Hi
I have an ISO file from Battlestar Series 1 Disc 1. It was burnt to a folder structure using anydvd and then changed to an iso using imgburn (just a change of storage preference, no other reason).
Two of the epsidodes come up with errors. Here is the output from one of them:
MakeMKV v1.6.15 win(x64-release) started
Debug logging enabled, log will be saved as C:\Users\Ben/MakeMKV_log.txt
Cells 5-end were skipped due to cell commands (structure protection?)
Title #0 was added (4 cell(s), 0:42:52)
Title #1 was added (4 cell(s), 0:41:50)
Title #2 was added (4 cell(s), 0:41:57)
Title #3 was added (4 cell(s), 0:41:47)
Cells 17-end were skipped due to cell commands (structure protection?)
Title #4 was added (16 cell(s), 2:48:26)
Title #5 has length of 24 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #6 has length of 14 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #7 has length of 12 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Saving 1 titles into directory P:/Video - not used in MediaPortal/MakeMKV
Program reads data faster than it can write to disk, consider upgrading your hard drive if you see many of these messages.
DEBUG: Code 1152 at aunO=lJAWqIjw[[SDBEZO:213133250
DEBUG: Code 55 at bCs<Y/4t@TU?,NDiE<x:121266626
DEBUG: Code 149 at bCs<Y/4t@TU?,NDiE<x:121266925
DEBUG: Code 12 at bCs<Y/4t@TU?,NDiE<x:29398737
DEBUG: Code 0 at aunO=lJAWqIjw[[SDBEZO:213134377
Failed to save title 3 to file P:/Video - not used in MediaPortal/MakeMKV/title03.mkv
0 titles saved, 1 failed
Is this a problem with my image? It seems to play ok in other programs when mounted. I'm not at home for a bit so can't redo the disc at the moment.
Ben
BSG Series 1 Disc 1 (ISO)
setarip_old
Re: BSG Series 1 Disc 1 (ISO)
Hi!
Yes, the surest way would be to use the original, commercial DVD as your input to MakeMKV - No point in first creating an .ISO image file...redo the disc...
- Contact:
It's a mastering error. The next version should be much better handling these.
