LibreDrive on Pioneer XS07UHD
storageisfun
#1 Post by storageisfun » Wed Dec 25, 2024 7:18 pm
I purchased a Pioneer XS07UHD for myself.
I have read that you need to flash certain firmware, but on this specific drive you can't do that.
When I try to rip a 4k UHD movie it says
MakeMKV v1.17.8 win(x64-release) started
Saved FW dump file as C:\
Please send the file "C:\
Error 'Scsi error - ILLEGAL REQUEST:CANNOT WRITE MEDIUM - INCOMPATIBLE FORMAT' occurred while issuing SCSI command A30..0020..03F to device 'SPT' occurred while issuing SCSI command A30..0020..07F to device 'SPTI:\Device\CdRom0'
Error 'Scsi error - ILLEGAL REQUEST:CANNOT WRITE MEDIUM - INCOMPATIBLE FORMAT' occurred while issuing SCSI command A40..0020..07F to device 'SPTI:\Device\CdRom0'
Error 'Scsi error - ILLEGAL REQUEST:CANNOT WRITE MEDIUM - INCOMPATIBLE FORMAT' occurred while issuing SCSI command A30..0020..0BF to device 'SPTI:\Device\CdRom0'
Error 'Scsi error - ILLEGAL REQUEST:CANNOT WRITE MEDIUM - INCOMPATIBLE FORMAT' occurred while issuing SCSI command A40..0020..0BF to device 'SPTI:\Device\CdRom0'
Error 'Scsi error - ILLEGAL REQUEST:CANNOT WRITE MEDIUM - INCOMPATIBLE FORMAT' occurred while issuing SCSI command A30..0020..0FF to device 'SPTI:\Device\CdRom0'
Error 'Scsi error - ILLEGAL REQUEST:CANNOT WRITE MEDIUM - INCOMPATIBLE FORMAT' occurred while issuing SCSI command A40..0020..0FF to device 'SPTI:\Device\CdRom0'
Error 'Scsi error - ILLEGAL REQUEST:CANNOT WRITE MEDIUM - INCOMPATIBLE FORMAT' occurred while issuing SCSI command A40..002000800 to device 'SPTI:\Device\CdRom0'
Error 'Scsi error - ILLEGAL REQUEST:CANNOT WRITE MEDIUM - INCOMPATIBLE FORMAT' occurred while issuing SCSI command A30..0020..03F to device 'SPTI:\Device\CdRom0'
Error 'Scsi error - ILLEGAL REQUEST:CANNOT WRITE MEDIUM - INCOMPATIBLE FORMAT' occurred while issuing SCSI command A40..0020..03F to device 'SPTI:\Device\CdRom0'
Error 'Scsi error - ILLEGAL REQUEST:CANNOT WRITE MEDIUM - INCOMPATIBLE FORMAT' occurred while issuing SCSI command A30..0020..07F to device 'SPTI:\Device\CdRom0'
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT ESTABLISHED' occurred while issuing SCSI command AD010..080002400 to device 'SPTI:\Device\CdRom0'
Saved AACS dump file as C:
It also says
Manufacturer: PIONEER
Product: BD-RW BDR-XS07U
Revision: 1.04
Serial number: ...
Firmware date: 2024-10-09
Bus encryption flags: 13
Highest AACS version: 72
Firmware version: ID05
Re: LibreDrive on Pioneer XS07UHD
#2 Post by MartyMcNuts » Wed Dec 25, 2024 8:55 pm
It also says
Revision: 1.04
Serial number: ...
Return it. It cannot be used for UHD discs. It cannot be made UHD compatible or have libredrive enabled as the firmware is newer than December 2022.
storageisfun
#3 Post by storageisfun » Mon Dec 30, 2024 2:36 am
I got a different drive from Buffalo and I can't seem to get the firmware to flash. It provides an error code when I use the SDFFlasher GUI when I try to write the firmware. I used the firmware that it said on the website.
Also, do you know when every post will stop having to be approved by a moderator?
#4 Post by MartyMcNuts » Mon Dec 30, 2024 4:43 am
Please don't ask the same question in multiple threads. I have replied to you in the SDFtool FLasher thread.
