LibreDrive for Pioneer drives
isolation
#1201 Post by isolation » Mon Dec 23, 2024 3:54 am
Hello, I have the following drive. I was reading elsewhere in this forum that it appeared possible to upgrade this drive for the capability to read 4k UHD discs. Is this still true today? Any help would be appreciated.
Manufacturer: PIONEER
Product: BD-RW BDR-XD05
Revision: 3.10
Serial number: [redacted]
Firmware date: 2017-06-22
Highest AACS version: 81
Drive platform: RS8232
Firmware name: PIONEER BDR-XD05
Firmware version: 3.10/ID34
#1202 Post by Coopervid » Mon Dec 23, 2024 10:28 am
isolation wrote: Mon Dec 23, 2024 3:54 am Hello, I have the following drive. I was reading elsewhere in this forum that it appeared possible to upgrade this drive for the capability to read 4k UHD discs. Is this still true today? Any help would be appreciated.
Revision: 3.10
PM sent.
razzar
#1203 Post by razzar » Mon Dec 23, 2024 2:23 pm
Anyone who can help me out with flashing alternative firmware to unlock the UHD BD capabilities of this drive?
Product: BD-RW BDR-212V
Revision: 1.02
Firmware date: 2022-05-31
Bus encryption flags: 13
Firmware version: ID06
#1204 Post by Coopervid » Mon Dec 23, 2024 4:07 pm
razzar wrote: Mon Dec 23, 2024 2:23 pm Anyone who can help me out with flashing alternative firmware to unlock the UHD BD capabilities of this drive?
Revision: 1.02
PM is coming.
alexander_ac
#1205 Post by alexander_ac » Mon Dec 23, 2024 8:53 pm
Billycar11 wrote: Sun Dec 22, 2024 3:21 am
alexander_ac wrote: Sun Dec 22, 2024 3:14 am Hi,
MakeMKV has stopped reading Blu-ray UHD disks, I updated it's firmware to 1.05 which after reading the first dozen or so pages of this thread maybe the cause. Here are the drive details.
Product: BD-RW BDR-S12U
Revision: 1.05
Serial number: AGDL004972WL
Firmware date: 2023-08-01
Highest AACS version: 72
Drive platform: Pioneer RS8F01
Firmware version: ID43
Any assistance to fix this is appreciated.
yeah sorry man its ruined now after you updated it.
return it if you can.
i have some pioneers with old fw if you want one
According to Pioneer there’s no going back 😔, but isn’t it just a matter of updating MakeMKV to support it? That seems to be what’s been done before
#1206 Post by Billycar11 » Mon Dec 23, 2024 9:02 pm
alexander_ac wrote: Mon Dec 23, 2024 8:53 pm
you have to remember this is an exploit in the fw pioneer patched it there may be no more exploits in it.
razzar
#1207 Post by razzar » Tue Dec 24, 2024 2:31 am
Coopervid wrote: Mon Dec 23, 2024 4:07 pm
Revision: 1.02
PM is coming.
Much appreciated. :)
Revision: 1.02
Serial number: [Redacter]
Firmware date: 2022-03-07
Highest AACS version: 61
Drive platform: RS8F01
Firmware version: 1.02/ID43
isolation
#1208 Post by isolation » Tue Dec 24, 2024 4:37 am
Coopervid wrote: Mon Dec 23, 2024 10:28 am
Revision: 3.10
PM sent.
Thank you! Worked perfectly.
ETHREAL1
#1209 Post by ETHREAL1 » Wed Dec 25, 2024 3:13 pm
Have a Drive that looks like it should be supported but is not;
OS device name: F:
Product: BD-RW BDR-XS07U
Revision: 1.03
Serial number: ...
Firmware date: 2023-01-06
Highest AACS version: 77
Firmware version: ID05
truskino
#1210 Post by truskino » Wed Dec 25, 2024 4:57 pm
Dear Mike,
how can I fix my BDR-XD05TB?
Can't find the right information to do so.
The current status is "Possible, not yet enabled", and UHD discs can't be read by Makemkv and Windows too.
Thanks for helping,
Luca
Screenshot 2024-12-25 174603.png (95.39 KiB) Viewed 9959 times
#1211 Post by Woodstock » Wed Dec 25, 2024 5:11 pm
Pioneer disabled ROM changes in their December 2022 update, making it (currently) impossible to update these drives to read UHD disks. Since the software that they authorize to use that mode isn't available anymore, those drives are useless as far as UHD is concerned.
drknight71
#1212 Post by drknight71 » Thu Dec 26, 2024 6:51 pm
Wanted kernel firmware dump:
viewtopic.php?p=165131#p165131
ETHREAL1
#1213 Post by ETHREAL1 » Fri Dec 27, 2024 3:11 pm
Woodstock wrote: Wed Dec 25, 2024 5:11 pm Pioneer disabled ROM changes in their December 2022 update, making it (currently) impossible to update these drives to read UHD disks. Since the software that they authorize to use that mode isn't available anymore, those drives are useless as far as UHD is concerned.
Are you replying to me? If so should I try and return the drive?
#1214 Post by Woodstock » Fri Dec 27, 2024 3:25 pm
Yes, your drive was built after they disabled UHD. If your purpose is to rip UHDs, then yes, you should return that drive for a refund.
lurker2100
#1215 Post by lurker2100 » Sat Dec 28, 2024 2:10 am
Based on recent messages, it looks like this drive can be made to read UHD discs. Is that true?
OS device name: E:
Revision: 3.10
Serial number: ********
Highest AACS version: 47
