ragico
Post by ragico »
Thank you for explaining
deadchip12
Post by deadchip12 »
RESET_9999 wrote:
Thu Dec 26, 2024 4:26 pm
Yes, it will be an L1 plot.
The only way to get an HDR plot is with a base-layer video input. An RPU is just metadata, the script can only plot them.
I see. So I can only compare hdr plots (as well as screenshot brightness) if I run 6-2 on the original web video file. Since that seems to take too long, I may as well trust you and inject your rpu file from google drive instead. Will later try the new version of the tool to see if it runs a lot faster though.
darrrkmanxxx
Post by darrrkmanxxx »
Is there a way to adjust cmv4.0 in the RPU to better match peak brightness of a TV panel?
deadchip12
When we use workflow 7-2 to generate screenshots of web and bluray versions and compare their brightness, do we need to view the screenshots on an hdr screen, or sdr should suffice?
darrrkmanxxx wrote:
Fri Dec 27, 2024 11:00 am
the rpu metadata are here to tell your TV about the content brightness. Your TV won't tone map it accurately if you lie about it.
You can only control the aggressiveness of the tone mapping with the analysis tunings. Lower L1 values mean less tone mapping resulting in a brighter image but potentially clipped.
Higher values mean more tone mapping resulting in a darker image without clipping in highlights. L1 Values under your TV internal brightness target (in tv-led) or the edid target (in LLDV), disable the TV tone mapping, and the content is displayed as it is, as intended...
I did a complete analysis tunings comparisons here: https://slow.pics/c/OA0pupEN
old cmv4.0 legacy, match almost 1:1 the peaks of workflow 6-2 (madvr plot)
deadchip12 wrote:
Fri Dec 27, 2024 12:16 pm
Always HDR image, it doesn't matter if you watch it on an SDR display because you still see the real difference.
SDR tone-mapping is the worst invention ever and is totally misleading and useless.
darrrkmanxxx
RESET_9999 wrote:
Fri Dec 27, 2024 2:11 pm
Thanks for explaining. How to interpret those? Is the madvr plot the best, because it has the most dynamics?
If I do the madvr measuremnt, I adjust cmv4.0 when I generate from madvr file with dovi_tool ,e.g.
Jumanji:
Maximum Content Light Level              : 3938 cd/m2
Maximum Frame-Average Light Level        : 676 cd/m2
https://github.com/quietvoid/dovi_tool/ ... cmv40.json
    "cm_version": "V40",
    "length": 10,
    "level6": {
        "max_display_mastering_luminance": 4000,
        "min_display_mastering_luminance": 50,
        "max_content_light_level": 3938,
        "max_frame_average_light_level": 676
It this correct or is there something else to adjust?
Soemtimes Maximum Content Light Level, Maximum Frame-Average Light Level are missing, what should I enter then?
No, madvr generated metadata (3-2) is the worst and not really suited for DV playback. Also, Madvr scene cut detection is not very good. It's quite sensitive to flashes/explosions/fast movement and can sometimes miss obvious scene cuts. The best dv metadata generation is one of the analysis tunings using Davinci Resolve. I prefer the ''balanced tuning'' which is the dovi_scripts default in workflow 3-1
it doesn't matter, Level 6 metadata are 100% useless.
darrrkmanxxx
RESET_9999 wrote:
Fri Dec 27, 2024 2:59 pm
got it, do you have a video by chance on how to generate metadata with Davinci Resolve?
Post by SamuriHL »
deadchip12
@RESET_9999
I saw you just updated the Transfer CMv 4.0 Dolby Vision from WEB streaming to Profile 7 tutorial video. Would be great if you can do the same for the ADD Original Dolby Vision from WEB STREAMING to HDR10 Bluray Rip (P8 Hybrid) video as well, and a tutorial on how to use the new GUI in the latest dovi script version.
the p8 hybrid tuto doesnt really need to be updated... Nothing changed...
A couple of things were automated in the transfer cmv4.0 workflow so that's why I redid this one.
darrrkmanxxx
RESET_9999 wrote:
Sat Dec 28, 2024 1:27 pm
How can I tell if a device supports cmv4.0?
just try one of the cmv4.0 rpu test files
https://drive.google.com/drive/u/1/fold ... eyGDQEGJuF
voodoomamajuju
Post by voodoomamajuju »
@RESET_9999 Just wanted to say thanks for the Dolby_vision_stuff sheet but I just noticed that the link is broken. Is the sheet hosted somewhere else now? Thanks again!
