Verbatim 43890 External Slimline Mobile USB 3.2 Blu-ray Writer UHD Problem
knippinski
Re: Verbatim 43890 External Slimline Mobile USB 3.2 Blu-ray Writer UHD Problem
Post by knippinski » Fri Dec 27, 2024 7:20 pm
Hallo Coopervid,
could you please send me the Firmware for the Verbatim 43890 Drive to support UHD discs.
Greatly appreciated
Post by Coopervid » Sat Dec 28, 2024 11:24 am
knippinski wrote: Fri Dec 27, 2024 7:20 pm Hallo Coopervid,
Greatly appreciated
PM is coming.
Psyire
Post by Psyire » Wed Jan 08, 2025 2:09 am
Hi Coopervid,
I just picked up one of these drives as well, can you send me the firmware required for UHD?
Thanks bud!
Post by Coopervid » Wed Jan 08, 2025 10:46 am
Psyire wrote: Wed Jan 08, 2025 2:09 am Hi Coopervid,
Thanks bud!
PM is coming.
juanan
Post by juanan » Wed Jan 08, 2025 4:08 pm
HI!
I have the same problem. After several weeks using Verbatim 43890 to play/record Blurays with success,
I´ve just tried to read a UHD disks with this Makemkv result:
Información de unidad de disco
Nombre del SO del dispositivo: H:
Fabricante: PIONEER
Producto: BD-RW BDR-UD03
Revisión: 1.14
Número de serie: BDDLXXXXXXWL
Fecha del firmware: 2020-06-15
Marcas de cifrado bus: 1B
Highest AACS version: 17
Drive platform: RS8511
Firmware version: 1.14
No hay disco insertado (no disk inserted)
SO, would you please help me to flash my drive?
Thanks in advance
Post by Coopervid » Wed Jan 08, 2025 9:03 pm
juanan wrote: Wed Jan 08, 2025 4:08 pm HI!
Fabricante: PIONEER
Revisión: 1.14
Thanks in advance
PM is coming.
Fox_Mulder
Post by Fox_Mulder » Thu Jan 09, 2025 12:08 am
Quick question: I'm thinking about buying a burner that can read 4k films. Does the firmware upgrade from BDR-UD03 to BDR-UD04 always work? What are the disadvantages? Or should I just buy a 43888 with
Pioneer BDR-UD04?
Post by Coopervid » Thu Jan 09, 2025 10:16 am
Fox_Mulder wrote: Thu Jan 09, 2025 12:08 am Quick question: I'm thinking about buying a burner that can read 4k films. Does the firmware upgrade from BDR-UD03 to BDR-UD04 always work? What are the disadvantages? Or should I just buy a 43888 with
Pioneer BDR-UD04?
Yes it works with all drives but if you find a 43888 why bother?
zittrig
Post by zittrig » Thu Jan 09, 2025 1:40 pm
@Fox_Mulder: But have a good look at the drive before buying if you want a 43888 with Pioneer drive only. Because since recently there are 43888 with LG's BU40N released also.
Fox_Mulder
Post by Fox_Mulder » Thu Jan 09, 2025 6:02 pm
zittrig wrote: Thu Jan 09, 2025 1:40 pm @Fox_Mulder: But have a good look at the drive before buying if you want a 43888 with Pioneer drive only. Because since recently there are 43888 with LG's BU40N released also.
OK. Thanks for the info.
Can you see it on the packaging?
What disadvantage does the LG have compared to the Pioneer?
RobinStn
Post by RobinStn » Thu Jan 09, 2025 9:08 pm
Hallo Coopervid,
I would appreciated it.
Post by Coopervid » Thu Jan 09, 2025 9:25 pm
RobinStn wrote: Thu Jan 09, 2025 9:08 pm Hallo Coopervid,
Post your Makemkv info.
Fox_Mulder
Post by Fox_Mulder » Fri Jan 10, 2025 2:10 am
Coopervid wrote: Thu Jan 09, 2025 9:25 pm
How much should the firmware cost? I'm trying to decide which is more worthwhile.
zittrig
Post by zittrig » Fri Jan 10, 2025 4:40 am
Fox_Mulder wrote: Thu Jan 09, 2025 6:02 pm
IMO the BU40N is the best of the LG family so it wouldn't be a mistake to get one.
Marty explained some optical differences here ..
viewtopic.php?f=19&t=36199#top
RobinStn
Post by RobinStn » Fri Jan 10, 2025 6:30 am
Drive informatie
Naam OS-apparaat: E:
Fabrikant: PIONEER
Product: BD-RW BDR-UD03
Revisie: 1.14
Serienummer: ...
Firmware datum: 2020-06-15
Bus encryptie flags: 1B
