashcheck/ :
"Getting this error usually means a failing Blu-ray drive." Hm, ok, but... why would it consistently work for the main title? Hmm...
Windows, MakeMKV 1.17.8.
Drive: WH16NS40. I've used it since 2018.
The errors look like:
Hash check failed for file 00474.m2ts at offset 780288, file is corrupt.
Hash check failed for file 00474.m2ts at offset 976896, file is corrupt.
Too many hash check errors in file 00474.m2ts.
The source file '/BDMV/STREAM/00474.m2ts' is corrupt or invalid at offset 0, attempting to work around
The source file '/BDMV/STREAM/00474.m2ts' is corrupt or invalid at offset 0-6144, attempting to work around
The source file '/BDMV/STREAM/00474.m2ts' is corrupt or invalid at offset 6144, attempting to work around
The source file '/BDMV/STREAM/00474.m2ts' is corrupt or invalid at offset 6144-12288, attempting to work around
The source file '/BDMV/STREAM/00474.m2ts' is corrupt or invalid at offset 12288, attempting to work around
The source file '/BDMV/STREAM/00474.m2ts' is corrupt or invalid at offset 12288-18432, attempting to work around
The source file '/BDMV/STREAM/00474.m2ts' is corrupt or invalid at offset 18432, attempting to work around
Too many AV synchronization issues in file '/BDMV/STREAM/00474.m2ts' (title #-) , future messages will be printed only to log file
Error 'Internal error - Operation was cancelled (140)' occurred while reading '/BDMV/STREAM/00474.m2ts' at offset '16478208'
Failed to save title 30 to file D:/Video/Migration/Migration_t30.mkv
Encountered 83 errors of type 'HashCheck Error' - see http://www.makemkv.com/errors/hashcheck/...
0 titles saved, 46 failed
eddified
Re: Main Title Succeeds But Other Titles Fail
#2 Post by eddified » Thu Dec 26, 2024 5:43 pm
Update: Puss in Boots (2011) - brand new 4k UHD, but probably authored years ago, worked fine: all titles ripped successfully.
#3 Post by MartyMcNuts » Thu Dec 26, 2024 10:10 pm
eddified wrote: Thu Dec 26, 2024 5:43 pm Update: Puss in Boots (2011) - brand new 4k UHD, but probably authored years ago, worked fine: all titles ripped successfully.
Clean the other discs. The drive is struggling to read them.
eddified
#4 Post by eddified » Thu Dec 26, 2024 10:30 pm
MartyMcNuts wrote: Thu Dec 26, 2024 10:10 pm
These are all brand new, just removed the packaging. The discs are in perfect shape. Not dirty at all.
#5 Post by MartyMcNuts » Thu Dec 26, 2024 11:50 pm
eddified wrote: Thu Dec 26, 2024 10:30 pm
Doesn't matter. Brand new out of the box is usually when they need to be cleaned as they can sometimes have an invisible film over them from the manufacturing process.
eddified
#6 Post by eddified » Sun Dec 29, 2024 2:41 am
MartyMcNuts wrote: Thu Dec 26, 2024 11:50 pm Doesn't matter. Brand new out of the box is usually when they need to be cleaned as they can sometimes have an invisible film over them from the manufacturing process.
Well by golly, I cleaned Despicable Me 4 and now it seems to be working! Thanks a lot for explaining about the invisible film. If you hadn't mentioned that, I would never have bothered to clean them, as I believed they were already clean!
