Audio and subtitle track selection using CLI
dagor
Post by dagor »
I've looked at usage.txt and several forum threads, but I can't figure out how I form a commandline argument that rips a bluray with specific audio tracks and specific subtitle tracks. I've made an application that already figured out all audio track and subtitle track ids.
I just can't find a good example of how a more advanced ripping CLI is used.
makemkvcon.exe mkv disc:0 0 "file_path"
The above is clear, but it rips everything, I want a subset of audiotracks and subtitle tracks. Can more clear examples of this be given?
Much appreciated!
dagor
Re: Audio and subtitle track selection using CLI
Post by dagor »
If the mentioned above is not implemented, it would be a great feature. A proposed API would be:
makemkvcon.exe mkv disc:0 0 "file_path" --audio-track=0,1 --subtitle-track=1,4
So a comma separated list of the track ids that were retrieved via
makemkvcon.exe info
I currently need to rip everything, that means it results in a file that is 7GB larger than it should be (with a recent Bluray I bought) and after that use mkvmerge to strip the unwanted audio tracks. This then again results in roughly 60GB required diskspace to rip a single 1080p bluray. It's doable, but very ineffecient.
In any case, I do want to thank Mike for creating this amazing tool!
Ezatoka
Post by Ezatoka »
As much as I remember makemkvcon on Windows uses the language selection from the GUI, which you can set up in the advanced options.
I don't think there is a way (yet!) to make a selection via CLI.
dagor
Post by dagor »
Ezatoka wrote:
Wed Dec 18, 2024 2:44 pm
Thanks! Another idea is to make the Default Track Selection available as a CLI input:
makemkvcon.exe mkv disc:0 0 "file_path" --profile=-sel:all,+sel:(eng|nld|nolang),-sel:mvcvideo,=100:all,-10:favlang,-sel:(attachment)
If this is possible, I can write logic that will automatically select the wanted languages. That would be amazing!
