deadchip12
#10486
Post
by deadchip12 » Wed Dec 25, 2024 9:34 am
RESET_9999 wrote: Wed Dec 25, 2024 1:00 am
you can ignore it.
These warnings are new in the latest metafier.exe version...I'm not sure what they mean but they don't matter because metafier is just an additional metadata check.
What are the differences between the MKV, TS, and MP4 version of the DoVi_Scripts bat file?
I normally just downloaded the DoVi_Scripts_MKV.bat and ran it fine, but today when I tried using workflow 6-2 to measure brightness of this file Kingdom.Of.The.Planet.Of.The.Apes.2024.2160p.WEB-DL.DV.P5.ENG.LATINO.DDP5.1.Atmos.H265.MP4-BEN.THE.MEN.mp4, it has run for hours and created a temp folder of over 100GB. Something went wrong.
#10487
Post
by RESET_9999 » Wed Dec 25, 2024 1:47 pm
madvr cannot measure profile 5 video directly so the script converts it to prores first.
the only difference between the script versions is the muxing container
deadchip12
#10488
Post
by deadchip12 » Thu Dec 26, 2024 8:50 am
RESET_9999 wrote: Wed Dec 25, 2024 1:47 pm
It also takes that long on your end? I had been waiting for hours and it was still running. And the temp folder size was alarming.
Btw, I'm still having trouble with kingdom of the planet of the apes movie. I downloaded your web rpu from the google drive folder, ran workflow 6-2 to get its hdr plot and compare it against the plot of the bluray hdr10 version to see if they are similar. They are not.
web rpu
bluray version
#10489
Post
by RESET_9999 » Thu Dec 26, 2024 1:41 pm
deadchip12 wrote: Thu Dec 26, 2024 8:50 am
yes, there are many blended shots(the colorist manually merged shots together) but it should be fine and the values are mostly under 600-500nits so they shouldn't matter for most TVs.
yes, it runs about 24fps(1x) and the large HDD usage is also normal because prores is a lossless codec.
But in the latest beta, I improved the speed about 2times depending on your CPU. On my end, it now runs at 50fps(2.2x)
https://drive.google.com/file/d/128gq8a ... drive_link
deadchip12
#10490
Post
by deadchip12 » Thu Dec 26, 2024 3:03 pm
RESET_9999 wrote: Thu Dec 26, 2024 1:41 pm
The thing is in one of your earlier posts you showed me the hdr plot of the web version versus the bluray version for this movie and they looked very similar.
https://slow.pics/s/wQzSIwSH
#10491
Post
by RESET_9999 » Thu Dec 26, 2024 3:10 pm
it's because both plots are a measurement of the base layer with workflow 6-2.
RPU L1 plot is different because it's done by the colorist and the dolby algorithm.
deadchip12
#10492
Post
by deadchip12 » Thu Dec 26, 2024 4:23 pm
RESET_9999 wrote: Thu Dec 26, 2024 3:10 pm
I used workflow 6-2 too. The input file was your web rpu.
Are you saying if i use workflow 6-2 with your web rpu, it will generate the L1 plot, not the hdr plot?
#10493
Post
by RESET_9999 » Thu Dec 26, 2024 4:26 pm
Yes, it will be an L1 plot.
The only way to get an HDR plot is with a base-layer video input. An RPU is just metadata, the script can only plot them.
ragico
#10494
Post
by ragico » Thu Dec 26, 2024 5:03 pm
deadchip12 wrote: Tue Dec 24, 2024 11:52 pm
I just used workflow 1 to inject DV web version's RPU to hdr10 bluray version of harry potter sorcerer stone.
What is the benefit of this RPU replacement?
#10495
Post
by RESET_9999 » Thu Dec 26, 2024 5:46 pm
ragico wrote: Thu Dec 26, 2024 5:03 pm
what? replacement?
ragico
#10496
Post
by ragico » Thu Dec 26, 2024 5:54 pm
I will better explain my question.
Example the Harry Potter movie cited by @deadchip12
I have the 8.1 version made using rpu from you.
Then there is a P5 version on the web.
If I replace your rpu by the one from the P5 is there any benefit?
#10497
Post
by RESET_9999 » Thu Dec 26, 2024 5:57 pm
When both Generated P8 and a retail WEB P5 are available on my Google Drive, it's because the retail P5 rpu is cmv2.9 without dynamic L2 trims so the cmv4.0 generated RPU is better.
ragico
#10498
Post
by ragico » Thu Dec 26, 2024 6:09 pm
Thank you for explaining
deadchip12
#10499
Post
by deadchip12 » Fri Dec 27, 2024 12:25 am
RESET_9999 wrote: Thu Dec 26, 2024 4:26 pm
I see. So I can only compare hdr plots (as well as screenshot brightness) if I run 6-2 on the original web video file. Since that seems to take too long, I may as well trust you and inject your rpu file from google drive instead. Will later try the new version of the tool to see if it runs a lot faster though.
darrrkmanxxx
#10500
Post
by darrrkmanxxx » Fri Dec 27, 2024 11:00 am
Is there a way to adjust cmv4.0 in the RPU to better match peak brightness of a TV panel?
