"This Blu-ray needs a library for AACS decoding, and your system does not have it."
every time what is this?
i get error message when i try to rip 4k disks
james gilicuty
james gilicuty
Re: i get error message when i try to rip 4k disks
Error 'OS error - This device does not exist' occurred while reading '/BDMV/STREAM/00030.m2ts' at offset '32939636736'
Error 'OS error - The volume for a file has been externally altered such that the opened file is no longer valid' occurred while reading '\Device\CdRom3' at offset '32939636736'
what is this mess?
what is this mess?
You have 2 issues it looks like 1 your drive has a power issue plug directly to the motherboard in the back or get a high powered USB hub 35+ watts
2 you don't have makemkv integration enable for vlc
