Kingdom Hospital : Disk 4 : Episode 13 : Fails
ossiemoore
#1 Post by ossiemoore » Thu Dec 26, 2024 5:01 pm
The "Stephen King Presents Kingdom Hospital" Complete Series DVD contains four disks. Disk four has two episodes (12 and 13). Everything works until the last episode (13 titled Finale).
What I tried:
- Normal extraction of the episode. I do see the following in the log window...
MakeMKV v1.17.8 darwin(arm64-release) started
Optical drive "BD-RE PIONEER BD-RW BDR-XD08U 1.02 DHDL302773UCd" opened in OS access mode.
Title #1 was added (9 cell(s), 0:41:01)
Title #2 was added (11 cell(s), 1:17:51)
Title #3 was added (2 cell(s), 0:15:21)
Title #4 was added (2 cell(s), 0:14:46)
Title #5 was added (2 cell(s), 0:07:16)
Title #6 was added (2 cell(s), 0:08:19)
Title #7 was added (5 cell(s), 0:45:39)
Title #8 has length of 15 seconds which is less than minimum title length of 120 seconds and was therefore skipped
The source file '/VIDEO_TS/VTS_03_1.VOB' is corrupt or invalid at offset 10240, attempting to work around
Saving 1 titles into directory /Volumes/T9/media/movies
Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/VIDEO_TS/VTS_02_1.VOB' at offset '2739161088'
Error 'Posix error - Input/output error' occurred while reading '/dev/rdisk4' at offset '2739161088'
Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/VIDEO_TS/VTS_02_1.VOB' at offset '2739292160'
Error 'Posix error - Input/output error' occurred while reading '/dev/rdisk4' at offset '2739292160'
Failed to save title 1 to file /Volumes/T9/media/movies/Stephen King Presents Kingdom Hospital (Disc 4)-B1_t01.mkv
Encountered 24 errors of type 'Read Error' - see http://www.makemkv.com/errors/dvdread/
0 titles saved, 1 failed
- Using the Backup option for the disk (which fails too)
ossiemoore
Re: Kingdom Hospital : Disk 4 : Episode 13 : Fails
#2 Post by ossiemoore » Thu Dec 26, 2024 8:23 pm
A follow-up to my post is that the disk plays normally for that (and all) episodes when using the same workstation but using the macOS DVD Player application.
Let me know if you need anything else in a typical DVD report of this type.
#3 Post by dcoke22 » Thu Jan 16, 2025 1:58 pm
Errors like this:
indicate that there's a spot on the disc that MakeMKV was unable to read correctly. The standard advice is to gently clean the disc and try again.
When you play the disc in a player, the player blows past read errors and hopes the resulting visual or audio errors are too small to notice. MakeMKV, on the other hand, is trying to make a perfect copy.
