Pioneer BDR-X12 Flashed with Success!!
Merry Christmas Guy's!
When i thought my pioneer BDR-209 died (Anyway i managed to bring it back Alive!!),
i immediately placed an order for a used set of a Pioneer BDR-X12.
Details are listed below.
OS device name: G:
Manufacturer: PIONEER
Product: BD-RW BDR-X12
Revision: 1.03
Serial number: ...
Firmware date: 2020-08-05
Highest AACS version: 68
Drive platform: RS9000
Firmware name: PIONEER BDR-X12T
Firmware version: 1.03/ID15
OS device name: G:
Revision: 1.03
Serial number: ...
Re: Pioneer BDR-X12 Flashed with Success!!
A Big Thanks to Coopervid for providing the Firmware Flasher for my BDR-X12!
Now its Libre Enabled and listed as a BDR-X12U.
just take note that the "Drive Platform Number has changed to RS9001, previously it was RS9000.
Everything is working fine and dandy!
Cheers!!
Cheers!!
below is the MakeMkv readout now.
OS device name: \Device\CdRom3
Product: BD-RW BDR-X12U
Revision: 1.04
Serial number: ....
Firmware date: 2022-02-10
Drive platform: RS9001
Firmware version: 1.04/ID43
Revision: 1.04
Serial number: ....
My windows 11 desktop tower casing with 4 Pioneer Libre enabled drives. Plus 2 Slim Verbatim 43888 with Pioneer drives in them. (Pretty lucky i received the Pioneer versions instead of the LG versions)
@Coopervid
I am in need of the firmware for my BDR-X12. Thanks in advance.
Revision: 1.04
Serial number: ...
Firmware date: 2022-02-18
Highest AACS version: 77
Firmware version: 1.04/ID56
Revision: 1.04
Serial number: ...
PM sent.Tydirium wrote: Sat Mar 15, 2025 4:29 pm @Coopervid
Revision: 1.04
Serial number: ...
ThanksCoopervid wrote: Sun Mar 16, 2025 8:37 pmPM sent.Tydirium wrote: Sat Mar 15, 2025 4:29 pm @Coopervid
Revision: 1.04
Serial number: ...
Hi, how do I get the firmware for my Pioneer BDR-X12?
just email me see below
Batman&throbbin
@coopervidCoopervid wrote: Sun Mar 16, 2025 8:37 pmPM sent.Tydirium wrote: Sat Mar 15, 2025 4:29 pm @Coopervid
Revision: 1.04
Serial number: ...
Just out of interest did this advance (sidegrade) to rs9001 1.04 (1.04/ID43)?
TIA
Yes. Why are you asking?Batman&throbbin wrote: Tue May 27, 2025 3:19 pm@coopervidCoopervid wrote: Sun Mar 16, 2025 8:37 pmPM sent.Tydirium wrote: Sat Mar 15, 2025 4:29 pm @Coopervid
Revision: 1.04
Serial number: ...
TIA
Batman&throbbin
Thanks for responding, I have an x12 too.
Can you please help with the same?
Is there enough info with the attached?
- FF01885A-5187-40F1-9BD5-6D560F70AAAE.jpeg (145.98 KiB) Viewed 26420 times
Batman&throbbin
Also forgot to mention.
Was puzzled by the Multi-storey drives Yeti had showing S11 1.53 each of the four (in his drive selector)
TIA
TIA
