Yes, it will be an L1 plot.
The only way to get an HDR plot is with a base-layer video input. An RPU is just metadata, the script can only plot them.
What is the benefit of this RPU replacement?deadchip12 wrote: ↑Tue Dec 24, 2024 11:52 pmI just used workflow 1 to inject DV web version's RPU to hdr10 bluray version of harry potter sorcerer stone.
what? replacement?
I will better explain my question.
Example the Harry Potter movie cited by @deadchip12
I have the 8.1 version made using rpu from you.
Then there is a P5 version on the web.
If I replace your rpu by the one from the P5 is there any benefit?
When both Generated P8 and a retail WEB P5 are available on my Google Drive, it's because the retail P5 rpu is cmv2.9 without dynamic L2 trims so the cmv4.0 generated RPU is better.
Thank you for explaining
I see. So I can only compare hdr plots (as well as screenshot brightness) if I run 6-2 on the original web video file. Since that seems to take too long, I may as well trust you and inject your rpu file from google drive instead. Will later try the new version of the tool to see if it runs a lot faster though.RESET_9999 wrote: ↑Thu Dec 26, 2024 4:26 pmYes, it will be an L1 plot.
Is there a way to adjust cmv4.0 in the RPU to better match peak brightness of a TV panel?
When we use workflow 7-2 to generate screenshots of web and bluray versions and compare their brightness, do we need to view the screenshots on an hdr screen, or sdr should suffice?
the rpu metadata are here to tell your TV about the content brightness. Your TV won't tone map it accurately if you lie about it.darrrkmanxxx wrote: ↑Fri Dec 27, 2024 11:00 amIs there a way to adjust cmv4.0 in the RPU to better match peak brightness of a TV panel?
You can only control the aggressiveness of the tone mapping with the analysis tunings. Lower L1 values mean less tone mapping resulting in a brighter image but potentially clipped.
Higher values mean more tone mapping resulting in a darker image without clipping in highlights. L1 Values under your TV internal brightness target (in tv-led) or the edid target (in LLDV), disable the TV tone mapping, and the content is displayed as it is, as intended...
I did a complete analysis tunings comparisons here: https://slow.pics/c/OA0pupEN
old cmv4.0 legacy, match almost 1:1 the peaks of workflow 6-2 (madvr plot)
Always HDR image, it doesn't matter if you watch it on an SDR display because you still see the real difference.deadchip12 wrote: ↑Fri Dec 27, 2024 12:16 pmWhen we use workflow 7-2 to generate screenshots of web and bluray versions and compare their brightness, do we need to view the screenshots on an hdr screen, or sdr should suffice?
SDR tone-mapping is the worst invention ever and is totally misleading and useless.
Thanks for explaining. How to interpret those? Is the madvr plot the best, because it has the most dynamics?RESET_9999 wrote: ↑Fri Dec 27, 2024 2:11 pmthe rpu metadata are here to tell your TV about the content brightness. Your TV won't tone map it accurately if you lie about it.darrrkmanxxx wrote: ↑Fri Dec 27, 2024 11:00 amIs there a way to adjust cmv4.0 in the RPU to better match peak brightness of a TV panel?
If I do the madvr measuremnt, I adjust cmv4.0 when I generate from madvr file with dovi_tool ,e.g.
Jumanji:
Mastering display luminance : min: 0.0050 cd/m2, max: 4000 cd/m2
Maximum Content Light Level : 3938 cd/m2
Maximum Frame-Average Light Level : 676 cd/m2
"cm_version": "V40",
"length": 10,
"level6": {
"max_display_mastering_luminance": 4000,
"min_display_mastering_luminance": 50,
"max_content_light_level": 3938,
"max_frame_average_light_level": 676
Soemtimes Maximum Content Light Level, Maximum Frame-Average Light Level are missing, what should I enter then?
No, madvr generated metadata (3-2) is the worst and not really suited for DV playback. Also, Madvr scene cut detection is not very good. It's quite sensitive to flashes/explosions/fast movement and can sometimes miss obvious scene cuts. The best dv metadata generation is one of the analysis tunings using Davinci Resolve. I prefer the ''balanced tuning'' which is the dovi_scripts default in workflow 3-1Thanks for explaining. How to interpret those? Is the madvr plot the best, because it has the most dynamics?
it doesn't matter, Level 6 metadata are 100% useless.It this correct or is there something else to adjust?
got it, do you have a video by chance on how to generate metadata with Davinci Resolve?RESET_9999 wrote: ↑Fri Dec 27, 2024 2:59 pmNo, madvr generated metadata (3-2) is the worst and not really suited for DV playback. Also, Madvr scene cut detection is not very good. It's quite sensitive to flashes/explosions/fast movement and can sometimes miss obvious scene cuts. The best dv metadata generation is one of the analysis tunings using Davinci Resolve. I prefer the ''balanced tuning'' which is the dovi_scripts default in workflow 3-1Thanks for explaining. How to interpret those? Is the madvr plot the best, because it has the most dynamics?
