deadchip12
When we use workflow 7-2 to generate screenshots of web and bluray versions and compare their brightness, do we need to view the screenshots on an hdr screen, or sdr should suffice?
the rpu metadata are here to tell your TV about the content brightness. Your TV won't tone map it accurately if you lie about it.darrrkmanxxx wrote: Fri Dec 27, 2024 11:00 am Is there a way to adjust cmv4.0 in the RPU to better match peak brightness of a TV panel?
You can only control the aggressiveness of the tone mapping with the analysis tunings. Lower L1 values mean less tone mapping resulting in a brighter image but potentially clipped.
Higher values mean more tone mapping resulting in a darker image without clipping in highlights. L1 Values under your TV internal brightness target (in tv-led) or the edid target (in LLDV), disable the TV tone mapping, and the content is displayed as it is, as intended...
I did a complete analysis tunings comparisons here: https://slow.pics/c/OA0pupEN
old cmv4.0 legacy, match almost 1:1 the peaks of workflow 6-2 (madvr plot)
Always HDR image, it doesn't matter if you watch it on an SDR display because you still see the real difference.deadchip12 wrote: Fri Dec 27, 2024 12:16 pm When we use workflow 7-2 to generate screenshots of web and bluray versions and compare their brightness, do we need to view the screenshots on an hdr screen, or sdr should suffice?
SDR tone-mapping is the worst invention ever and is totally misleading and useless.
darrrkmanxxx
Thanks for explaining. How to interpret those? Is the madvr plot the best, because it has the most dynamics?RESET_9999 wrote: Fri Dec 27, 2024 2:11 pmthe rpu metadata are here to tell your TV about the content brightness. Your TV won't tone map it accurately if you lie about it.darrrkmanxxx wrote: Fri Dec 27, 2024 11:00 am Is there a way to adjust cmv4.0 in the RPU to better match peak brightness of a TV panel?
If I do the madvr measuremnt, I adjust cmv4.0 when I generate from madvr file with dovi_tool ,e.g.
Jumanji:
Mastering display luminance : min: 0.0050 cd/m2, max: 4000 cd/m2
Maximum Content Light Level : 3938 cd/m2
Maximum Frame-Average Light Level : 676 cd/m2Code: Select all
"cm_version": "V40",
"length": 10,
"level6": {
"max_display_mastering_luminance": 4000,
"min_display_mastering_luminance": 50,
"max_content_light_level": 3938,
"max_frame_average_light_level": 676
}Soemtimes Maximum Content Light Level, Maximum Frame-Average Light Level are missing, what should I enter then?
No, madvr generated metadata (3-2) is the worst and not really suited for DV playback. Also, Madvr scene cut detection is not very good. It's quite sensitive to flashes/explosions/fast movement and can sometimes miss obvious scene cuts. The best dv metadata generation is one of the analysis tunings using Davinci Resolve. I prefer the ''balanced tuning'' which is the dovi_scripts default in workflow 3-1Thanks for explaining. How to interpret those? Is the madvr plot the best, because it has the most dynamics?
it doesn't matter, Level 6 metadata are 100% useless.It this correct or is there something else to adjust?
darrrkmanxxx
got it, do you have a video by chance on how to generate metadata with Davinci Resolve?RESET_9999 wrote: Fri Dec 27, 2024 2:59 pmNo, madvr generated metadata (3-2) is the worst and not really suited for DV playback. Also, Madvr scene cut detection is not very good. It's quite sensitive to flashes/explosions/fast movement and can sometimes miss obvious scene cuts. The best dv metadata generation is one of the analysis tunings using Davinci Resolve. I prefer the ''balanced tuning'' which is the dovi_scripts default in workflow 3-1Thanks for explaining. How to interpret those? Is the madvr plot the best, because it has the most dynamics?
deadchip12
@RESET_9999
I saw you just updated the Transfer CMv 4.0 Dolby Vision from WEB streaming to Profile 7 tutorial video. Would be great if you can do the same for the ADD Original Dolby Vision from WEB STREAMING to HDR10 Bluray Rip (P8 Hybrid) video as well, and a tutorial on how to use the new GUI in the latest dovi script version.
the p8 hybrid tuto doesnt really need to be updated... Nothing changed...
A couple of things were automated in the transfer cmv4.0 workflow so that's why I redid this one.
darrrkmanxxx
How can I tell if a device supports cmv4.0?RESET_9999 wrote: Sat Dec 28, 2024 1:27 pm the p8 hybrid tuto doesnt really need to be updated... Nothing changed...
voodoomamajuju
@RESET_9999 Just wanted to say thanks for the Dolby_vision_stuff sheet but I just noticed that the link is broken. Is the sheet hosted somewhere else now? Thanks again!
Yeah, I'm stupid. I was making space in my Google Drive and deleted a folder that contained the Excel sheet. I did a backup recently, so only one month of data is missing.voodoomamajuju wrote: Tue Dec 31, 2024 12:59 am @RESET_9999 Just wanted to say thanks for the Dolby_vision_stuff sheet but I just noticed that the link is broken. Is the sheet hosted somewhere else now? Thanks again!
the new link in my signature should work
skull88
Happens to the best of us, haha. Just in case, maybe this article could help recover deleted file(s) in future: https://support.google.com/drive/answer/1716222?hl=en
thanks but unfortunately, the Google Drive account was created with a VERY old email address(hotmail.com) I no longer have access and they require email verification.skull88 wrote: Tue Dec 31, 2024 1:42 pm Happens to the best of us, haha. Just in case, maybe this article could help recover deleted file(s) in future: https://support.google.com/drive/answer/1716222?hl=en
