#10516 Post by SamuriHL » Fri Dec 27, 2024 7:31 pm
deadchip12
#10517 Post by deadchip12 » Sat Dec 28, 2024 12:50 am
@RESET_9999
I saw you just updated the Transfer CMv 4.0 Dolby Vision from WEB streaming to Profile 7 tutorial video. Would be great if you can do the same for the ADD Original Dolby Vision from WEB STREAMING to HDR10 Bluray Rip (P8 Hybrid) video as well, and a tutorial on how to use the new GUI in the latest dovi script version.
#10518 Post by RESET_9999 » Sat Dec 28, 2024 1:27 pm
the p8 hybrid tuto doesnt really need to be updated... Nothing changed...
A couple of things were automated in the transfer cmv4.0 workflow so that's why I redid this one.
darrrkmanxxx
#10519 Post by darrrkmanxxx » Sat Dec 28, 2024 7:36 pm
How can I tell if a device supports cmv4.0?
#10520 Post by RESET_9999 » Sat Dec 28, 2024 11:41 pm
just try one of the cmv4.0 rpu test files
https://drive.google.com/drive/u/1/fold ... eyGDQEGJuF
voodoomamajuju
#10521 Post by voodoomamajuju » Tue Dec 31, 2024 12:59 am
@RESET_9999 Just wanted to say thanks for the Dolby_vision_stuff sheet but I just noticed that the link is broken. Is the sheet hosted somewhere else now? Thanks again!
#10522 Post by RESET_9999 » Tue Dec 31, 2024 1:29 pm
Yeah, I'm stupid. I was making space in my Google Drive and deleted a folder that contained the Excel sheet. I did a backup recently, so only one month of data is missing.
the new link in my signature should work
skull88
#10523 Post by skull88 » Tue Dec 31, 2024 1:42 pm
Happens to the best of us, haha. Just in case, maybe this article could help recover deleted file(s) in future: https://support.google.com/drive/answer/1716222?hl=en
#10524 Post by RESET_9999 » Tue Dec 31, 2024 1:52 pm
thanks but unfortunately, the Google Drive account was created with a VERY old email address(hotmail.com) I no longer have access and they require email verification.
darrrkmanxxx
#10525 Post by darrrkmanxxx » Wed Jan 01, 2025 5:36 pm
ok, I don't see any changes in any of those files :(
Where I do see changes is in this file (titled as cmv4):
Chroma Weight extreme values 0-4095 DV P8 cmv4.0.mp4
This still means that cmv4.0 isn't supported, right? Just want to be sure.
How should I convert the RPU to be the most compatible with my setup?
Happy new year!
#10526 Post by RESET_9999 » Wed Jan 01, 2025 7:41 pm
yes this file has a cmv2.9 fallback metadata block. If your devices don't support cmv4.0, you don't have to worry about any of this and any RPU work fine.
what devices did you try?
darrrkmanxxx
#10527 Post by darrrkmanxxx » Wed Jan 01, 2025 8:21 pm
:D
Just on my trusty old Philips TV 65oled934 (2019).
Then on a LG G3 with dune premier pro running corelec I get everything when set to player led. With tv led I don't see any trims unfortunately, but this is expected, right?
#10528 Post by RESET_9999 » Wed Jan 01, 2025 8:26 pm
No, cmv4.0 should work with TV-LED. CE player-led supports only cmv2.9. (at least on the ugoos)
Your G3 TV internal DV config is probably higher than 1000nits so the trims are probably ignored when the RPU MDL is 1000nits. Make sure that you use the test files that say ''4000-MDL''
darrrkmanxxx
#10529 Post by darrrkmanxxx » Wed Jan 01, 2025 9:02 pm
will any cmv4.0 rpu have an cmv2.9 fallback or do I have to inject one?
Also my Philips TV 65oled934 has 800nit peak brightness. Don't I have to add a 800nit trim to the RPU to get the most brightness out of it?
Sorry for the dumb questions, seems I'm still not getting it. :D
#10530 Post by RESET_9999 » Wed Jan 01, 2025 9:18 pm
yes all cmv4.0 movies have cmv2.9 fallback metadata. Your G3 + CE device should support cmv4.0.
All the trims(100-600-1000) work together and the metadata can be extrapolated to any target brightness.
