Error reading Captain America BD (Can't read AACS VID)
jhodgesatmb
Post by jhodgesatmb » Tue Oct 25, 2011 7:23 pm
My preferences have 'Always create BD+ dumps' checked but nothing is being created for this disk.
The error in the console says: "Can't read AACS VID from disc - most likely current AACS host certificate is revoked by your drive.
I have seen this error in other forum posts and generally the response is that a new svq is needed. Of course, the disk was just delivered so maybe I am jumping the gun but it seems I should be able to create a dump like I did when X-Men First Class came out, but not this time.
setarip_old
Re: Error reading Captain America BD (Can't read AACS VID)
Post by setarip_old » Tue Oct 25, 2011 9:21 pm
Hi!
"Captain America" does NOT contain BD+...
reebok
Post by reebok » Tue Oct 25, 2011 10:28 pm
mine ripped fine. 1.6.15.
fr0z3ng33k
Post by fr0z3ng33k » Wed Oct 26, 2011 1:30 pm
jhodgesatmb wrote:My preferences have 'Always create BD+ dumps' checked but nothing is being created for this disk.
It works if you register your MakeMKV ver (1.6.15) with this key:
T-LyW5B7qmbGataV5eGd_dWVklURVn0gV8o572y_cyhaZrANmfAlWh4MbYlxKfInkVCS
jhodgesatmb
Post by jhodgesatmb » Wed Oct 26, 2011 3:00 pm
Thanks for the responses. I have a registered copy of MkMKV so I doubt that is the problem. I have a call into LaCie about the drive. I just put in a BD that I encoded a long time ago and got the same error, so I bet the problem happened when I upgraded to OSX Lion last week. I wonder if anyone else has experienced a problem like this.
setarip_old
Post by setarip_old » Thu Oct 27, 2011 5:08 am
Then your drive may be at fault, either failing or dirty.
Try run a cleaning disc on the drive. Maxell makes one that sells for about $10US...
