LibreDrive on Pioneer XS07UHD
storageisfun
Post by storageisfun » Wed Dec 25, 2024 7:18 pm
I purchased a Pioneer XS07UHD for myself.
I have read that you need to flash certain firmware, but on this specific drive you can't do that.
When I try to rip a 4k UHD movie it says
MakeMKV v1.17.8 win(x64-release) started
Saved FW dump file as C:\
Please send the file "C:\
Error 'Scsi error - ILLEGAL REQUEST:CANNOT WRITE MEDIUM - INCOMPATIBLE FORMAT' occurred while issuing SCSI command A30..0020..03F to device 'SPT' occurred while issuing SCSI command A30..0020..07F to device 'SPTI:\Device\CdRom0'
Error 'Scsi error - ILLEGAL REQUEST:CANNOT WRITE MEDIUM - INCOMPATIBLE FORMAT' occurred while issuing SCSI command A40..0020..07F to device 'SPTI:\Device\CdRom0'
Error 'Scsi error - ILLEGAL REQUEST:CANNOT WRITE MEDIUM - INCOMPATIBLE FORMAT' occurred while issuing SCSI command A30..0020..0BF to device 'SPTI:\Device\CdRom0'
Error 'Scsi error - ILLEGAL REQUEST:CANNOT WRITE MEDIUM - INCOMPATIBLE FORMAT' occurred while issuing SCSI command A40..0020..0BF to device 'SPTI:\Device\CdRom0'
Error 'Scsi error - ILLEGAL REQUEST:CANNOT WRITE MEDIUM - INCOMPATIBLE FORMAT' occurred while issuing SCSI command A30..0020..0FF to device 'SPTI:\Device\CdRom0'
Error 'Scsi error - ILLEGAL REQUEST:CANNOT WRITE MEDIUM - INCOMPATIBLE FORMAT' occurred while issuing SCSI command A40..0020..0FF to device 'SPTI:\Device\CdRom0'
Error 'Scsi error - ILLEGAL REQUEST:CANNOT WRITE MEDIUM - INCOMPATIBLE FORMAT' occurred while issuing SCSI command A40..002000800 to device 'SPTI:\Device\CdRom0'
Error 'Scsi error - ILLEGAL REQUEST:CANNOT WRITE MEDIUM - INCOMPATIBLE FORMAT' occurred while issuing SCSI command A30..0020..03F to device 'SPTI:\Device\CdRom0'
Error 'Scsi error - ILLEGAL REQUEST:CANNOT WRITE MEDIUM - INCOMPATIBLE FORMAT' occurred while issuing SCSI command A40..0020..03F to device 'SPTI:\Device\CdRom0'
Error 'Scsi error - ILLEGAL REQUEST:CANNOT WRITE MEDIUM - INCOMPATIBLE FORMAT' occurred while issuing SCSI command A30..0020..07F to device 'SPTI:\Device\CdRom0'
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT ESTABLISHED' occurred while issuing SCSI command AD010..080002400 to device 'SPTI:\Device\CdRom0'
Saved AACS dump file as C:
It also says
Manufacturer: PIONEER
Product: BD-RW BDR-XS07U
Revision: 1.04
Serial number: ...
Firmware date: 2024-10-09
Bus encryption flags: 13
Highest AACS version: 72
Firmware version: ID05
Re: LibreDrive on Pioneer XS07UHD
Post by MartyMcNuts » Wed Dec 25, 2024 8:55 pm
It also says
Revision: 1.04
Serial number: ...
Return it. It cannot be used for UHD discs. It cannot be made UHD compatible or have libredrive enabled as the firmware is newer than December 2022.
storageisfun
Post by storageisfun » Mon Dec 30, 2024 2:36 am
I got a different drive from Buffalo and I can't seem to get the firmware to flash. It provides an error code when I use the SDFFlasher GUI when I try to write the firmware. I used the firmware that it said on the website.
Also, do you know when every post will stop having to be approved by a moderator?
Post by MartyMcNuts » Mon Dec 30, 2024 4:43 am
Please don't ask the same question in multiple threads. I have replied to you in the SDFtool FLasher thread.
