Hello, I have the following drive. I was reading elsewhere in this forum that it appeared possible to upgrade this drive for the capability to read 4k UHD discs. Is this still true today? Any help would be appreciated.
Manufacturer: PIONEER
Product: BD-RW BDR-XD05
Revision: 3.10
Serial number: [redacted]
Firmware date: 2017-06-22
Highest AACS version: 81
Drive platform: RS8232
Firmware name: PIONEER BDR-XD05
Firmware version: 3.10/ID34
LibreDrive for Pioneer drives
PM sent.isolation wrote: Mon Dec 23, 2024 3:54 am Hello, I have the following drive. I was reading elsewhere in this forum that it appeared possible to upgrade this drive for the capability to read 4k UHD discs. Is this still true today? Any help would be appreciated.
Revision: 3.10
razzar
Anyone who can help me out with flashing alternative firmware to unlock the UHD BD capabilities of this drive?
Product: BD-RW BDR-212V
Revision: 1.02
Firmware date: 2022-05-31
Bus encryption flags: 13
Firmware version: ID06
Revision: 1.02
PM is coming.razzar wrote: Mon Dec 23, 2024 2:23 pm Anyone who can help me out with flashing alternative firmware to unlock the UHD BD capabilities of this drive?
Revision: 1.02
alexander_ac
According to Pioneer there’s no going backBillycar11 wrote: Sun Dec 22, 2024 3:21 amyeah sorry man its ruined now after you updated it.alexander_ac wrote: Sun Dec 22, 2024 3:14 am Hi,
MakeMKV has stopped reading Blu-ray UHD disks, I updated it's firmware to 1.05 which after reading the first dozen or so pages of this thread maybe the cause. Here are the drive details.
Product: BD-RW BDR-S12U
Revision: 1.05
Serial number: AGDL004972WL
Firmware date: 2023-08-01
Highest AACS version: 72
Drive platform: Pioneer RS8F01
Firmware version: ID43
Any assistance to fix this is appreciated.
return it if you can.
i have some pioneers with old fw if you want one
you have to remember this is an exploit in the fw pioneer patched it there may be no more exploits in it.alexander_ac wrote: Mon Dec 23, 2024 8:53 pmAccording to Pioneer there’s no going backBillycar11 wrote: Sun Dec 22, 2024 3:21 am
i have some pioneers with old fw if you want one, but isn’t it just a matter of updating MakeMKV to support it? That seems to be what’s been done before
razzar
Much appreciated.Coopervid wrote: Mon Dec 23, 2024 4:07 pmPM is coming.razzar wrote: Mon Dec 23, 2024 2:23 pm Anyone who can help me out with flashing alternative firmware to unlock the UHD BD capabilities of this drive?
Revision: 1.02
Revision: 1.02
Serial number: [Redacter]
Firmware date: 2022-03-07
Highest AACS version: 61
Drive platform: RS8F01
Firmware version: 1.02/ID43
isolation
Thank you! Worked perfectly.Coopervid wrote: Mon Dec 23, 2024 10:28 amPM sent.isolation wrote: Mon Dec 23, 2024 3:54 am Hello, I have the following drive. I was reading elsewhere in this forum that it appeared possible to upgrade this drive for the capability to read 4k UHD discs. Is this still true today? Any help would be appreciated.
Revision: 3.10
ETHREAL1
Have a Drive that looks like it should be supported but is not;
OS device name: F:
Product: BD-RW BDR-XS07U
Revision: 1.03
Serial number: ...
Firmware date: 2023-01-06
Highest AACS version: 77
Firmware version: ID05
OS device name: F:
Revision: 1.03
Serial number: ...
truskino
Dear Mike,
how can I fix my BDR-XD05TB?
Can't find the right information to do so.
The current status is "Possible, not yet enabled", and UHD discs can't be read by Makemkv and Windows too.
Thanks for helping,
Luca
Thanks for helping,
Luca
Pioneer disabled ROM changes in their December 2022 update, making it (currently) impossible to update these drives to read UHD disks. Since the software that they authorize to use that mode isn't available anymore, those drives are useless as far as UHD is concerned.
drknight71
Wanted kernel firmware dump:
viewtopic.php?p=165131#p165131
ETHREAL1
Are you replying to me? If so should I try and return the drive?Woodstock wrote: Wed Dec 25, 2024 5:11 pm Pioneer disabled ROM changes in their December 2022 update, making it (currently) impossible to update these drives to read UHD disks. Since the software that they authorize to use that mode isn't available anymore, those drives are useless as far as UHD is concerned.
Yes, your drive was built after they disabled UHD. If your purpose is to rip UHDs, then yes, you should return that drive for a refund.
lurker2100
Based on recent messages, it looks like this drive can be made to read UHD discs. Is that true?
OS device name: E:
Revision: 3.10
Serial number: ********
Highest AACS version: 47
OS device name: E:
Revision: 3.10
