Pioneer BDR-212DBK vs BDR-212V
Stormy1
Re: Pioneer BDR-212DBK vs BDR-212V
New Owner of a BDR-212V
OS device name: H:
Manufacturer: PIONEER
Product: BD-RW BDR-212V
Revision: 1.02
Serial number:
Firmware date: 2022-05-31
Bus encryption flags: 13
Highest AACS version: 35
Firmware version: ID06
@Coopervid can you help me out with instructions to flash the drive? Thank you!
OS device name: H:
Revision: 1.02
Serial number:
Read your PM. Merry Christmas!D0do42 wrote: Tue Dec 24, 2024 6:33 pm Many thanks for the quick response, Coopervid! That worked like a charm. Any way to send you a tip?
Merry Christmas everyone!
PM sent.Stormy1 wrote: Wed Dec 25, 2024 2:40 am New Owner of a BDR-212V
OS device name: H:
Revision: 1.02
Serial number:
ddockrx
I have been using Pioneer drives for years and when I finally decided to build a dedicated Plex server, my oldest one became unresponsive. I bought the one that seemed to be the closest to my older drive, just a newer updated model. It happened to be a BDR-212DBK. I have been using it a little over a year with makeMKV with a lot of success. I noticed that some newer releases are going away from blu-ray and now only offered in 4K (last round of Disney+ stuff). Several threads mentioned the 12/22 point of no return firmware for UHD compatibility and no longer being able to revert back. Mine is on the latest firmware, but before 12/22:
Product: BD-RW BDR-212D
Revision: 1.03
Serial number: -omitted-
Firmware date: 2022-10-13
Highest AACS version: 81
Drive platform: RS8F00
Firmware version: 1.03/ID61
Did I luck out or just miss out the chance for my drive to be UHD friendly?
Revision: 1.03
your are in luck email me for the flasherddockrx wrote: Fri Jan 03, 2025 5:10 am I have been using Pioneer drives for years and when I finally decided to build a dedicated Plex server, my oldest one became unresponsive. I bought the one that seemed to be the closest to my older drive, just a newer updated model. It happened to be a BDR-212DBK. I have been using it a little over a year with makeMKV with a lot of success. I noticed that some newer releases are going away from blu-ray and now only offered in 4K (last round of Disney+ stuff). Several threads mentioned the 12/22 point of no return firmware for UHD compatibility and no longer being able to revert back. Mine is on the latest firmware, but before 12/22:
Revision: 1.03
see below
kae9797
Hi and a Happy New Year to everyone!
I'm a proud New Owner of a BDR-212V drive!
I'm looking for help on how to flash it to read and rip UHD discs.
Any help would be welcome!
I have been using Make MKV for years and just replaced my old LG drive with a new Pioneer.
I just joined up on the forum so I don't know if I can receive PMs just yet!
So if anybody can help me you might need to reach me by email!
Thanks , I'm looking forward to using this new drive!
I see that other people with the same drive have been able to flash them!
OS device name: M:
Revision: 1.02
Serial number: XXXXXXXXXXXX
Highest AACS version: 78
Again thanks for looking!
OS device name: M:
Revision: 1.02
PM sent.kae9797 wrote: Fri Jan 03, 2025 6:52 am Hi and a Happy New Year to everyone!
OS device name: M:
Revision: 1.02
kae9797
Thank you. Got it and it worked like a charm!
kae9797
Wow!!
I just finished ripping some 4K disc and wow!
The Pioneer drive is fast and very quiet, I can barely hear it!
Anyway thanks for the help Coopervid.
Now I have the star wars UHD box set That gave me a lot of trouble ripping them a few
years ago,, I think I will take another crack at those and see
if this drive does better than my old LG drive did!
Mikx0
Can I please have help on how to flash BDR-212V?
OS device name: F:
Revision: 1.02
Serial number: ...
Highest AACS version: 57
OS device name: F:
Revision: 1.02
Serial number: ...
cerjzc
Just received my BDR-212V to replace a failing LG drive. Would appreciate any help with getting the firmware information for flashing.
Revision: 1.02
Serial number: ...
Revision: 1.02
Serial number: ...
DustySensors
Hi there! I received a lovely BDR-212V drive for Christmas and I am looking forward to updating the firmware to work with UHD discs (and LibreDrive if possible) in the future.
I am currently working out of Linux at the moment, but if Windows is needed, I do have access to this OS as well. Below is what is being shown by MakeMKV (v1.17.8, flatpak):
If someone could send me instructions for my drive, it would be greatly appreciated! Thank you for your time and I hope you have a great rest of your weekend!
Best,
DustySensors
OS device name: /dev/sr0
Revision: 1.02
Serial number: [redacted]
Best,
DustySensors
yeah just email me for the flasher send that infoDustySensors wrote: Sun Jan 05, 2025 2:43 am Hi there! I received a lovely BDR-212V drive for Christmas and I am looking forward to updating the firmware to work with UHD discs (and LibreDrive if possible) in the future.
Drive InformationLibreDrive InformationCode: Select all
OS device name: /dev/sr0 Manufacturer: PIONEER Product: BD-RW BDR-212V Revision: 1.02 Serial number: [redacted] Firmware date: 2022-05-31 Bus encryption flags: 13No disc insertedCode: Select all
Status: Possible, not yet enabled Drive platform: Pioneer RS8F00 Firmware version: ID06
Best,
DustySensors
DustySensors
Thanks for the reply! email sent!Billycar11 wrote: Sun Jan 05, 2025 2:47 amyeah just email me for the flasher send that infoDustySensors wrote: Sun Jan 05, 2025 2:43 am Hi there! I received a lovely BDR-212V drive for Christmas and I am looking forward to updating the firmware to work with UHD discs (and LibreDrive if possible) in the future.
Best,
DustySensors
flasher sent
