Verbatim 43890 External Slimline Mobile USB 3.2 Blu-ray Writer UHD Problem
knippinski
Re: Verbatim 43890 External Slimline Mobile USB 3.2 Blu-ray Writer UHD Problem
Post by knippinski »
Hallo Coopervid,
could you please send me the Firmware for the Verbatim 43890 Drive to support UHD discs.
Greatly appreciated
knippinski wrote:
Fri Dec 27, 2024 7:20 pm
Hallo Coopervid,
Greatly appreciated
PM is coming.
Psyire
Post by Psyire »
Hi Coopervid,
I just picked up one of these drives as well, can you send me the firmware required for UHD?
Thanks bud!
Psyire wrote:
Wed Jan 08, 2025 2:09 am
Hi Coopervid,
Thanks bud!
PM is coming.
juanan
Post by juanan »
HI!
I have the same problem. After several weeks using Verbatim 43890 to play/record Blurays with success,
I´ve just tried to read a UHD disks with this Makemkv result:
Información de unidad de disco
Nombre del SO del dispositivo: H:
Fabricante: PIONEER
Producto: BD-RW BDR-UD03
Revisión: 1.14
Número de serie: BDDLXXXXXXWL
Fecha del firmware: 2020-06-15
Marcas de cifrado bus: 1B
Highest AACS version: 17
Drive platform: RS8511
Firmware version: 1.14
No hay disco insertado (no disk inserted)
SO, would you please help me to flash my drive?
Thanks in advance
juanan wrote:
Wed Jan 08, 2025 4:08 pm
HI!
Fabricante: PIONEER
Revisión: 1.14
Thanks in advance
PM is coming.
Fox_Mulder
Post by Fox_Mulder »
Quick question: I'm thinking about buying a burner that can read 4k films. Does the firmware upgrade from BDR-UD03 to BDR-UD04 always work? What are the disadvantages? Or should I just buy a 43888 with
Pioneer BDR-UD04?
Fox_Mulder wrote:
Thu Jan 09, 2025 12:08 am
Pioneer BDR-UD04?
Yes it works with all drives but if you find a 43888 why bother?
zittrig
Post by zittrig »
@Fox_Mulder: But have a good look at the drive before buying if you want a 43888 with Pioneer drive only. Because since recently there are 43888 with LG's BU40N released also.
Fox_Mulder
zittrig wrote:
Thu Jan 09, 2025 1:40 pm
OK. Thanks for the info.
Can you see it on the packaging?
What disadvantage does the LG have compared to the Pioneer?
RobinStn
Post by RobinStn »
Hallo Coopervid,
I would appreciated it.
RobinStn wrote:
Thu Jan 09, 2025 9:08 pm
Hallo Coopervid,
Post your Makemkv info.
Fox_Mulder
Coopervid wrote:
Thu Jan 09, 2025 9:25 pm
Hallo Coopervid,
How much should the firmware cost? I'm trying to decide which is more worthwhile.
zittrig
Post by zittrig »
Fox_Mulder wrote:
Thu Jan 09, 2025 6:02 pm
IMO the BU40N is the best of the LG family so it wouldn't be a mistake to get one.
Marty explained some optical differences here ..
viewtopic.php?f=19&t=36199#top
RobinStn
Post by RobinStn »
Hallo Coopervid,
Drive informatie
Naam OS-apparaat: E:
Fabrikant: PIONEER
Product: BD-RW BDR-UD03
Revisie: 1.14
Serienummer: ...
Firmware datum: 2020-06-15
Bus encryptie flags: 1B
